Old 03-22-2018, 09:35 AM   #1
kdinnar's Avatar
2017 27' Flying Cloud
2014 25' FB Flying Cloud
2013 23' FB Flying Cloud
Boothbay Harbor , Maine
Removing All Four Wheels At One Time
I've ordered 4 new tires for our 2017 FC 27fb. The tire shop is a distance away. Does anyone have a good procedure for removing all 4 wheels without doing any damage. My idea was to jack up the trailer at the jack point, removing the two wheels, then lowering that side with the drums resting on blocks. Then I would go to the other side and repeat the process. How does that sound?
Joyce and Ken
2017 Flying Cloud 27FB
2017 Ram 2500 Limited
kdinnar is offline   Reply With Quote
Old 03-22-2018, 09:41 AM   #2
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Do Not lower the trailer onto the drums. Lower it down onto blocks under the the axle beam close as possible to the axle to frame mounts.
Alan
AlinCal is offline   Reply With Quote
Old 03-22-2018, 09:41 AM   #3
jkwoodrow
1987 34.5' Airstream 345
Springfield , Ohio
You will be be ahead to borrow or buy four jack stands. When you jack up each axle (loosten the lug nuts slightly before) put a jack stand under each axle then remove the wheel. You'll be very happy when you don't need to jack everything up twice.
John Woodrow is offline   Reply With Quote
Old 03-22-2018, 10:27 AM   #4
Boxite's Avatar
2008 22' Sport
I would NOT place jack stands under the axle. The hollow axle will be damaged. Place the 4 jackstands under the FRAME... two at front and two at rear. When you have the AS jacked up.... look underneath and follow the frame-lines... they'll be evident if you take your time to do this right.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 03-22-2018, 11:02 AM   #5
Mollysdad's Avatar
I'm with you all on the jackstands, but I'd place them on the steel support beam for the axles.
Never support the trailer with the jack under the axles. They're hollow. The old style springs are okay, but not the Dexter rubber ride.
Old 03-22-2018, 11:08 AM   #6
1991 25' Excella
The axle beams are structural square steel tubing, a jack under the axle will do no harm other than scratch the paint.
Alan
Old 03-22-2018, 11:12 AM   #7
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
When removing all four wheels at once, the very first thing I do is connect to my tow vehicle (with parking brake on) and place the tongue jack just on the ground, this will safely support the front of the Airstream and also provide a "brake". Then I place my jack just behind the Airstream Jack point tag, jack it up and place 1 jack stand (curbside), replace jack to other (street side) and repeat. Make sure that you are on a hard level surface and the the jack stands are perfectly placed under the frame rails.
When re-attaching the wheels, you MUST use a torque wrench, this is so you don't over tighten the lug nuts.
Happy Airstreaming!
vintagemotor is offline   Reply With Quote
Old 03-22-2018, 11:43 AM   #8
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs down
Do NOT use the axle tube as the jack point...it WILL bend, it is not structural tubing.
The axle is bent at the factory to set alignment.
Two jack stands and the tongue jack works for us.
ID:	306887   Click image for larger version
PFC
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-22-2018, 01:04 PM   #9
1991 25' Excella
Not structural tubing? what material is it then?
They will not bend by jacking or the ones I hauled to the dump that were original and the new ones I installed would trashed.
Jacking under the axle at the mount plate works for me.
Alan
Old 03-22-2018, 01:12 PM   #10
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Ditto. You probably would get away with jack stands under the axle, but I have been told numerous times by numerous people never use the axle as a support or jacking point. The bend of the axle is very important to tire alignment. You probably would not bust anything but a slight bend will cause you problems down the road.
Placing jack stands under the frame will flex the coach if they are too far apart.
Lumatic is online now   Reply With Quote
Old 03-22-2018, 01:24 PM   #11
Thumbs up
I'm sorry, I thought you were jacking on the axle tube, jacking on the mount plate, (as in pic), is the preferred method.
The axle is structurally manufactured so it can be bent....
FAQ's from Dexter...
Why are some axles bent in the middle?
"Sometimes you will notice a slight bend in the axle that is not a Vd axle as described below. Sometimes to set the camber of the wheel (angular relationship to the road) the axle must be bent slightly to make it match the trailer builders requirements. Most times the axle is designed with a camber that takes into the consideration the load that will be placed on the axle."
If your comfortable axle jacking...go for it.
PFC
RLC
Old 03-22-2018, 02:00 PM   #12
Mollysdad's Avatar
Okay, others will disagree. In the interest of safety, I'll not put the jack under the axle tube.
To add some more to the equation, what size jack do you use?
If a floor jack?
I'd rather not use a bottle jack because I don't want to crawl under.
Considering the tongue jack and the other two wheels are supporting a portion of the weight.
Old 03-22-2018, 02:12 PM   #13
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
I don't think there is any disagreement that you should not put a jack or stand on the axle (tube) itself. And that putting it on the beam between the two axles on each side of the trailer (as illustrated by Robert Cross) is a good approach.
Frank & Fran
2016 27' FC FB with 400 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 03-22-2018, 02:31 PM   #14
Central , Mississippi
There has been so many folks repeat the improperly worded warning, it's now an internet fact.
Jacking a trailer under the center of the axle beam will likely bend it. Jacking on the axle tube near the mount plate...no way you will collapse this thing. That is some seriously stout tubing
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Wheels four 2017 flying cloud original wheels Panchopaco Airstream Classifieds 0 08-30-2017 09:33 PM
Four 15" Alumimum wheels from 2014 International Signature Rocinante Airstream Classifieds 0 08-31-2016 06:36 PM
Four Sendel 15 inch wheels (rims) damascus Airstream Classifieds 0 11-04-2015 02:14 PM
1976 Airstream mag wheels (4) four THEBREWERS Airstream Classifieds 0 04-27-2015 05:45 AM
