Old 11-07-2013, 03:33 PM   #155
BlackAces's Avatar
Taylors , South Carolina
"It is estimated that in approximately three years, roughly one-third of a tire's strength is gone."
That's a quote from a popular ST tire manufacturer about their radial ST tires.
If a person's expectations exceed reality, disappointment is sure to follow.
BA
BlackAces
USN - RET - PDRL
DoD & SSA - RET
BlackAces is offline   Reply With Quote
Old 11-07-2013, 05:09 PM   #156
K.C. , Missouri
BA
Yeah, really gives a guy a lot of confidence in the whole idea of ST tires in general, huh ?
No thanks.....I prefer other choices. For all those supporters of ST tires, I say, "go for it....."
gmw photos is offline   Reply With Quote
Old 11-08-2013, 02:04 PM   #157
CapriRacer
CapriRacer's Avatar
I'm in the , US
Just an FYI:
That quote about loss of strength is both misleading and applies to ALL tires - not just ST tires.
Why misleading? Because what they are trying to express is the loss of FATIGUE as a tire (or anything that undergoes a changing load - particularly a cyclic load) is used.
If you look up the Wikipedia article on material fatigue, you'll notice a graph called the SN curve. It expresses the change in cycles to failure as a function of stress. What is interesting is that you can estimate the remaining life in a tire if you know either the average life in the tire or the stress level.
But trying to express this loss of life as a loss in strength is just fundamentally wrong.
And like I expressed earlier, it applies to all tires - regardless of the type of tire. The fact that there are manufacturers who produce better performing tires is the key factor. If an LT is produced by one of those often maligned ST tire manufacturers - AND - used in the same way - that tire would not perform as well.
CapriRacer is offline   Reply With Quote
Old 11-08-2013, 02:24 PM   #158
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
"The fact that there are manufacturers who produce better performing tires is the key factor. "
Exactly! That is why I am running LT tires. I can not find well manufactured ST tires.
Plus I am not smart or interested enough to try to read the standards, but I suspect that a LT tire that is rated at 2500 lbs load has to pass a more stringent test to get the rating than a ST tire does for the same load rating.
Bill M. is online now   Reply With Quote
Old 11-08-2013, 02:37 PM   #159
K.C. , Missouri
....yes indeed. I may just use that as a sig line going forward.
...thanks Barry !
Clearance lights issue jsprad Lights - Interior & Exterior 3 08-20-2011 09:28 AM
Back-up Lights - TV - issue Pinchy Lights - Interior & Exterior 3 05-10-2011 06:24 AM
