Old 06-23-2016, 04:54 PM   #1
Grey Goose
2011 25' FB Flying Cloud
San Clemente , California
Rear tire wear
I've noticed the rear tires on my 2011 25' FC are showing slightly more wear compared to the front. Both sides show the same amount of wear. Also the outside of all tires show slightly more wear than the inside. Is this normal or is there a problem with weight distribution? I'm running an Equalizer WD hitch. Is it OK to rotate tires?
Ktholin is offline   Reply With Quote
Old 06-23-2016, 05:17 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Ware on both outer edges of a tire indicate under inflation. Have you ever weighed the trailer and used the inflation charts to determine the correct pressure?
Ware on one side of a tire may indicate axle misalignment. i use an 8 ft florescent light bulb across the center line of the tires. The bulb should touch all surfaces. Any gap on to one of the tire edges indicates the misalignment.
2004 Excursion 4x4
Old 06-23-2016, 05:27 PM   #3
1991 25' Excella
Stanfield , Oregon
Everything HowieE said is spot on. Id take it to a semi trailer shop and have the alignment checked.
SpletKay06 is offline   Reply With Quote
Old 06-23-2016, 08:33 PM   #4
Grey Goose
I read somewhere that there should be a slight toe in of the wheels to improve tracking. In this case, a straight edge would not contact all sides of the tires.
More Tire Wear - Front or Rear? Ag&Au Tires 3 01-13-2014 05:21 PM
Uneven tire wear..Yikes!! daydreamer36535 Tires 18 07-09-2007 10:17 AM
Outrigger wear to tire contact Johndigbydog Tires 10 01-20-2006 10:03 PM
Dramatically different tire wear Nicksut Tires 5 10-21-2005 12:41 PM
Un-even tire wear Deputych Tires 5 05-15-2003 12:23 PM
