03-03-2015, 08:46 AM
#41
1981 31' Excella II
New Market
, Alabama
I run about 25 psi in the rear tires of my Ranger but there is no weight in it. Anything more than than and they wear in the center. Now in an explorer, I would never do that since it has more weight back there. An explorer is basically an SUV on a ranger chassis.
Perry
Originally Posted by SteveH
The real problem in the Explorer/Firestone thing was the fact that Ford had such a miserable riding vehicle that they specified the tires be run at 24psi to attempt to cover up the horrible ride of the Explorer.
Anyone with any knowledge/experience with tires run at low air pressures at highway speeds knows the tires will get overheated and come apart. Simple physics of tires. Why do you think we run 65psi or higher in our trailer tires?
Granted the Firestones were not the greatest tires in the world, but the real problem was running them at 24psi., the Ford specified air pressure.
03-03-2015, 08:51 AM
#42
1981 31' Excella II
New Market
, Alabama
I did have a plug patch fail one time and it was on a high miliage tire. I hit a rail road crossing just right and it must have lifted the patch off. It may not have been installed correctly. I had the tire patched again and no more more problems. I have had more than one of the old plugs fail.
Perry
03-04-2015, 05:05 AM
#43
CapriRacer
I'm in the
, US
Originally Posted by A W Warn
CapriRacer,
Will you expand a little on the definition of the term "underinflated"? What does that really mean?.....
I'm going to be slicing the baloney pretty thin here, so bear with me.
I think everyone will agree that if you are operating a tire at an inflation pressure less than what the tire load tables says, then it is underinflated. Of course, the amount of under inflation is proportional to how much below that value it is being operated.
Then there is the issue of what the vehicle manufacturer specifies - which ought to be a bit more than the load table. In this region, I would use the term *underinflated* when the value is less than specified.
But the physics of the situation is this: There isn't a clear cut line where a tire is so underinflated that it will fail instantly. Sure, a flat tire doesn't last very long (we're talking feet and seconds, here!), and one with only a few psi might last a few miles, but in neither case is it immediate. That's because these types of tire failures are durability issues and it takes a long time for the cumulative affects of underinflation to cause a failure. We engineers use the term *fatigue* - and the more overstressed something is, the quicker it fails due to fatigue.
So one can operate a tire slightly underinflated and think everything is OK - until one day the tire fails.
But if we look at the other end of the spectrum, I am calling anything over the vehicle manufacturer's specification *overinflated* - BUT - a tire can operate just fine a bit over inflated - no wear issues because tire wear is more affected by other factors.
For example perryg114 reports above that the rear tires on his Ranger wear in the center when the pressure is larger than 25 psi. That's because drive tires tend to wear in the center, while steer tires tend to wear in the shoulder - and that affect is greater than the affect inflation pressure has. I would caution perryg114 that he could be running his tires underinflated (that is, below what the load table says) and not realize it.
There is a simple test that works very well in determining if a tire is being operated underinflated - pressure build up. The rule of thumb is that you don't want the pressure to build up more than 10%.
If you have a TPMS that reads the pressure directly and transmits that to the cab, great! But if you don't have one of those, then manual measurements work. While it takes a while for a tire to reach its stable operating temperature, certainly an hour is adequate.
Oh and this isn't a target you should be trying to hit. It's a warning sign that things are wrong. Lower is better - and as I said before, it is just fine to be operating a tire a bit overinflated.
03-04-2015, 05:56 AM
#44
Ravenna
, Ohio
I like and agree with what CapriRacer said.
I have seen statements in print from various sources in the tire induftry that operating at 20% blow the specified inflation is considered "flat" and can be used as a reason to void a warranty.
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
03-04-2015, 06:05 AM
#45
Lin
, Ne
I have a Chevrolet 3500HD that came with 225/70R/19.5F tires. Max inflation on sidewall is #95. Tag in door says #60 front and #75 rear. I have run those pressures 90k on the original tires. Wow, I've been running with flat tires for 90k miles.
03-04-2015, 06:06 AM
#46
Ravenna
, Ohio
Am I the only one that finds it interesting that, by my count at least, we have two Tire Engineers on this forum, and I've never read either one make a definite statement about a tire, good or bad, but only vague innuendo's of what might result if whatever the topic is about actually does happen?
In every situation there is a worst case possibility.
Steve, You haven't offered information on what your profession is but before you decide to ignore the advice of the tire engineers here I would ask what answer you get when you ask your Dr "At what Blood Pressure will I have a heart attack?" Ever been given a specific number such as 193/99 ?
Ever seen a car advertise the exact fuel economy you can expect?
What is the exact depth of water (in inches) in which you would drown?
I can go on.
Life seldom has simple yes and now answers.
#47
1981 31' Excella II
New Market
, Alabama
I think I am right at the limit of under inflation. There is also the issue of having no traction especially in wet weather with the tires above 25psi. This is a fringe issue and has nothing to do with heavily loaded trailers.
I do think those running 4 E rated tires at 80 psi on a 6000lb trailer is silly and it is just going to beat that poor trailer to death.
Perry
03-04-2015, 06:08 AM
#48
Lin
, Ne
I've only seen excuses.
03-04-2015, 06:12 AM
#49
Ravenna
, Ohio
Sorry no you haven't. The placard is based on an assumption of what your load might be.
Now if you provide the actual load you have always run for each tire position we will know what your inflation should be.
03-04-2015, 08:02 AM
#50
2000 25' Safari
Davidson County
, NC Highlands County, FL
For tire dummies like me, would you clarify what is meant by "tire load tables"?
Who's tire load tables? Are you referring to the placard on the vehicle door, a load chart that is provided by the tire manufacturer, or something else?
add edit:
About 3 years ago I purchased a set of tires for my Safari. After they were installed I asked for an inflation/load chart, so that I would know how to inflate the tires properly. The tire dealer, and later the manufacturer's sales rep, told me they did not have one specifically for those tires. The inflation information on the sidewall is the only thing I have to go on.
Since the rims on my Safari have PSI 65 MAX cast into them, I cannot inflate the tires to the 80 PSI maximum that is marked on the sidewall. I'm running at 60 PSI with a load ranging from 1500 to 1800 Lbs on each tire. Are these tires underinflated?
Alan
03-04-2015, 08:26 AM
#51
Lin
, Ne
My service truck weight is 12,600# all the time. FA is 4800# and RA is 7800#. GVWR is 15,000#.
03-04-2015, 09:13 AM
#52
1976 31' Sovereign
Oswego
The tire discount I go to has free tire pressure checks, well last time I went tech inflated tires to sticker on truck that is more than side wall on tires. Argued with me had to inflate by law. got manager we went over what was proper agreed with me then inflated pressure that I spec. Tech is no longer emp.
03-05-2015, 07:22 AM
#53
CapriRacer
I'm in the
, US
For tire dummies like me, would you clarify what is meant by "tire load tables"?........
http://www.barrystiretech.com/2005traloadtable.jpg
This is a tire load table. Basically, it is an inflation pressure vs max load table sorted by tire size and type. Somewhere in the heading will be notes about where the table is applicable.
.......Who's tire load tables? Are you referring to the placard on the vehicle door, a load chart that is provided by the tire manufacturer, or something else?.......
Well, the load tables are issued by a tire standardizing organization, such as The Tire and Rim Association (TRA, for short) the US based organization - and those tables are reprinted by the tire manufacturers. All the tire manufacturers use the same tables published by the tire standardizing organizations. To make matters a bit more confusing, there are sometimes some differences between tire standardizing organizations, but those differences are minor.
add edit:
First, your vehicle should have a vehicle tire placard that lists the original tire size and the proper inflation pressure for that size. Vehicle tire placards can be found on doors, doorposts, glove boxes, fuel filler doors, trunk lids, etc.
There should also be a certification label that will list the GVW (Gross Vehicle Weight), and the GAWR's (Gross Axle Weight Ratings). Trailer manufacturers haven't always done a good job with the certification label as many trailers exceed those values.
Second, what tire size are we talking about? There will be a load table that will list a minimum inflation pressure for a given load. Typically, the vehicle manufacturer will specify MORE inflation pressure than the minimum.
And lastly, if I want to answer this question directly "..... Are these tires underinflated?....", I need to know 3 things: The tire size, the actual load on each tire, and the inflation pressure. I'm short one item.
03-05-2015, 07:33 AM
#54
CapriRacer
I'm in the
, US
OK, let's do the math:
A 225/70R19.5 inflated to 60 psi front /75 psi rear has a load carrying capacity of 2615# front (single) / 2860 rear (dual), which means the front axle GAWR can be no higher than 5230# and the rear GAWR no higher than 11,440#. Yup, both are below those values.
So does that answer your question?
03-05-2015, 08:13 AM
#55
2000 25' Safari
Davidson County
............Second, what tire size are we talking about?
..........And lastly, if I want to answer this question directly "..... Are these tires underinflated?....", I need to know 3 things: The tire size, the actual load on each tire, and the inflation pressure. I'm short one item.
For my trailer tires use these (lowest load to highest load)
For tire # 1 of 4:
Tire size = ST225/75-R15 load range E
Tire load = 1,600 lbs
Tire inflation = 60psi
For tire # 2 of 4:
Tire load = 1,800 lbs
Alan
03-05-2015, 08:58 AM
#56
Lin
, Ne
You think they are under inflated?
03-05-2015, 09:37 AM
#57
Ravenna
, Ohio
OK I accept the challenge. You give me a specific question with all the relevant facts and I will offer my opinion.
It may help if I knew your profession so I can understand your view on product quality and reliability.
03-05-2015, 09:56 AM
#58
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Who here disagrees that a tire with internal damage resulting from being driven under inflated usually always displays external evidence of this damage via bulges, lumps, uneven sidewalls, or knots on the sidewall or tread area?
In short, the damage to the interior of a tire USUALLY becomes visible on the exterior.
The application of common sense sense goes a long way.
I can't remember the last time I was stuck on the side of the road with a failed tire or even a flat. Perhaps 20 years or more?
Part of this is what is called "luck", but part of this is paying attention to my tires.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
03-05-2015, 10:15 AM
#59
Ravenna
, Ohio
Lets try a different approach to see if we can help you understand what is meant by under inflated.
" Under inflated" means less air pressure than is needed to carry the load.
For motorized vehicles we see than if we assume your axle weights are equally split side to side, each front tire is loaded to 4,800/2 or 2,400#. As Capri has pointed out your 225/70R19.5 LR F inflated to 60 psi has 2615# capacity so your have EXCESS load capacity of 215# for each tire
You are not under inflated.
Lets look at the rear position where I assume you are running duals.
Again as Capri said "75 psi rear has a load carrying capacity of 2,860# (dual)" but your actual load, again assuming exact 50/50 split side to side is 7800/4 or 1,950# per tire. Your load capacity for the 4 rear tires totals 11,440 but you are only loading them to 7,800# so you have Excess Capacity of 3,600# total on the rear axle.
Again you are not under inflated.
An example of under inflation might be when someone running 225/70R19.5 LR F inflates the front tires to 65 psi which according to the Load/Infl tables indicates 2,755# load capacity for each tire but has loaded the vehicle such that the front axle measures at 6,000#. In this case the actual load EXCEEDS the capacity by 490#. In this case the tires are "under inflated".
Hope that between Capri's answer and my example you now understand what is meant by under inflation.
03-05-2015, 10:16 AM
#60
2000 25' Safari
Davidson County
I made my first tow in the late 60's. So far (knock on wood) I have not had a flat tire on any trailer I have owned. On cars and trucks I have occasionally, but not on my trailers.
I have found metal objects stuck into treads and had them repaired when needed. I would say part of it is "luck", but the larger part is being vigilant about checking tire pressure and inspecting tires before, during, and after each tow.
Alan
