Old 01-13-2018, 12:09 PM   #1
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
Removing lug nuts due to flat solid or capped?
ID:	302342Click image for larger version
ID:	302343Click image for larger version
Luckily the nail in the tire was discovered in the driveway.
I was trying to remove the lug nuts to take the tire off. Using a 3/4 inch socket the first came off fine. The second the cap broke off. (See pics above.) How do I remove the lug nuts?
This has not happened when I check the torque.
Matti
Mattirs is offline   Reply With Quote
Old 01-13-2018, 12:15 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
A 6 point socket should still fit the nut.
2004 Excursion 4x4
Old 01-13-2018, 12:59 PM   #3
1959 22' Flying Cloud
Escondido , California
Ford, Toyota and a couple of other mfg's use caps on some of their lug nuts. Best thing to do is use a variety of sockets. Only use 6 point and don't use an impact gun.
If the nut is new or it looks like it is still in really good shape then use the socket that fits the tightest.
If the nut has some slight damage or marks then use the socket that is a tight fit or slightly small. You might have to force the socket on.
If the nut is in really bad shape you're going to have to use a smaller socket, line it up and force it on. I usually use a mallet to get it on.
To remove the stuck nut from the socket you can place it in a vise and knock it out with a bolt.
I keep spare lug nuts, various sockets and breaker bar with me. BTW, if you are using stock wheels it's not as easy as replacing the capped ones with solid ones. Ford for example has a patent on the angle of the taper. You can buy solid lug nuts that fit the thread but they won't seat properly with stock wheels.
Good luck.
"On a vintage Airstream if it aint absolutely broke DON'T TOUCH IT!!"
2bkidfree is offline   Reply With Quote
Old 01-13-2018, 01:23 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
Those things are nothing but a pain. I discovered mine like the OP... in my driveway where I had access to a multitude of tools. Even then, they put up a fight. I promptly replaced them with solid nuts.
CRH is offline   Reply With Quote
Old 01-13-2018, 01:48 PM   #5
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Yup, very early on we replaced Airstreamís terrible original capped lug nuts with solid ones.
Rocinante is our 2014 International Signature 27FB
Old 01-13-2018, 02:58 PM   #6
2016 28' Flying Cloud
Auburn , Alabama
I had the same problem. I found this video on how to get them off and it worked pretty good. Each one came off in about a minute.
https://youtu.be/iG3V59HQCQ8
Here's the aftermath.
Bobert is offline   Reply With Quote
Old 01-14-2018, 09:19 AM   #7
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
A great thread relating to this problem can be found here
Greg
greghoro is offline   Reply With Quote
Converting from lug bolts to studs and lug nuts tim781996 Wheels, Hubs & Bearings 7 11-22-2014 09:23 AM
Nuts on lug nuts Steel rim spare tire!y Griff Wheels, Hubs & Bearings 4 02-13-2014 08:51 AM
lug nuts or lug bolts Mbirdshooter Wheels, Hubs & Bearings 3 07-20-2010 02:00 PM
Lug nuts vs. lug bolts dorfgog Wheels, Hubs & Bearings 9 04-19-2010 09:41 PM
Removing rear skin due to dents IPM Ribs, Skins & Rivets 11 09-02-2003 10:11 AM
