Old 03-28-2005, 10:03 AM   #1
frozen chosen's Avatar
Recall = rebalance?
I read, with some amusement, the recent "I'm troubled" string. I am still not sure what this guy was saying or complaining about, but I did notice Inland's mention of the importance of balancing the tire/wheel/hub assembly. With the '04 recall, many of us have new bearings now. Before the recall came out, our 16's bearings failed in a big way, destroying bearings and cracking the hub in two (thanks AS). Is there a need to balance again? In fact, I wonder if my tires/wheels were ever balanced at all; do they do this at the factory? The tires have no leads on them to indicate it was done.
frozen chosen is offline   Reply With Quote
Old 03-28-2005, 10:11 AM   #2
1971 29' Ambassador
Leonardtown , Maryland
Balancing
Could the weights be on the back side of the rim?
I would think balancing is good for the longevity of the tires.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 03-28-2005, 10:36 AM   #3
Images: 59
There is lots of previous discussion on this; I think the conclusion was that the drums are not balanced at the factory. On that basis, I'm not sure balancing the wheels and tires alone is worthwhile.
Old 03-28-2005, 11:17 AM   #4
Jeez, I gotta learn not to ask questions like this - talk about TMI... There is a lot said on this subject; maybe less in the way of conclusions. The Inland site has a nice photo series of what they do. http://www.inlandrv.com/articles/wheel-balancing/
Old 03-28-2005, 12:06 PM   #5
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
OUCH!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-28-2005, 12:25 PM   #6
Images: 59
Yeah, Andy has a great setup to balance the whole deal. That's the right way to do it, if you live within striking distance.
If you live elsewhere, you need to find someone who has the same or similar equipment. The old 'spin balance, on the car' method is good also, but finding anyone who still does it is tough.
Or you can balance the hub/drum separately, which is what I do. Then any tire dealer can balance the wheel and tire. If both parts are balanced, the combination will be balanced.
But since Airstream spends millions on R&D and Quality Assurance, why should we do more than they do?
Old 03-28-2005, 03:34 PM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
You know, I had thought of going the center balancer way.....someone on this forum had posted them and they seemed like a good way to go.
I had a rim burn out like that. I think the dude that fixed my brakes on my car added a bit of heat to the frozen bolts. The rims were 25 years old, and I was lucky, drove it 325 miles home at speeds of 70 MPH and it died after a trip to of all places McDonald's for lunch one day.
Old 03-28-2005, 03:35 PM   #8
Aluminut
2004 25' Safari
. , Illinois
I found the link to the place I was thinking about....here it is:
http://www.centramatic.com/FAQ/faq.php
Old 03-29-2005, 09:26 AM   #9
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Centramatics
I am completely satisfied with the results of my Centramatic balancers. Since putting them on, there is no evicence of vibration in the trailer (no black marks in refrigerator, etc.) and my tires are holding up well.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 04-19-2005, 11:41 PM   #10
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
The "Line-Up Shop" here in Portland balances tires on the car still. FYI
C Johnson is offline   Reply With Quote
Old 04-20-2005, 05:57 AM   #11
markjoandall's Avatar
2001 30' Excella
Bedford , New Hampshire
centramatic
Like John in the above post, I use the Centramatic. However I went one step further, I had my hub and wheel assemblies spin balanced with my local mechanic and use the centramatics also. Last year we took an 11,000 mile trip and all worked very well.
The hubs that come from the factory were extremely out of balance. I had one or two hubs that were almost 6oz out of balance. This was before the rims and tires were mounted on the hubs.
Mark
-Life is a journey, not a destination.
Aerosmith
markjoandall is offline   Reply With Quote
Old 04-20-2005, 02:23 PM   #12
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
John, I just got off the phone with them. They recommended 800-810 model. Is this what you purchased for your trailer?
Centramatic
Apparently I have two dealers in St. Louis handling these. I'm sort of feeling that I might be better off to put these on myself rather than bring the trailer down to someone who really is in the business of handling big trucks. Did you order from them directly or did you go through a local dealer?
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-20-2005, 02:31 PM   #13
Pahaska's Avatar
Hays County , Texas
Centramatic
Jack
I ordered mine through Freightliner of Texas, but I had them put on by the local rural tire store. Actually, they removed each wheel in turn, I placed the balancer on in the correct orientation (ring out), and they reinstalled the wheel. It took about 20 minutes all told. I insisted on being there when they jacked the trailer to show them the jack points.
Oh yes, it was the 800 series, 6-lug model. The only one that fits our hubs.
John W. Irwin
WBCCI #9632
Old 04-20-2005, 03:01 PM   #14
jcanavera's Avatar
Fenton , Missouri
Images: 143
Am I right to assume that the price on the link was the price for 4 or is it per pair?
I'm still trying to keep the kitchen drawers shut when traveling. The dealer for the second time made adjustments. Looks like 2 drawers still slide open when traveling. I'm thinking that this might help.
Jack
Jack Canavera
STL Mo.
AIR #56
Suburban Furnace recall !!! NewStreamer Furnaces, Heaters, Fireplaces & Air Conditioning 34 11-26-2015 03:29 PM
Suburban Brake Recall davidz71 Our Community 0 03-12-2005 08:52 PM
Recall notice~ 53flyingcloud LP Gas, Piping, Tanks & Regulators 1 01-02-2005 06:51 AM
Grand Hall Ent. gas regulator recall 53flyingcloud LP Gas, Piping, Tanks & Regulators 0 12-23-2002 07:29 AM
Norcold g/e Refrigerator Recall FLguy8 Refrigerators 1 12-06-2002 12:58 PM
