Old 06-01-2004, 07:40 PM   #15
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
The reason
The charts are produced to show the minimum pressure for varying loads. You also get a softer, quieter ride at the lower pressures, but the lower pressure can lead to other issues such as the infamous Firestone/Ford fiasco. Lower pressures allow the sidewalls to flex more and that also leads to a bit more heating and wear, but the tires should last the typical mileage as long as never underinflated. Running at max inflation results in longer treadlife, slightly better gas mileage at the expense of some comfort.
david
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
