Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
View Poll Results: poll : Do you refill your tires with pure NITROGEN ( N ) ?
YES and I'm very satisfied ! 3 10.71%
YES but I'm not satisfied at all, no avantage really ! 0 0%
NO, only "fresh" air, thank you ! 14 50.00%
WHAT, I did'nt know we can refill with pure NITROGEN 11 39.29%
Voters: 28. You may not vote on this poll
Old 11-10-2003, 01:10 PM   #15
markdoane
Profile:  , Minnesota
Images: 59
Pure Nitrogen
Bruno:
Please do not take offence. I am sure Sander17 was making a little American humor. In the USA we often joke with each other in this manner. Same with my response to Sander, was an attempt to upstage his humor with a more ridiculous addition to his proposal.
If you make a trip to the Bordeaux region, I have a friend there with a vineyard who drives around France in a Cadillac STS (with Minnesota licence plates), and has a dog named Fluffy. I helped him pick his grapes a few years ago. He would love to see your Aristream.
Old 11-10-2003, 03:20 PM   #16
sander17
sander17's Avatar
Profile:  1996 28' Excella
Okemos , Michigan
Images: 42
Bruno,
Please do not take offense. I don't care what hat you wear.
The point I was trying to make was that just because two events happen simultaneously, it does not necessarily mean that one causes the other. In your previous post, it appeared that your filling of tires with nitrogen caused the uneventful trip. All I was implying was that you probably would have had the same result using plain old compressed air. Did you have a previous trip with lots of tire problems from using air? If so, we should investigate why such problems are not seen on this side of the Atlantic.
Once again, I am sorry if you took offense to my response. I guess humor is difficult to translate at times.
sander17 is offline   Reply With Quote
Old 11-10-2003, 03:39 PM   #17
brunoffrance
Very american 4 a french
brunoffrance's Avatar
Profile:  1971 27' Overlander
DUNKERQUE / FRANCE , Nord
Images: 68
OK; Thank you for your courtesy So...
I let the nitrogen in my tires
Best regards from FRANCE;
Bruno;
Name:	me & pu.jpg
My blog:The american dream in FRANCE:
My pictures in high quality: Pictures on FLICKR:
My videos are on YOU TUBE
My AIRSTREAMLIFE ning
brunoffrance is offline   Reply With Quote
Old 11-10-2003, 03:46 PM   #18
markdoane
Images: 59
Pure Argon
Doesn't anyone want to discuss using Argon as a tire filling gas?
Old 11-10-2003, 03:49 PM   #19
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Re: Pure Argon
I'll Bite
Would enough static from the dry roads make your tires glow??? Too bad they would glow green? Blue would be the rage fer sure!
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 11-10-2003, 03:52 PM   #20
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 153
Helium
Think about the arguements of "Can I pull a 34' classic with helium filled tires with my '98 Kia?".
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 11-10-2003, 06:36 PM   #21
markdoane
Images: 59
Argon?
theNewkid:
Actually, I hadn't thot of the glow factor. I was thinking that argon has lower thermal conductivity and diffusivity than nitrogen.
Old 11-10-2003, 07:17 PM   #22
overlander63
Rivet Masher
overlander63's Avatar
Profile:  L.A., Dammit , California
Okay, after reading the posts, I have this to add (or detract):
Farm tractor tires are filled with salt water for increased tire weight and traction. If you don't put the salt in, the water will freeze in place in cold weather, making for a bizzare ride.
Europe has relatively high speed limits, compared with ours. If you travel on the Autobahn, for example, with no speed limits in most places, you will most likely be traveling at speeds that would benefit from the Nitrogen. Most freeways here have a limit of 70 or so, not really high enough to warrant the straight gas.
As far as I know, Nitrogen will not cause any problems with your tires, if you want to use it, other than the obvious issue of transporting a full cylinder of the stuff on the highway .
Old 11-10-2003, 11:14 PM   #23
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Nitrogen's main advantage is that it does not expand at the temperature normally encountered in automotive and trailer tires. Airline jet tires are filled with nitrogen for this very reason, they run about 200lbs of pressure, and tire pressure fluctuations at these pressures and temperatures encountered in aviation are immense with regular air.
So, in race cars, or fast cars in Europe, nitrogen in the tires makes perfect sense to me. I uses to get my tires so hot, you would NOT want to touch the sidewalls for long, definitely uncomfortable.
If youfill your tires with nitrogen, the air pressure increase from this heat is a non-event. Nitrogen will start to expand at much higher temps as are practical in automotive/trailer use.
I do not think it's a necessity for US street use.
My friend who races carts use nitrogen in the little gumball tires, they are very small and get very hot, so pressures would be very inconsistent with regular air.
Uwe
Old 11-10-2003, 11:18 PM   #24
Tin Hut
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
gas
I don't know about nitrogen in my tires but sometimes the inside of my car seems to fill with methane.
"would you rather have a mansion full of money or a trailer full of love?"
Warning: (20%)
Tin Hut is offline   Reply With Quote
Old 11-11-2003, 12:36 AM   #25
biggerbadbrad
Profile:
I prefer to fill my tires with hydrogen. Well, until I hit that last pot hole, that is.
bbb
biggerbadbrad is offline   Reply With Quote
Old 11-11-2003, 08:27 AM   #26
sander17
sander17's Avatar
Okemos , Michigan
Images: 42
Smile Thermal expansion of Nitrogen gas
Sorry Uwe,
Someone is misleading you.
"The coefficient of volume expansion for a gas under constant pressure is nearly the same for all gases and temperatures and is equal to 0.00367 for 1 deg C." from
the Handbook of Chemistry and Physics, 59th ed. pg F-122.
Also known as the ideal gas law: PV=nRT
( it even applies to the expansion of methane inside the driver's compartment)
Old 11-11-2003, 08:43 AM   #27
qqq
qqq's Avatar
Profile:
Sander,
Hart
qqq is offline   Reply With Quote
Old 11-11-2003, 09:11 AM   #28
87MH
87MH's Avatar
Images: 153
The Prize
Sander17
For correctly answering the question you win a genuine "AIRSTREAM" Embossed Plastic Pocket Pencil Protector with a picture of an Airstream being pulled by a bicycle.
Now, for the bonus question, .....
What would be the pressure in the bicycle's tires be if all of the heat generated by braking is transmitted to the tires after negotiating Wolf Creek Pass and the Airstream and bicycle are safely brought to a stop in downtown Pagosa Springs?
Note: No mass change from the bicyclist is assumed, as modern fabrics will contain all bodily fluids and solids expelled as the cyclist negotiates the first switchback.
Dennis
WBCCI # 1113
AirForums #1737
Tires Causing Sway? Pick Tires 14 12-03-2006 05:38 PM
Tires & Wheels for a '66 Overlander 66Overlander Tires 16 05-29-2004 12:20 AM
Kelly Tires for MH....any thoughts? 1985air345 Airstream Motorhome Forums 6 02-22-2004 10:05 AM
Questions about trailer tires... cactushead Tires 2 10-22-2003 06:58 PM
tires? trailer will sit after move goodgrey Tires 4 12-06-2002 03:10 PM
