Old 04-16-2010, 09:21 AM   #1
Dillon , South Carolina
Now I am confused about tires
Now I am confused. I will need to replace the 4 tires on my 1959 Ambassador. They are 700 x 15 now.
I was considering going with 225 X 75 X 15. But now do I need D or E rated tires?
I have also been told that each wheel should be steel and rated at 2600 Lbs or better. Each wheel should be 15 in x 6in with 6 hole patter with a 5 1/2 bolt circle and zero offset.
Suggestions are welcome.
urb2165 is offline   Reply With Quote
Old 04-16-2010, 10:15 AM   #2
dpandorf's Avatar
2000 34' Limited
Somewhere in Western , North Carolina
I'd buy these:
Marathon ST225/75R15 Tires
ST225/75R15 2540 lbs (D) rating (with all 4 tires will support up to 10,160 pound trailer weight.
If the wheels are Airstream factory wheels you should be ok. However, I think the wheels should have their rating placarded somewhere on the wheel.
Duane Pandorf
Blog | Google+
Air# 16888 | 2000 34' Limited | 2008 Ford F250
dpandorf is offline   Reply With Quote
Old 04-16-2010, 08:51 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The best scenario is to match the tire load rating with the max load of the trailer + 10%.
Too low a tire rating and the result could be very exciting situation.
Too high a tire rating and it is a waste of money and potentially a harsh ride for the trailer.
So "D" or "E" rating sugestion becomes a guess not knowing what your trailer weighs when fully loaded with gear and liquids. Or one needs to know what the GVWR, however a 1959 unit did not have that kind of rating when it was manufactured.
>>>>>>>>>>>>>Action
Old 04-16-2010, 09:03 PM   #4
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Our Ambassador Wheels/Tires
We recently replaced the tires and wheels on our "78" Ambassador. The specs you listed are correct for our Ambassador...I assume they may be the same for yours. Purchased our from: 15" SIX BOLT ALUMINUM TRAILER WHEELS FOR TOWABLE RV'S, FIFTH WHEEL TRAVEL TRAILERS, BOAT TRAILERS, CARGO TRAILERS, HORSE TRAILERS AND MORE Great people to deal with and fairly priced.
TAC PA-5
Roadrunner is offline   Reply With Quote
Old 04-16-2010, 09:35 PM   #5
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Going sideways here....have you had a chance to check out those new wheel balancers called Centramatic wheel balancers -- you can see a demo on you tube. They are made in Dallas and theirs cost around 200.00 for a set. But the company that makes them says that Inland RV is cheaper. But they are a cool finishing touch to your new tires if and when you get them.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 04-16-2010, 09:49 PM   #6
1970 27' Overlander
Here's that link....Centramatic Happy reading!
Old 04-17-2010, 07:34 AM   #7
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
It seems I my be in the same boat soon, having to replace my tires. Another question is can you replace them with truck tires. it seems most trailer tires are only rated to 65 mph. would I or someone else be better off with a D or E rated truck tire that is built for higher speeds. I have noticed my tires can get warm in the summer at highway speeds and my the tires on the TV are not as warm...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 04-17-2010, 08:09 AM   #8
Mr. Decent's Avatar
1960 18' Traveler
Nomadic , Symmetry
Images: 21
I recommend checking this link regarding special trailer tires, light truck tires and passanger tires.
http://www.taskmasterproducts.com/ac...ailertires.pdf
Mr. Decent is offline   Reply With Quote
tires radials or bias ply tires larry b Tires 22 06-27-2010 05:36 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 10:11 AM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
ok, now I'm confused... bradk Towing, Tow Vehicles & Hitches 38 03-01-2006 10:23 AM
Help - I'm Confused timcumming Clearcoat, Exterior Paint & Trim 16 02-26-2003 01:23 PM
