Old 05-07-2015, 06:37 PM   #1
1993 25' Excella
CLeveland , Ohio
Replacement of Tires, Bearings and Brakes.
What would be a fair installed price for four LT 225-75-15 non-asian tires, replacement of all brake pads and bearings on a 1993 25 foot Excella by a repair facility? Just trying to figure out costs. THANKS!
Akronguy is offline   Reply With Quote
Old 05-07-2015, 07:02 PM   #2
K.C. , Missouri
$320 per wheel for a new brake backing plate with all new components, a new tire mounted and balanced, and all labor charges should cover it.
Edit: maybe a few $$ more with the cost of new bearings and seal.
gmw photos is offline   Reply With Quote
Old 05-09-2015, 10:13 AM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Each labor market could be different. Los Angeles will be a lot different than say Youngstown.
>>>>>>>>>Action
Action is offline   Reply With Quote
Old 05-09-2015, 10:51 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
RV labor rates can be as low as $75/hr. and up to $125/hr.
dwightdi is offline   Reply With Quote
Old 05-09-2015, 02:23 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Look at Eastern Marine the 10 x 2 1/4 are on sale for $26.00. It take about 1/2 hour per backer plate to install. While off another 1/2 hour to clean and pack the bearings, most dealer will do that they will just pack them dirty in 5 mins. If the bearings are packed right you need new seals about $5.00 from a supply house or $15.00 from a shop.
Tires and balancing depending on what you buy.
The important thing is to jack up the trailer when completed and rock the wheel while holding at the top and bottom. You should feel a slight movement. No movement they are TOO TIGHT and you will burn a bearing.
2004 Excursion 4x4
Old 05-10-2015, 02:29 PM   #6
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
New backing plates with brakes and magnet 115$ new drums 112$ with bearings..
tjdonahoe is offline   Reply With Quote
Old 05-10-2015, 02:52 PM   #7
K.C. , Missouri
I made my guesstimate based on the thought that a tire, mounted and balanced should be under $200. Etrailer has brake backing plate complete for $56, and a bearing kit for $12. Around here labor is about $100/hour, so a shop should be easily able to do one position in half hour. So roughly $310, so I said $320 plus maybe a little more for parts markup, etc.
All in one replacement hubs, brakes, bearings. ArgosyGypsy Brakes & Brake Controllers 17 05-14-2011 08:16 AM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
Help w/ wheel bearings and brakes. mrmossyone Brakes & Brake Controllers 20 12-15-2007 04:29 PM
