Old 02-17-2016, 08:23 PM   #1
1999 34' Excella
Cinnaminson , New Jersey
Optional 16" tire sizes for a 34'
Problem: my 34 has a Hensley I currently scrape the spring bars on the ground pulling out of my driveway. There's a slight incline. When the rear tires of my truck roll off the edge of the apron to the street I drag the bars for about 2-3 feet. I've been using wood in the street to help me clear. I had a new driveway and apron poured last year and I hate to damage any of it.
Trailer has steel 15's with 225/75/15's currently and they are listed as 28" tall. Only 4 year old E rated Carlisel tires in great shape but I want to put the rims on and want to improve the clearance issue at the same time. I don't need much but at the same time the more the merrier...
I already have a set of new aluminum 16" wheels, just need new rubber. So thinking of improving my clearance issue with larger tires. The standard 225/75/16 generally list at about 29.4" tall. This will help but only by about 3/4" of added height on the trailer.
So I've been looking at optional sizes.
215/85/16 (30.4" tall) or 235/85/16 (31.7" tall) the 235's will raise it by 2 full inches. Haven't decided on a brand or anything yet.
Curious if anyone is running anything larger than the standard 225/75/16 tire and how well they fit. Looking at my 34' I think the front axle is going to be the one that will be close. I may have to do some clearancing to make them fit. Anyone running larger tires on a 34? Got pics and comments?
excellaf350 is offline   Reply With Quote
Old 02-17-2016, 08:31 PM   #2
1994 34' Excella
Warren , Manitoba
What year is the trailer? I replaced the axles on my 1994, 34', and it is now about 3 inches higher than it was before replacement. Check to see if your axles are bad before anything else. You can go to Inland RV's site to find out more about checking the axles.
Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 02-18-2016, 03:20 AM   #3
1999 34' Excella
It's a 99. Honestly never thought about that. But my 29 did the same thing just not a bad.
I will def check it out but I'm fairly confident the axles at good.
I'm def gonna do this just curious if I'm the Guinea pig for it or not.
Old 02-18-2016, 01:40 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Correct trailer height and hitch height would be needed. Here is Airstream's data page for 1999 models. If your hitch ball is set to he correct height and the trailer is not level that may be an indication of axle issues.
http://www.airstream.com/wp-content/...b95610d786.pdf
>>>>>>>>>Action
Old 02-18-2016, 08:16 PM   #5
1999 34' Excella
I will definitely check. But my my scraping problems are because of the long long trailer and the angle of the driveway. The Hensley and spring bars hang several inches if not close to a foot below the hitch ball height. Doesn't leave much room for backing up an incline the crown of my street goes down while the driveway goes up. Just works out the rear tires of the truck are headed down the lowest part of the street while the trailer is headed up the steepest part at the same time.
I will most definitely check trailer height though.
Old 02-19-2016, 11:32 AM   #6
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Take the bars off before going up the incline, you will have better traction on your drive wheels...
Old 02-19-2016, 02:35 PM   #7
2014 28' Flying Cloud
Boca Raton , Florida
I mounted XPS 235/85R15 tires on my 2104 FC 28'. This was not intentional for I ordered them on-line at Tire Rack after seeing a special deal. These tires are almost 32" in diameter so they are much wider than the OEM GY 15". The rear tire had plenty of clearance but the front only had about one inch from the front wheel well. This was only after I trimmed a portion of the wheel well trim and bending back some metal that overextended into the well. I posted this issue AF and got a lot of advice from- It should be fine to replace with 225/75R16E. I spoke to a tech rep at Airstream and was told it will be fine for there is not forward movement of the tires- only up and down, But we decided to return the 235's and replace with 225's for peace of mind and since Tire Rack was willing to make the exchange within 30 days. Hope this helps.
Joohntooth is offline   Reply With Quote
Old 02-19-2016, 02:36 PM   #8
oops- I meant XPS 235/85R16E not 15,
Old 02-19-2016, 02:46 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
New axles... Far cheaper than new driveway
Yes, I did mine recently.. Same tires wheels. ProPrIde hitch.
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-20-2016, 07:03 AM   #10
1999 34' Excella
Yeah we were talking in your other post... So you did switch to the 225's but the 235's did fit. (With some trimming) my other option is the 215/85's. Still larger than at 30.4" but not quite at big as 32"... There should be no movement forward or backwards just Up and down, but there certainly could be side to side.... Ever watch a 34' on a tight turn? Woah there's just a little tire deflection on front and rear axles, lol.
Old 02-20-2016, 07:06 AM   #11
1999 34' Excella
New driveway is already done. And I could have bought another airstream for what I have in it. That's why I really don't want to scrape it.
So you did 235/85/16's?
Old 02-20-2016, 07:08 AM   #12
1999 34' Excella
Always an option I suppose. But taking the bars off is a real PITA and to do that every time I go in and out of my driveway would drive me insane!
If I put some wood at the end of the driveway in the street I can get out without scraping. It's tight but doesn't scrape. I'm ok with tight...
Old 02-20-2016, 07:14 AM   #13
1999 34' Excella
>>>>>>>>>Action
Took your advice and made some measurements yesterday. With hitch set at factory height I'm within 5/8" maybe 3/4" of level at the back of the trailer so, I'm gonna say axles are fine. Obviously what's in the trailer will affect that but it's in "winter mode" right now here up in the NE. Tanks empty and what not but several piles of camping gear that normally go in the truck are in there now.
Old 02-20-2016, 01:48 PM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Nope.. stayed with the 15" wheels... they are steel and in great shape..
The 16" will only give a a little height...
What worked for me was ramps I fabricated from 2x4 stacks, glued together..
Channing
WBCCI# 30676
Panel sizes, Minuet to "regular" Argosy Bex All Argosy Trailers 5 07-28-2014 06:11 AM
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
Spare Tire bracket optional? Jared129 Wheels, Hubs & Bearings 3 05-14-2008 09:38 AM
Is spare tire optional? AirHeadRik Tires 11 04-15-2007 04:17 PM
