Old 09-08-2013, 05:47 PM   #1
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Radial vs. bias
I can probably answer my own question , but, how much smoother ride do radial tires have over bias ply on an airstream ( 1965 overlander)?
Cochese is offline   Reply With Quote
Old 09-08-2013, 08:02 PM   #2
mapleton , Utah
Oh boy, a tire question
the only thing we like better is a hitch question!
You will get a lot of differing opinions on this and other qualities including ST/LT, running temps and blowouts
lots of other threads on this, do some searching and LOTS of reading
tim
rumrunner is offline   Reply With Quote
Old 09-09-2013, 05:44 AM   #3
LFC
Memphis , Tennessee
I doubt the trailer will know the difference...
LFC is offline   Reply With Quote
Old 09-09-2013, 12:53 PM   #4
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Probably have better luck finding a radial tire if you need one when on the road than an old bias ply tire.
Old 09-09-2013, 01:00 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Bias ply tires have a smoother ride. The need for more effective suspension designs was one of the main barriers to the adoption of radial tires in the U.S. in the late 1960s and early 1970s.
Old 09-09-2013, 08:46 PM   #6
mapleton , Utah
I actually ordered my tires and wheels today. 225/75b15 8 ply bias.
went to 4 different tire and trailer stores for quotes and every one had the bias plys in stock, had to order the rims I really expected the reverse. (BTW not one of them stocked or recommended GYM's).
The selling point for me was the fact that I still have 40 year old 6.70x15 bias plys on split rims on my 55fc and it was towed from Oregon on them 3 years ago. Plus if they fail they just split and go flat, don't go through the floor of your trailer like a buzz saw like radials can.
just my 2 cents
tim
Old 09-09-2013, 09:01 PM   #7
thomdial's Avatar
1979 23' Safari
, Ohio
Good Choice
I went through the same dilemma about a year ago. Bias vs. radial. I heard a lot about radials riding smoother, but the whole notion of having a blowout (which happens all the time) and causing major damage made it an easier decision.
thom
thomdial is offline   Reply With Quote
Old 09-10-2013, 11:20 AM   #8
1981 31' Excella II
New Market , Alabama
If you run trailer tires you are probably better off with bias ply. I run car/truck radials and don't expect to have any problems with blowouts. Radials have much better traction than bias ply tires because they have a wider contact patch. They also tend to have less problems with getting too hot and they have lower rolling resistance. Radials have a much more cushy ride than bias ply tires. My impression of trailer tires is that they are a light weight car tire with way too much pressure (to handle higher loads) in them so when they blow it is ugly.
Perry
« Tires | Top | Wheel Chocks »
