Old 08-11-2015, 09:10 PM   #1
1972 23' Safari
Indian Head Park , Illinois
Replacing old tires / wheels on 1972 Safari LY
I am looking to replace the tires and possibly the wheels on a 1972 Safari LY (23'). The current tires are pretty cracked and worn (probably at least 30 years old), and the lug nuts are pretty heavily rusted. I am also having difficulty finding any type of identification marks on the sidewalls to determine the size.
The Airstream Service Manual indicates that this trailer has 7:00x15 (6 or 8 ply) tires. From what I have been reading on this forum and elsewhere, I believe that this size translates to the modern tire notation of: ST225/75R15 tires. Does this sound correct?
Thank you.
amurfey is offline   Reply With Quote
Old 08-11-2015, 09:50 PM   #2
Mission , Texas
Hi,
We recently went through this drill as the DOT numbers concluded that one tire on our 75 could possibly be original. The tires weren't cracking and held air okay. But the guidelines are the lifespan of a tire is 3-10 years depending who is talking and if the tires are subjected to UV or unweighted and pressure reduced when in storage.
Rims supposedly have a stamp on them to tell you their weight rating. I was unable to find any on my presumably original steel wheels which for now we're keeping (plus we have the original hubcaps).
A couple of sites quoted the size of the original 7x15s to be 27.88" diameter, 225/75-15 to be 28.1" diameter, and 205/75-15 to be 27.1" diameter.
I have visible damage to the lead edge of the wheel wells, so the replacement tires are 205s, trailer tires, load range C (1,820 pounds @ 50psi - sometimes referred to as 6 ply).
You might try pulling one off and looking at the other side.
nrgtrakr is offline   Reply With Quote
Replacing 15" Bias tires on my 1972 31 Sovereign cole3444 Tires 10 06-11-2014 06:15 PM
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
Tires- How old is too old?? rbr Tires 20 08-09-2009 09:26 AM
Subing Wheels/Tires from New to Old? GT1963 Tires 3 12-05-2004 02:59 PM
