Old 06-09-2013, 10:16 AM   #15
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
I've been running BF Goodrich P235/75 R15 108T XL on my 27FB like Perry for year and a half. Probably 4-5000 miles on them. They ride smoother (no more popped rivets and stuff seems to stay put in the trailer). 2183 LBS LOAD derated to 1985lb x 4 is still 7940lb and the trailer is rated at 7500. At the scales fully loaded we run about 6000 lb on the trailer tires so we are well within limits. Watching the TPMs the pressure usually varies about 8Lbs between 50 degrees (cold) and 90 degrees (operating on hot pavement). They don't vary in pressure or temps more than the TV tires while running. The rear TV tires get hotter and have the largest pressure rise. I changed the GYM's out based on the documented damage here in the forums. Whether the GYMs are good or not I can't say but they sure do a lot of damage when they fail spectacularly. -Brad
ID:	187805   Click image for larger version
SuperTrouper is offline   Reply With Quote
Old 06-09-2013, 10:33 AM   #16
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
"2183 LBS LOAD derated to 1985lb "
Again-WHY are you de-rating the tire?? It does NOT know it is on a trailer and has, I believe, an "S" speed rating which is over 100mph.
Please explain the de-rate premise.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 06-09-2013, 11:00 AM   #17
Sure, Article VI Section D:
http://www.nhtsa.gov/cars/rules/ruli...re/Final/#ref4
"For the final rule, the agency has also decided to retain the de-rating factor of 1.10 for P-metric tires used on non-passenger car vehicles. For non-passenger car vehicles equipped with P-metric tires, the vehicle normal load shall be not greater than the derated value of 94% of the tire load rating at the vehicle's placard pressure. This de-rating provides a greater load reserve when these tires are installed on vehicles other than passenger cars. For the first time, this final rule requires light trucks to have a specified tire reserve, the same as for passenger cars, under normal loading conditions."
Old 06-09-2013, 11:28 AM   #18
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
After months of reading tire threads and asking questions, I just ordered 5 Michelin P235 75 15 XL tires for my 6300# Safari 25. Good bye to ST tires.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 06-09-2013, 01:07 PM   #19
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
DOT 49 CFR Part 571 Docket No. NHTSA-03-15400 RIN 2127-AI54
Thanks, had not seen that before. Now I understand-more government regulation. Everything that was postulated in there is a severe case example. But, it is what it is, thanks for the info.
I will continue to run my "P" metric XL's
Bruce
Old 06-09-2013, 01:28 PM   #20
1981 31' Excella II
New Market , Alabama
99% of all passenger tire failures are caused by not checking air pressure and not by overloading. I see it everyday on the way to work. Someone driving 90 with one or more tires that probably have 10psi in them. Or the ones that run temporary spares as full time tires. This is why many new cars have the pressure monitors on them. It is not because it is necessary it is because people are lazy and ignorant and don't check tire pressures. You can't legislate this.
Perry
Old 06-09-2013, 01:45 PM   #21
Hodum's Avatar
1995 34' Excella
Corinth , Mississippi
Originally Posted by CapriRacer View Post
Because at 80 psi, the load carrying capacity of the ST tire was 2830#, while the P type tire is 1985#. That's operating the tire at 143% of its rated capacity.
You need to seriously rethink this.
Somebody is not adding correctly. Even derated to 1,985# I have a 2,710# safety margin before reaching the rated capacity of the Michelins. My trailer, loaded, will weigh about 10,000#. Take 800# for tongue weight leaves 9,200#. Six tires derated to 1985# =11,910# My tires will never reach anywhere near there rated load carrying capacity. The ride difference is great. I have run Michelins on all of my cars and trucks for years, and though I know there are other great tires I dare not change because of the quality of ride and longevity of the Michelins.
Why settle for anything less?
1995 34ft Classic Excella 1000
2012 Kings Ranch F-250 FX-4, 6.7 diesel, 6 speed auto trans.
TAC # MS-8
Hodum is offline   Reply With Quote
Old 06-09-2013, 01:57 PM   #22
Hodum's Avatar
1995 34' Excella
I think that you are going to be one happy camper the first time you pull your 6,300# airstream on these super smooth, sidewall flexing, great handling, 7,940# rated Michelins.
TAC # MS-8
Old 06-09-2013, 08:50 PM   #23
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
I know when I put them on my 1997 31' Excella wide body, it made all the difference in the ride. Oh, did I mention this was AFTER I had a Carlisle ST Load Range E tire blow catastrophically and do $7000.00 yes $7000.00 worth of damage to the above mentioned trailer.
Bruce
Old 06-09-2013, 08:54 PM   #24
BlackAces's Avatar
Taylors , South Carolina
Here is what the regulation really says. It's often misunderstood. This is the most current and official document.
Tire selection and rims and motor home/recreation vehicle trailer load carrying capacity information for motor vehicles with a GVWR of 4,536 kilograms (10,000 pounds) or less - Federal Motor Carrier Safety Administration
BlackAces
USN - RET - PDRL
DoD & SSA - RET
BlackAces is offline   Reply With Quote
Old 06-09-2013, 09:39 PM   #25
Originally Posted by BlackAces View Post
So 4.2.2.1 and 4.2.2.2 say P tires on trailer with no passengers max load divided by 1.1 or 2183lbs=1985lbs right?
Old 06-09-2013, 09:49 PM   #26
willapus's Avatar
Memphis , Tennessee
I stayed with an lt tire because of all the complaints with the g.y.m.'s, but scaled down closer to the original size for my TT, 7.00-15 load c to lt 225/75 r16. "P" tire load ratings are not equal to LT load ratings. The increased height of the center of gravity on trucks decrease the load capacities of P tires by about 10%. The p tires sidewalks aren't as rigid as the lt's. I'm hoping the new lt's on the TT and TV will help minimize the sway.
Will
'67 29' Streamline Empress
'05 Toyota Sequoia 4x4
'65 Buick Electra 225 convt.
willapus is offline   Reply With Quote
Old 06-09-2013, 09:49 PM   #27
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
That 1,985 pound load number is correct for the 15" Michelin tire in a derated application.
Old 06-10-2013, 05:10 AM   #28
CapriRacer
CapriRacer's Avatar
I'm in the , US
Actually, the derating of P metric tires for Light Truck, van, and trailer usage predates the government regulation by a decade. The government adopted the existing standard.
And to answer the question: The tire does indeed know it is on a trailer. It is being asked to do different things than if it was on a passenger car. (Ok, Ok! Tires are inanimate object and can't "know" anything. Nevertheless, trailer usage is different than usage on a passenger car. )
And lastly:
The tidbit of information was not part of this thread. So while I apologize for an un-necessary alarm, I was merely acting out of safety concerns.
CapriRacer is offline   Reply With Quote
Tow vehicle tires: Different tires for summer and winter? Jammer Tires 9 02-15-2012 03:03 PM
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
Wide White Wall Tires wasagachris Tires 14 08-04-2011 09:32 PM
Tires and Alignment Airstream12557 Land Yacht/Legacy Motorhomes 0 06-08-2011 05:04 AM
Towmaster Tires mshamilton Tires 0 05-08-2011 09:38 AM
