Old 09-07-2016, 05:18 AM   #15
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Airing Down
Originally Posted by Tireman9 View Post
Wondering why one would need to carry an air compressor around.
I use the air compressor for airing-up after taking the Jeep Wrangler TV off road with aired-down tires.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 09-07-2016, 10:47 AM   #16
Longboard6's Avatar
2015 23' FB Flying Cloud
Sacramento , California
Thanks, all. I made the decision to go with the Viair 450 P. The 13 lb weight and quick top off rate seems like what I want. I'll let you know how it goes. I'll be topping off at my storage facility and thereafter when needed. I'm tired of looking for stations I can get into with working compressors that are free. I've probably spent the cost of the Viair in quarters.
Longboard6 is offline   Reply With Quote
Old 09-08-2016, 08:42 AM   #17
Ravenna , Ohio
Good answer and good for you. Some seem to forget to re-inflate their tires after going off road.
Tireman9 is offline   Reply With Quote
Old 09-24-2016, 09:00 PM   #18
Longboard6's Avatar
Follow up....I bought the Viair 450 P and could not be happier. I topped off all 8 tires with ease and quite quietly. At 13#s
I will never travel without it.
Old 09-25-2016, 06:07 AM   #19
Long Island , New York
Thanks for the follow up, ordering today.
Old 09-26-2016, 03:06 PM   #20
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
Just to add, I got a Senco PC1010 1-Horsepower Peak, 1/2 hp running 1-Gallon Compressor https://www.amazon.com/dp/B0000AQK78..._GYy6xbCXW49WP
Am pretty happy with it. Heavier than the 12V pumps but works very well on the road. I used my AS's inverter to power the other day when topping up tires and it worked well.
Southern Belle
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 09-26-2016, 03:35 PM   #21
2016 23' International
Salem , Oregon
Here is another option. Looks like the Viar but from from Harbor Freight 64.99. Probably made in the same factory.
Make your own decision but $65.00 V 300.00
Dave
NoResults is offline   Reply With Quote
Old 09-28-2016, 10:13 AM   #22
I assume you mean this one?
http://www.harborfreight.com/12volt-...sor-69285.html
IMO the specs are probably different from the Viarr 450, but they are not spelled out in detail. Some of the reviews suggest that this unit does not have a 100% duty cycle, and that the thermal overload protection goes off somewhat easily.
Good price though, with many positive reviews.
Old 10-05-2016, 02:10 PM   #23
interstateflyer's Avatar
Los Osos , California
Has anyone found a lightweight portable compressor that runs runs on AC? From what I've seen AC compressors generally have a higher max psi rating.
My truck has an AC outlet as does my 2017 25FB (1000 watt inverter), so I'm covered on the road and in RV parks/campgrounds with electrical hookups. I'd rather not have to deal with DC alligator clips on the trailer or truck battery.
Also, 2017 Airstream Internationals don't have cigarette lighter style DC ports so the truck would be the only DC source.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 10-06-2016, 06:01 AM   #24
Navarre , Florida
Post #20
Southern Belle
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 9 10-02-2013 10:55 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
