Old 09-08-2010, 11:40 AM   #1
sylvan lake , Michigan
Recommend a good tire inflator
HELP!!!
Am looking for a reliable, capable tire inflator for maintaining air pressure in my class B motorhome tires (driving a 2007 Airstream Interstate). Believe a 120 volt-type unit---one I can plug into a wall outlet---is probably my best choice, but am not sure which brand or model will best meet my need. (Recommended tire pressure for the Interstate ranges from 55 to 80 psi.)
I want something that will do the job efficiently and am having a "dickens" of a time trying to identify the right product. Can anyone recommend a good tire inflator for doing the job? (Getting a little tired of running to the local gas station and throwing quarters into air machines that time-out after only a few minutes of questionable service.) THANKS!
lg_sylvanlk is offline   Reply With Quote
Old 09-08-2010, 11:54 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
I have a compact 120v unit of the type favored by roofing contractors. It is a cheap brand but has given good service. I believe I went to Fleet Farm and bought the cheapest one. It does weigh 30 pounds or so however so not suitable on the road. I have a 12v pump for that.
Old 09-08-2010, 11:59 AM   #3
1971 29' Ambassador
Leonardtown , Maryland
I have a Black And Decker Air Station. It works on 115vac and 12vdc. It is not the fastes, but when on the road but, it works well.
At home I have a garage kept 115vac compressor with a 12 gal tank.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 09-08-2010, 12:31 PM   #4
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
I have a pretty good 12v compressor in an outside storage spot. I have used it on car tires but have not used it yet on my moho tires. It is rated to the 100# I need for proper fill. I've done business with this vendor for about 15 years and trust the products they offer. 12 Volt Air Compressor - Air Tools - Tools - Griot's Garage
TerraYacht is offline   Reply With Quote
Old 09-08-2010, 02:25 PM   #5
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
At the recommendation of a friend on this Forum I purchased a SENCO air compressor that is compact and lightweight. Google SENCO Air Compressor for more information and where to find the best deal. I bought mine on Amazon.com for around $115.00. While not as fast as my large shop unit it does the job quickly enough and is easy to carry on trips. Coupled with one of my Honda generators it will do the trick in an on the road emergency as well.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 09-08-2010, 02:59 PM   #6
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Maybe 12 volt more versatile
Originally Posted by lg_sylvanlk View Post
HELP!!!
Take a look at this thread:
http://www.airforums.com/forums/f438...sor-63580.html
I bought the "Warn SPC" 12 volt compressor discussed in this thread and have been very impressed with it. I used in June to inflate the flat tire on my campground neighbor's truck. He was unable to get his spare free from the truck. It took his tire from near 0 psi to 75 psi in just a couple of minutes. (I wish I had timed it). This allowed him to drive to the tire shop and have the problem taken care of.
It has the versatility of being available in a rest stop, on the shoulder of the road, or in the middle of nowhere. It beats changing a tire, especially if you are going to the tire shop anyway. It is very compact and easy to store.
Regards,
Ken
Old 09-08-2010, 03:33 PM   #7
Halimer
2006 25' Classic
New Hyde Park , New York
Seconds on the Warn SPC. I have used it to winterize the camper and pump up TV and AS tires. I wouldn't leave home without it.
Mark
halimer is offline   Reply With Quote
Old 09-08-2010, 03:39 PM   #8
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I"ve carried one of these for years, plus a stop-n-go tire plugger kit, and have only used once - on my motorcycle - but it worked like a champ and saved my bacon when I found my rear tire had a nail and was totally flat one morning. It's small, lightweight, pricey, but worked fine. On a MoHo tire, etc., I dont' know. Photos in the ads show it being used in Iraq on a HMMV type vehicle tire. YMMV.
Buy Now: Cycle Pump Motorcycle Air Compressor, EZ Air Tire Gauge, Tire Repair Kit | Pashnit Moto
AirsDream is offline   Reply With Quote
Old 08-08-2015, 02:13 PM   #9
2001 30' Excella
Full-time traveling , Hmmmm. what day of the week is it?
It appears the Warn inflator is no longer made, so I was wondering what folks are using nowadays?
JBBeaubeaux is offline   Reply With Quote
Old 08-08-2015, 02:27 PM   #10
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I carry a couple compressors, both from Harbor Freight. A small 12 volt and a lightweight AC 100 PSI oil less 3 gallon pancake model. Happy with the performance of both. Of course the AC model is much more efficient and quicker to use.
MICHAEL
Old 08-08-2015, 02:42 PM   #11
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Check the ratings for 12 Volt compressors on Amazon...
Old 08-08-2015, 02:57 PM   #12
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
We bought the Viair 450-P in 2012 and it has performed very well. Looks like now they have a 450P-RV. Does a great job and is quiet.
Amazon.com: VIAIR 450P Automatic Function Portable Compressor: Automotive
Silverbee is offline   Reply With Quote
Old 08-08-2015, 07:54 PM   #13
2016 30' Classic
Erie , Colorado
Viair 400P-RV does fine and a bit less expensive than the 450.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 08-08-2015, 08:12 PM   #14
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I have one of these and have been really happy with it.
VICTOR Direct Drive Tire Inflator,150 psi - Tire Chucks and Inflators - 5DYY9|22-5-60135-8 - Grainger Industrial Supply
Alan
What Generator Do You Recommend? mistermike Generators & Solar Power 35 08-19-2010 12:49 PM
When a good tire goes bad ArtStream Tires 6 06-03-2009 11:52 AM
wheel/tire recommend for single ax. overlander (1957) p.dow Tires 23 10-01-2008 01:59 PM
Spare Tire.What is a good rim? Devoman Wheels, Hubs & Bearings 6 09-08-2006 04:43 PM
Good 'Ole Glycerin for tire dressing JodynJeep Tires 10 01-25-2006 07:54 PM
