Old 06-24-2009, 07:06 PM   #1
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
one side wore out other side good
I also have a 25 Safari 2007, and just wore out the tires on the curb side after 26,000 miles. Other side still good. Why would that be?
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 06-24-2009, 09:11 PM   #2
Most likely cause is lack of proper running gear balance.
Many owners today are install Centramatic balancers, which solves the problem.
When they work on semi's, they gotta work on an Airstream trailer.
Many owners speak very positive about them.
Old 06-25-2009, 07:41 AM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
You might look how the tires are wearing. Your description above needs more details to give some possible solutions.
Action
Old 06-25-2009, 07:47 AM   #4
richinny's Avatar
2011 34' Classic
a picture of the worn tire would be helpful.
Ricky
Old 06-25-2009, 10:25 AM   #5
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Might take that to an alignment shop and check that axle. Im guessin but it could be bent just a smidge. IT don't take much,just runnin over a curb just once could do it. IF thats a Dexter axle, I have also heard or saw someone mention that they had a 2007 or so, AS and the plates were welded in 1 in or so out of Square.which wore the tires out just like yours.There were some bad rubber in some of those axles,Andy can tell ya what the yrs the trailers were that had axles failures. I think the AS dealer in Texas replace a half dozen axles that were bad a couple of yrs ago.
Good Luck
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 06-25-2009, 06:31 PM   #6
hshovic's Avatar
Bozeman , Montana
Images: 20
Thanks for the replies. I replaced the two bad tires and put the other side's tires on the fronts. So, I guess I got (or will get) more than 25,000 miles, which doesn't seem too bad. In fact, I need to replace the driving tires now too. The rears' are pretty much gone on my OEM's Silverado. Fronts are ok. Rotated a year ago.
Hank
Power side to side leveling idea truckasaurus Jacks, Stabilizers, Lifting and Leveling 12 10-10-2008 10:43 AM
Compare Kipor, Honda, Yamaha quiet generators side by side ShinyTwinkie Generators & Solar Power 17 09-26-2008 09:01 AM
Brake controller side by side comparison Boondocker Brakes & Brake Controllers 4 10-17-2007 12:05 PM
Side to side leveling: can I use the stabilizer jacks? iAirstream Jacks, Stabilizers, Lifting and Leveling 4 08-17-2007 07:33 PM
Side-to-Side Flooring Replacement in Classic MH Eddy Repairing/Replacing Floor &/or Frame 12 11-03-2006 01:08 PM
