Old 10-23-2011, 12:52 PM   #1
Rolo's Avatar
1962 22' Safari
Cedar Rapids , Iowa
Images: 21
Removing tire from '62 Land Yacht
I'm the new owner of a 62 Land Yacht and I want to replace the shocks. I jacked up the trailer, removed the lugs, and tried to pull out the tire, but no room between the fender and the wheel. I could probably let out the air and wiggle it out, but what if I have a flat on the road somewhere. I sure don't want to let the air out of spare to get it back on. I thought about removing the wheel bearing dust cap, but don't want to screw up the threads working the rim out. What am I missing here?
Rolo is offline   Reply With Quote
Old 10-23-2011, 12:58 PM   #2
Rolo.
Many owners have experienced the same issue.
The answer is that the rubber rods in the axle have solidified and won't let the tire drop the 3 inches as it's supposed to, when you jack up the trailer.
Old 10-23-2011, 01:06 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Sounds like the rubber rods in the axles are petrified. Did the wheel move down at all when you jacked the axle up? There are no threads on the dust cap, it is a press fit.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 10-23-2011, 01:14 PM   #4
1963 30' Sovereign
westwego , Louisiana
My 63 sov is threaded.
NOLA Geoff is offline   Reply With Quote
Old 10-23-2011, 01:30 PM   #5
Threaded grease caps were indeed true, many years ago, and, for a very short time.
I have no idea why they were, and now they are not.
Old 10-23-2011, 03:54 PM   #6
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Andy, is my bad axle on my 67 the reason the tire seems sooooo close to the wheel well. Will the new axle and shock combo remedy this? Or do I have bigger problems?
Thanks.
Dingo Girl is offline   Reply With Quote
Old 10-23-2011, 04:11 PM   #7
1994 28' Excella
Paris , Ohio
Are you jacking up the trailer, or the axle? You must put the jack under the trailer and jack it up, until the tire is about 3 " off the ground this should allow the axle to drop enough to get the wheel off, good luck.
trapperman33 is offline   Reply With Quote
Old 10-23-2011, 06:15 PM   #8
Thanks.
A new axle properly designed would lift your Airstream about 3 inches higher than it is now.
That would take care of the tire issue.
Old 10-23-2011, 06:37 PM   #9
1963 30' Sovereign
Theres a spot on either side behind each rear wheel,on the belly, marked with an extra piece of aluminum. That's your jack point. Another technique is, if you have a double axle, drive up onto layers of 2x8 blocking with your good tire, And swap your bad one. Haven't changed a tire yet, but this is what i've gathered over the past month.
Old 10-23-2011, 06:42 PM   #10
That "JACK" label, is for a stabilizing jack, not a lifting jack.
The correct way to safely lift an Airstream with a jack, is to use the rear end of the "axle mounting plate".
Old 10-23-2011, 06:45 PM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Safe jacking....
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-23-2011, 07:00 PM   #12
Originally Posted by ROBERT CROSS View Post
Safe jacking....
AMEN.
Old 10-23-2011, 07:00 PM   #13
1963 30' Sovereign
Thanks Andy. You saved me an outrigger and possible broken bones.
Old 10-23-2011, 08:31 PM   #14
Rolo's Avatar
1962 22' Safari
Cedar Rapids , Iowa
Images: 21
Andy,
I got the tire and the shocks out, but had to take the dust cap off. The arm didn't drop 3 inches. Am I wasting my time looking for shocks? Do I need a new axle?
Thanks.
235/75R15XL vs 225/75-15 trailer tire perryg114 Tires 129 07-18-2012 01:59 PM
Very strange tire wear rbhinzman Tires 17 10-21-2011 08:43 AM
Need spare tire rim for size 700-15 1976 has alum mag wheels Caravanner76 Wheels, Hubs & Bearings 3 10-18-2011 09:21 PM
Removing window frames '61 GT streamahead Windows, Doors, Locks & Vents 3 07-30-2011 09:47 AM
