Originally Posted by Tireman9
Have to wonder if your failure was a Run Low Flex failure
or a Tread Separation like this
Term "Blowout" is used by many to describe any failure. TPMS will not warn of an impending Tread/Belt separation but a functioning TPMS will provide warning of air loss which is their intended purpose.
If you don't know the real root cause for the failure how do you know the action you took will prevent another failure?
RE your experience with Michelin tire. If you didn't have a TPMS and the air leak continued and you had a Run Low Flex Failure i.e. "Blowout" would you have then considered the Michelin "defective".
After all this is the logic that many seem to use.
Fireman--very good points!
Our last trailer tire "failure" occurred when my wife, about to pull out of a gas station, noticed "something weird in the tire" in her side view. I hit out to check it, and it was a new 10" long bubble on the sidewall near the tread.
We check cold tire pressure every morning, and that morning was no exception. We have NEVER rubbed a sidewalk against a curb--we are both super attentive about it.
Because we caught it early, there was no damage. That tire was 6 months old and had about 6000 miles on it. The tread looked new. We checked the pressure when it was removed and the tire was not under inflated.
After the spare was put in place, we were fortunate to only be twenty minutes from Les Schwab, who replaced the tire and another one of the same young vintage that they didn't like the looks of. These wee part of a full new set of Towmarks from Schwab after we had w complete tread separation on a GYM the previous season, and another that was showing early bubble in the sidewall.
We now have a full set of Michelun's in 16" wheels, and recently added the TireMinder 66 system for peace of mind. Because our TV has duallies, it did not come with TPMS, so we have a ten sensor attempt in place.
The TireMinder has been working well, but has its own challenges because the dually valve extensions need to be under full air pressure for the sensors to work. This makes fir many potential leak points, each of which TireMinder has caught in time.
Since we replaced our original tires at 40K miles with new ones on the TV, we changed to Aneruca's Tires metal stems, and the nightmare started. Even though we carefully checked each component before installation (by submerging each tire/she'll/valve/extension/sensor in water tank), several have subsequently developed leaks after just sitting in the driveway..
After much research, I have just purchased Slrinter wheel specific metal valves which are supposed to make a better deal than the ones America's Tire has in stock. I will take my fourth trip to the tire shop tomorriw and we will start again from scratch.
So TPMS? I guess at this point I'd call it a mixed blessing. If we do get it right, it will be wonderful.
Oh--zero problems with the sensors in the Sendels/Michelins on the Airstream that are part of the same system!
