Hi
I need to replace my 7.oo x 15 tires
here in the netherlands these tires are hard to get and verry expencive
witch tire has the same height
235/75/15 or smaller
Remco
remcolent,
I have been told, the replacement to 7.00X15 is 225X75X15 radial. Goodyear Marathons are the best. You need to find a tire that is specific for trailers. Auto tires will not be sufficient. Hope this helps. You might be able to find a Michelin 7.00"R" X 15 radial in Europe. I saw one vintage trailer last summer that had them. I checked at home and our local Michelin dealer just rolled his eyes. I took that as a "No."
Hi
Remco
ST225/75R15 in the same load range you have on your trailer. Should be load range C for your smallish two axle trailer. Here is the URL of a Cooper tire dealer in the Netherlands, that should be able to help you. http://www.interstate.nl/
Good luck in the hunt!
thanks for the replies
but is the 225/75 the same height
I need the height to have enough clearance on the rear bumper
to get in and out my driveway
Remco
No. The 700 x 15 is approximately 1.5" taller than the 225 x 15. Many people like t he 700 because of this factor, it helps keeping the rear end from dragging on bad dips. The H78 15 is the same size as the 225's
Keep the shiny side up. WBCCI # 3485 Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @ www.tidewaterwbcci.com
Rick Bell in "Silverbell"
