Old 08-04-2006, 01:06 PM   #1
frederic.c01's Avatar
1973 23' Safari
amberieu en bugey France , france
Images: 69
Send a message via MSN to frederic.c01
pressure tires for safari
hi all
which is the pressure for the tires of a safari 1973.it is one two axles.thank's for your concils.
fred
If you need something, call me. I will say to you how you to pass some.
http://airstream.blog.expedia.fr/
frederic.c01 is offline   Reply With Quote
Old 08-04-2006, 01:14 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Originally Posted by frederic.c01
hi all
fred
Fred,
It really depends on the type of tires you are running.
Whatever you do, do not exceed the max pressure that is printed in the rubber at the sidewall ( at least it should be).
Maybe you can post pictures or describe your tires, so we can help you better.
Uwe
www.area63productions.com
Old 08-04-2006, 01:26 PM   #3
1973 23' Safari
Images: 69
hi uwe
i running with goodyear only trailer service st 225/75 r15 2150 lbs max load per tire.
i think 50 psi is good.
Old 08-04-2006, 01:31 PM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
hi uwe
That would be a load range C Marathon tire which has a max psi of 50. I have mine inflated to 50 spi cold before traveling.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-04-2006, 01:40 PM   #5
1973 23' Safari
Images: 69
hi davdz71
I would inflate them to 50 psi before travelling thank you. I will make 1000 miles for the holidays.
Old 08-04-2006, 01:54 PM   #6
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
hi uwe
That's a load range C tire? There should be a max pressure rating on teh sidewall. It is probably 50lbs, as you indicated. My LR C tires on the Suburban have a max pressure of 50lbs.
Uwe
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Tire Pressure TBYRNE Tires 11 08-09-2002 09:04 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
