Old 05-27-2009, 07:13 AM   #15
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
If your tire is difficult to install between the hub and the trailer body, you may be having a problem with your axle.
When changing tires, be sure to look at the clearance at the inside of the tire near the frame (backside of the tire) to make sure sidewall clearance is NOT an issue. If it is close enough to rub at a standstill, the tire will flex enough during travel to cause a failure if rubbing against the frame.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 05-27-2009, 10:19 AM   #16
Mexray's Avatar
1978 28' Ambassador
Morada , California
I've been using bias ply tires on my various trailers for ages...nothing wrong with em', as posted above...
My tire guy set me up with some 7.00-15's for our AS a few months ago - only have about 500 miles, but everything's good to go, so far...
Yes, they're imported...what isn't...they are:
Hartland, EXP Highway, Load range D, 6 ply nylon tread, 4 ply nylon sidewall, max load 2040 lbs @ 60 PSI (D)...
They were 'fresh dated' stock from a local tire distributor, and my guy has used them without any know problems...he says, anyway...
Correct tire pressure and a quick check with your palm to check for excesive heat when you stop, go a long way to avoid tire problems...
Just my 5/64's tread depth opinion...
Ray & Pat; Morada, CA
Old 05-27-2009, 10:27 AM   #17
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
Originally Posted by SnoSheriff View Post
I also read that the 225's are a bit smaller in diameter that the 7.00x15. Is that true and other than sitting lower what impact does that have on the trailer?
On our old '79, when we went from 7x15 to 225's, the aluminum tire clamps that act like chocks did not fit anymore. The difference in diameter of the tires put them out of the adjustment range.
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 05-27-2009, 10:59 AM   #18
Cos
1973 21' Globetrotter
Middletown , Rhode Island
I changed to a 16in rim and went with BF Goodrich commerical tires. I found there was a larger selection of tires at different load and speed ratings with the larger wheel.
Cos is offline   Reply With Quote
Old 05-28-2009, 05:49 AM   #19
1984 31' Excella
Norfolk , Virginia
Images: 11
Tires
Ditto
Beginner
Beginner is offline   Reply With Quote
Old 04-30-2011, 05:27 AM   #20
r carl's Avatar
Lin , Ne
Originally Posted by overlander63 View Post
That's because it's an off-road tire.
This is the one to get.
Yokohama RY215
Need help with size of black tank replacement drowe42 Waste Systems, Tanks & Totes 2 05-25-2009 05:01 PM
7.00x15 6 ply Load Range D rasmuw Tires 21 04-08-2008 09:16 PM
mattress replacement advice george1 General Interior Topics 34 02-20-2008 04:58 PM
A/C replacement size? 345 Honkity Hank Classic Motorhomes 16 03-16-2006 08:28 AM
Refrigerator Replacement Size Problem Herritt Refrigerators 4 05-04-2005 11:47 AM
