Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 04-25-2005, 03:52 PM   #1
remcolent
Profile:  1986 32' Excella
vledder , drenthe
replacement for 7.00 X 15
Hi
I need to replace my 7.oo x 15 tires
here in the netherlands these tires are hard to get and verry expencive
witch tire has the same height
235/75/15 or smaller
Remco
remcolent is offline   Reply With Quote
Old 04-25-2005, 04:55 PM   #2
Coloradobus
Profile:
remcolent,
I have been told, the replacement to 7.00X15 is 225X75X15 radial. Goodyear Marathons are the best. You need to find a tire that is specific for trailers. Auto tires will not be sufficient. Hope this helps. You might be able to find a Michelin 7.00"R" X 15 radial in Europe. I saw one vintage trailer last summer that had them. I checked at home and our local Michelin dealer just rolled his eyes. I took that as a "No."
Coloradobus is offline   Reply With Quote
Old 04-25-2005, 06:41 PM   #3
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Originally Posted by remcolent
Hi
Remco
ST225/75R15 in the same load range you have on your trailer. Should be load range C for your smallish two axle trailer. Here is the URL of a Cooper tire dealer in the Netherlands, that should be able to help you. http://www.interstate.nl/
Good luck in the hunt!
Change is inevitable, except from a vending machine
AIR#2611
Old 04-25-2005, 07:02 PM   #4
sovereignrwe
sovereignrwe's Avatar
Profile:  1972 31' Sovereign
Oakdale , Minnesota
Last summer, we purchased Yokohama 7.00 x R15s.
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 04-25-2005, 11:31 PM   #5
remcolent
vledder , drenthe
thanks for the replies
but is the 225/75 the same height
I need the height to have enough clearance on the rear bumper
to get in and out my driveway
Remco
Old 04-26-2005, 05:18 AM   #6
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
No. The 700 x 15 is approximately 1.5" taller than the 225 x 15. Many people like t he 700 because of this factor, it helps keeping the rear end from dragging on bad dips. The H78 15 is the same size as the 225's
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 35 06-18-2007 06:47 AM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Pictures of shell off floor replacement... williamhenshall Repairing/Replacing Floor &/or Frame 23 08-08-2002 05:05 AM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
61 Bambi Panel Replacement 61BambiCanada Ribs, Skins & Rivets 0 06-07-2002 09:41 AM
