Old 07-10-2010, 12:53 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Opinion Wanted - 205/75R15 Tires
Hey guys,
Just bought and mounted some Goodyear Marathon 205/75R15 (LR-C) tires for my dual axle, '58 Overlander. They sure seem small from what I'm used to (I have 225s on my 72 Sovereign) but these tires are sized correctly for a 4000lb Overlander with dual axles.
What do you guys think? Is it just me or do these tires seem smallish?
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-10-2010, 01:13 PM   #2
Originally Posted by mello mike View Post
Hey guys,
Mike.
The original tires were 700 x 15
That was changed to ST 225/75 R 15
I would suggest you use the same tire as you do on your newer model.
Old 07-10-2010, 04:17 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Originally Posted by Inland RV Center, In View Post
Mike.
Thanks Andy for responding. Well to satisfy my curiousity, I went back to Discount Tire to try mounting a 225/75R15 and they couldn't do it. The tire is too wide. So it looks like I'll be staying with the 205s.
1958 Overlander
4CU 1st VP
Old 07-10-2010, 05:38 PM   #4
Mike.
How about the wheels?
I'm sure they are not originals. That being the case, are they the correct wheels with "zero" offset?
Old 07-10-2010, 09:06 PM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Just for the record, the tires I replaced were Kelly-Springfields 6-70-15 LT (LR-C)
1958 Overlander
4CU 1st VP
Old 07-17-2010, 12:33 PM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Well, I ended up buying Yokohama 215/70R15 Light Truck tires. Oh, and they're radials not bias plys. She sits 2 inches higher now and looks much better. Next stop, Arizona Axles for new axles, leaf springs, and a hitch coupler. I'll also have them cut off the hydraulic brake cylinder, re-tap the tongue jack holes, and mount two new safety chains.
ID:	106941   Click image for larger version
ID:	106943   Click image for larger version
1958 Overlander
4CU 1st VP
Old 07-17-2010, 02:44 PM   #7
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Looks like your dog doesn't like the jack post.
The taller ties look great Mike. Glad you made the switch. Did you notice any difference in towing after switching to the Yokohama's?
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 07-17-2010, 05:43 PM   #8
r carl's Avatar
Lin , Ne
FF
I thing its the wheel on the bottom of the jack he is aiming for. He will eventually get to the 4 new ones soon enough.
Old 07-17-2010, 08:15 PM   #9
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
FF
Thanks, Brad. I didn't really notice a difference towing since Discount Tire is less than a mile from my house. The real test will be when I get on the I-17 next weekend when I take her down to Arizona Axle.
I was hoping nobody would notice Pepe spraying the jack. And yes, he got one of the Yokohamas, too. Dogs!
1958 Overlander
4CU 1st VP
7.00x15 replacement; 225 vs 205 Marcello Tires 5 06-19-2010 04:16 PM
Opinion Wanted - Is this trim color a good match? mello mike Clearcoat, Exterior Paint & Trim 10 04-25-2010 10:48 PM
Fitting LT235/75R15 LR C on our '71 Tradewind... barts Tires 7 04-18-2010 06:17 PM
225/75R15 Goodyear Marathons do not fit. Silver 81 Tires 13 11-07-2009 11:00 AM
Michelin 235/75R15 LTX M/S vs Marathon ST225/75r15 EXCEL88 Tires 3 06-16-2008 07:41 PM
