Old 08-27-2018, 09:36 AM   #1
2016 30' International
Florence , Alabama
Problems with TST TMPS mount
I haven't seen this posted on the forum - anyone else with the TST TMPS units have problems with their mount not holding position? My suction mount would routinely get loose and begin to aim down; or even start turning side to side on it's own. As I retightened the joints over and over the plastic knobs finally just broke off!
I called TST and had to buy a replacement for $10, and it does the same thing right out of the box.
Right now my plan is to assemble a custom RAM mount but cutting the broken mounts plate off and gluing it to a RAM diamond plate.
Anyone else run into this?
joshjack is online now   Reply With Quote
Old 08-27-2018, 09:59 AM   #2
2016 26' Flying Cloud
Southlake , Texas
Mine holds its position but I did have one of the plastic knobs break off. I mount mine in the lower left corner of the windshield and the display is actually resting on dash. I did this after the suction cup let go a couple of times. Now it can’t startle me when it lets go. It also keeps the mount from tilting down.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Bgibbs is offline   Reply With Quote
Old 08-27-2018, 03:58 PM   #3
Florence , Alabama
Originally Posted by Bgibbs View Post
Mine holds its position but I did have one of the plastic knobs break off. I mount mine in the lower left corner of the windshield and the display is actually resting on dash. I did this after the suction cup let go a couple of times. Now it canít startle me when it lets go. It also keeps the mount from tilting down.
I have a power hardwired coming down from my rear view mirror so I keep it mounted high next to the mirror.
Old 08-27-2018, 04:49 PM   #4
Mollysdad's Avatar
I didn't want a suction mount so I devised a Ram mount from the get go.
I use a Ram cupholder mount, to a medium Ram arm, to something called a 4 hole I-grip mount or a 4 hole AMPS mount, depending where you get it. It has a 1" Ram ball and a plate that looks just like the one from the suction cup.
BUT, even though the 4 hole I-grip snaps into the four holes on the back of the TST monitor (I have the color one) you can't lock it in place like it should. So I spent a few minutes with a file and trimmed the prongs down.
BTW, the ball that comes with the TST appears to be a GoPro mount, but it's not either. The screw is different and doesn't mate with any Ram or GoPro stuff.
I already have a GPS on the dash, so the cup holder seemed like a good idea. The monitor is so light, the cup holder doesn't move at all.
I-grip:
Mollysdad is online now   Reply With Quote
Old 08-27-2018, 04:58 PM   #5
Mollysdad's Avatar
In reading the manual, sorry, man card in jeopardy; it said not to keep the monitor plugged in. The internal battery is supposed to last 5-7 DAYS, and leaving the mini USB plugged in will overcharge the battery.
(Mine is the TST Color monitor if that matters)
2017 Flying Cloud 30 ' Hub Mount / Stud Mount question twolanehwy General Repair Forum 3 09-24-2017 03:03 PM
Stud Mount TV Mount on Shower Wall??? BASE729 Audio, Video & TV 0 11-29-2014 05:31 PM
HawksHead TMPS valve choice input needed bonginator Tires 6 09-03-2012 07:18 PM
Flush Mount or Surface Mount Zac&Kristin Water Heaters, Filters & Pumps 10 01-13-2008 07:59 PM
Problems Problems Problems pjzuk General Motorhome Topics 6 09-03-2007 08:25 AM
