Old 09-25-2006, 12:29 AM   #1
2007 25' Safari FB SE
Suburbia , Sunny So Cal
I wanna go faster than 62 m.p.h.!!!
No, I'm not a speed junkie. I've been going to Kingman Arizona and if any of you have ever driven I 40 from Barstow East you know the average speed is 75mph. When you get into Az the speed limit is 75m.p.h. for ALL vehicles. At 62 m.p.h. I am a rolling roadblock and have had more than one tractor trailer realize real late in the game that I was going a lot slower than he was. I'd like to remove some of this excitment from my life and go closer to the flow of traffic. Is ther a 15in tire that I can put on the A/S that is safe/rated for cruising at 70 through the desert in the summer?
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 09-25-2006, 05:29 AM   #2
1984 31' Excella
Norfolk , Virginia
Images: 11
Tires....Tires....Tires
75 MPH towing a travel trailer is a bit much in my opionion, that being said running 10 MPH below the traffic flow is equally dangerious (if the speed limit is 75 MPH every one is running 80 MPH minimum). Earlier this spring an older couple was involved in a serious accident (both are ok now I understand) and they were running the speed limit and were passed by a semi that set into motion a chain of events that lead to the accident.
To the best of my knowledge, there are no ST or LT 15 load range D rated at 99 MPH or above. That is not to say there isn't any, I'm not aware of any(the Cooper Custom Trailer Plus has been discontinued).
That is why I went to the LT225/75R16 LRD Goodrich Commercial T/A.
Beginner
Beginner is offline   Reply With Quote
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
spare tire? Chas Tires 14 07-04-2005 07:09 PM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 08:47 PM
Tire opinion Dbraw Tires 12 11-25-2002 07:39 AM
Tire code info FrankR Tires 1 05-20-2002 09:18 AM
