Old 06-02-2014, 01:44 PM   #1
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Nokian Rotiiva AT 235/75R15 116/113S
I saw this while surfing. Know nothing about the company, but a 15" LT tire with that load range sure got my attention. T428439 235/75R15LT 116/113S is the item, made by Nokian.
Anyone know anything about these tires??
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 06-02-2014, 03:54 PM   #2
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Have had Nokians on my Touareg. Nokian is known for their snow tires but also makes these all season/all terrain tires as well. Good for light off road use but have a softer compound so they can wear faster on a heavy vehicle. Have no idea how they would hold up on a trailer, but may wear faster.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 01-08-2016, 08:39 PM   #3
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Bump for an update. Anyone running these on their trailer?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 01-09-2016, 04:46 AM   #4
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Scott
I have not noticed this tire before, looks very interesting.
Reading their specs it looks like it is designed for summer highway use so I don't think temperature would be a problem. From what I understand they are a very good company.
The only gamble I think is how they will react to the turning forces on a tandem axle. Over the years we have seen a couple of tires that would loose their tread due to trailer use. I doubt that would be the case with the Nokian but you don't really know until you try them. I am sure they are not tested for that.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 01-09-2016, 06:23 AM   #5
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
I've tried to get these tires from Discount Tire and they couldn't get them.
There is plenty of load capacity for heavier trailers and single axle trailers that carry a big load.
Lance
Top is offline   Reply With Quote
Old 01-09-2016, 10:44 AM   #6
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Originally Posted by Andrew T View Post
Hi Scott
Andrew T
Thanks Andrew. I hate to be the beta tester but can they be worse than the GYMs I have now?
Old 01-09-2016, 10:45 AM   #7
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Hmm. I didn't actually try to order them but they do seem to be available via the web.
Old 01-09-2016, 10:51 AM   #8
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Scott
I doubt they would ever be a problem, you could use the Michelin P235/75R x 15's on yours if you did want something with a track record. We have put a few thousand of these on many on 30's including classics which run them close to maximum load and never an issue.
If we have a 30 in stock that I can use this summer I may try a set of the Nokian's on it.
Andrew T
Andrew Thomson
London, Ontario
Old 01-09-2016, 10:55 AM   #9
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Hi Scott
Andrew T
As much as I'd love to use the Michelins (I have them on my truck already), they are only rated at 2205 lbs. That's just cutting it, and doesn't account for the 10% derating that's required.
Then again, my trailer isn't near 8800 lbs but still...
Old 01-09-2016, 11:07 AM   #10
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Scott - have you thought about Goodyear Cargo tires? The G26 comes in a 15" and carries 2400# - no de-rating required. I ALMOST a went with these except they will definitely be about an inch or so lower than the Michelins meaning is have to adjust my hitch and the trailer would be closer to bottoming out. But you might want to have a look.
On edit - here's a link: http://m.tirerack.com/tires/TireDeta...3674x012-tire&
Old 01-09-2016, 12:27 PM   #11
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
You could also get a load range D Pirelli Scorpion ATRs. LT235/75/15 LRD.
Lance
Old 01-09-2016, 12:36 PM   #12
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
I agree. Dont want to lower the trailer any.
Old 01-09-2016, 12:37 PM   #13
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
I can double check but im sure I looked at those before and they wont wirk with 8800 lbs.
Old 01-09-2016, 01:11 PM   #14
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Four of those Pirelli will get you #9,430 of capacity. What are your axle weight ratings or weights when fully loaded for travel? The #8,800 is your trailer's GVWR. That includes tongue weight.
Lance
Michelin LTX 235/75R15 XL Upgrade? switz Tires 234 06-28-2014 03:46 PM
Fitting LT235/75R15 LR C on our '71 Tradewind... barts Tires 7 04-18-2010 06:17 PM
225/75R15 Goodyear Marathons do not fit. Silver 81 Tires 13 11-07-2009 11:00 AM
Towing 5200# TT w/1978 F150 Supercab with 6.6L engine & 2.75 rear end and 235/75/15's Scottbral Tow Vehicles 2 04-04-2009 09:10 AM
Michelin 235/75R15 LTX M/S vs Marathon ST225/75r15 EXCEL88 Tires 3 06-16-2008 07:41 PM
