Old 11-10-2015, 05:09 PM   #1
Tincampers's Avatar
Sneedville , Tennessee
One tire wearing faster than other three
Just noticed that the curb side front tire is wearing faster than the other three. The wear is on the outside tread area. The other three tires are fine. Tire pressure is checked regularly and the trailer is towed level. Any ideas as to why this is happening?
Tincampers is offline   Reply With Quote
Old 11-10-2015, 05:48 PM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
1 tire wearing faster than other three
That wheel is most likely out of line. Find a good alignment shop and get your trailer checked out. The two front wheels should be in alignment in relation to the hitch ball socket. The two rear wheels in relation to the fronts after their alignment. Your trailer will then tow straight and true. Your tire wear will then be even and normal. If your alignment shop can/will not do it that way, find one that can. Most are not equipped to do this kind of alignment. Lots of measuring and axel tube bending involved, but so worth the great result.
I have had both of our Airstreams done at Hewitt Alignment in Stockton CA.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 11-10-2015, 06:01 PM   #3
Tincampers's Avatar
Would this be covered under the warranty?
Old 11-10-2015, 06:11 PM   #4
r carl's Avatar
Lin , Ne
You will find your problem here.
Trailer Axle Alignment and Tire Wear Problems
Old 11-10-2015, 07:19 PM   #5
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I had the same trouble, once.
I struggled to find the reason. Blamed it on wheel, alignment, etc.
I swapped it to another position and it alone continued to wear.
Turns out it was simply a bad tire.
I suggest rotating your tires and track the outcome.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 11-10-2015, 07:58 PM   #6
Tincampers's Avatar
Regards,
JD
Thanks JD, I will try that.
Old 11-10-2015, 09:20 PM   #7
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
I had a similar problem with a tire on my 14 inch 23 footer. Did what JD did.
Replaced tire and that took care of it. I do not recall which side of the trailer, although it was the inside tread on mine.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 11-11-2015, 12:03 AM   #8
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Yep, sometimes a tire will just wear screwy, and never straighten up.
Brevi tempore!
Old 11-11-2015, 06:56 AM   #9
Tincampers's Avatar
I do have a straight edge and will check to be sure there isn't a major alignment problem. I'll just swap this tire for the spare. Going to put 16" on at some point.
Old 11-11-2015, 07:04 AM   #10
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Every Spring after the brake inspection......
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 11-11-2015, 09:54 AM   #11
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
It is said that you should not change sides when rotating radial tires.
That said, I don't always do what "they" say.
Brevi tempore!
Old 11-11-2015, 09:58 AM   #12
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We found more wear on the curb rear on our 25FB as have several friends. I put the trailer on individual wheel scales and that tire was carrying 200 pounds more weight than the other three.
Old 11-11-2015, 10:52 AM   #13
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have had the same trouble twice- simply bad tires-
Those look like Goodyear Marathons by the tread pattern in the picture.
I rotated mine, kept them properly inflated, never hit a curb-
They will only last 3-4 years no matter how well you take care of them.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-11-2015, 10:54 AM   #14
m.hony's Avatar
2013 30' Classic
It was the front right and Carlisle tires on my previous trailer.
It was the left rear and Goodyear Marathons on this trailer.
Once I got new tires, I noticed the other 3 also had tread separation, just not as bad as the 1-
TAC #MS-10
Airforums #70955
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 07:49 PM
Rated tire speed - Can I get faster than 62? Goin camping Tires 1 09-25-2006 05:29 AM
One Elec Brake not Equal to Other Three wingfoot321 Brakes & Brake Controllers 1 04-24-2004 03:01 AM
Any other's 26' other than 60's Overlander? 59toaster Our Community 4 03-21-2003 10:00 AM
Faster than a Telegraph! autoist Airstream Motorhome Forums 0 02-26-2003 09:32 PM
