Old 07-07-2007, 04:55 PM   #1
Bing-Bing's Avatar
1994 34' Excella
Fulltiming , Out West
Portable air compresser
I want to get a small portable air compressor to keep the trailer tires aired up. What would you all recommed and where would I get one. Thanks
Bing-Bing is offline   Reply With Quote
Old 07-07-2007, 05:03 PM   #2
Central , Mississippi
If your into DIY stuff, some mid to late 80's highline GM autos had self leveling rear suspension that included a neat little heavy duty 12 v air compressor. Toss in a old freon tank and a 100 psi switch and bingo, onboard air. Mke sure and use 10 gauge or larger cable, it takes a lot of grunt to get 100 psi so the current draw can be quite high.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-07-2007, 05:04 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Don't buy the $9.99 one on e bay they will not do th job as they claim.
If you are a junk yard type you can get a 12 volt unit of anything that had air ride and use it. Lincolns and some Chrysler product for a start.
2004 Excursion 4x4
Old 07-07-2007, 05:32 PM   #4
_
hi bing-bing
search the terms 'air compressor' and 12v or 110 ac for variety...
or just go browse in the "tire" forums...
here are some threads with options...
http://www.airforums.com/forums/f438...ion-18687.html
http://www.airforums.com/forums/f438...res-30644.html
http://www.airforums.com/forums/f438...ons-23250.html
cheers
2air'
Old 07-07-2007, 06:13 PM   #5
cammur's Avatar
Roseville , California
I have the Husky but I don't take it trailering. See here for what I bought: http://www.airforums.com/forums/f438...tml#post356815
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 07-07-2007, 06:16 PM   #6
Images: 59
I got one at Sears for about $20. It's a Black&Decker. Runs 120Vac or 12VDC, and runs (they say) up to 160 psi.
What I like is the size (as small as a breadbox), all the hoses and cables for both 120v and 12v fold into a compartment under the cover, it's light, and it has a large gauge you can set.
I haven't field tested it yet, but it ran ok in the shop. Anything this size is gonna take a long time to fill a flat.
ID:	40727   Click image for larger version
Old 07-07-2007, 06:46 PM   #7
Bing-Bing's Avatar
1994 34' Excella
Thank you guys for the suggestions. I like the looks of the husky so I'll check around tomorrow to see where I can pick one up. You all are great to get back to me so quickly. I appreciate it!......Bing
Old 07-10-2007, 09:52 PM   #8
Bing-Bing's Avatar
1994 34' Excella
I bought the Husky portable system that will jump start my truck,air up my tires and has both an a/c and d/c outlet..All for 90 bucks....This way my wife can run her hair curler while watching me air up the tires.
Old 07-10-2007, 10:11 PM   #9
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Our 59 SOTR has one
We have an Air compressor on board - 12v too - for the water pressure system. Now, to figure out a way to tap into it for access to be able to fill the tires if needed. Hmm... I'll have to work on that.
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Rear Air bags PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 24 11-12-2007 06:02 PM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 07:45 AM
air horns uncleneal Airstream Motorhome Forums 1 08-16-2002 07:22 AM
Air streams in New York area?!? mitchm71 Our Community 0 07-25-2002 09:33 AM
