Old 03-02-2016, 05:54 AM   #43
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Steamy,
That's a lot of overkill for a 23'er in my opinion. There are plenty of 15" tires that will give you years of trouble free service.
Lance
Top is offline   Reply With Quote
Old 03-02-2016, 01:56 PM   #44
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
We have a lift kit and 16" Michelins on our 19", and I really like the ground clearance and how smooth it pulls with the load range E tires. I am trying to replicate this on the 23".
Steamy1 is offline   Reply With Quote
Old 03-02-2016, 02:15 PM   #45
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
If you want tall 15" tires, the Yokohama RY 215 is 29.4" tall.
http://www.tirerack.com/tires/tires....ireModel=RY215
Lance
Old 03-02-2016, 02:17 PM   #46
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
But, if you just have a bunch of money and like to spend it, that's cool too.
Your very own economic stimulus package of sorts.
Lance
Old 03-03-2016, 06:48 AM   #47
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Going from the stock 14" wheels and tires on the 23D to the 15" SenDel T03-56545T wheels and 15" Michelin LTX (P) 235/75R15 XL tires raised the trailer 1.1" as the Michelins are 2.2" larger in diameter. These are the same pattern wheels we have on the Classic and is the pattern Airstream is using for the factory installed 16" Michelin tires on the 2015 and later 31' Classics and the Eddie Bauer models.
The wheel openings weren't identical so we had to trim over an inch off the metal curb side front to have the same distance from the vertical plastic wheel well lining and that gave me about ⅝" clearance for the that front tire. The other side was just over 1" clearance.
With the trailing arm suspension, the tires move back and up on bumps.
The 16" Michelins have a 29.2" diameter while the 15" are 28.9" in diameter.
One would have to go to 12" drum brakes with a 23D to get the 6 lug nut bolt pattern associated with 16" tires. The SenDel folks make both a five and six bolt 15" wheel in the same look. They also make the 16" wheel in six and eight lug bolt patterns.
Old 03-03-2016, 09:49 AM   #48
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Originally Posted by SCOTTinNJ View Post
Well, I don't think anyone is going to pay for $5,000+ in repairs if a tire blows out, Michelin, Goodyear, or Airstream.
And at least with Walmart you can get a replacement Pirelli just about anywhere.
If it could be proven in court that that the tire was at fault, remember Ford and the Bridgestone ordeal?.. Who is paying?
Old 03-03-2016, 11:32 AM   #49
Switz,
Good information; so the question is if it is possible to replace the 10" drum with a 12" drum, on the existing axle?
Old 03-03-2016, 11:47 AM   #50
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Originally Posted by Steamy1 View Post
Switz,
No, you can't put a 12" drum on a 3.5K axle. It doesn't matter though.
You can use a 10" hub and drum with 6x5.5 lugs as long as it is a standard 3.5K axle.
http://dexteraxle.com/inc/sdetail/6747/6836
Lance
Old 02-10-2018, 09:54 PM   #51
2017 30' International
Lincolnwood , Illinois
LT tires
Since they are LT tires you need to derate them by 10%. So that's under my axle weight of 8800 lbs.
I don't believe we need to derate LT tires.
Milo1952 is offline   Reply With Quote
Old 02-11-2018, 02:09 AM   #52
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Correct. I was wrong.
SCOTTinNJ is offline   Reply With Quote
Old 08-13-2019, 04:31 PM   #53
just had the Nokians mounted. going to try these out for our September trip to the PNW:
Nokian Rotiiva AT ATV Radial Tire - 235/75R15 113S
The fact that these are a true LT tire with a LRE rating are appealing. Will see how they compare to the Michelins, which are a P rated tire.
Updates to follow.
Old 08-13-2019, 10:25 PM   #54
2008 25' Safari
Davison , Michigan
Updates to follow.
We've had our Nokians mounted with centramatic balancers... and we've crossed the country several times. Utah off road, New mexico.. and next week florida (we're in Michigan).
The nokians are great tires... and durable. Ours show little wear. With the savings on not buying new wheels, you can invest in other goodies as well.
We've had the Michelins.. and we've had the GY ST's... the Nokians are our favorite.
Estrange is offline   Reply With Quote
Old 08-13-2019, 11:37 PM   #55
Flht2k's Avatar
sacramento , California
We have owned them since 2015, look brand new over 20k. No better tire and made in the usa
Flht2k is offline   Reply With Quote
Old 08-14-2019, 12:16 AM   #56
Reassuring to hear this from actual experience. Even the tire guy said it was a great product and he does not carry them.
Do you run at 80 psi?
« Marathons got us! | Top | - »
Michelin LTX 235/75R15 XL Upgrade? switz Tires 234 06-28-2014 03:46 PM
Fitting LT235/75R15 LR C on our '71 Tradewind... barts Tires 7 04-18-2010 06:17 PM
225/75R15 Goodyear Marathons do not fit. Silver 81 Tires 13 11-07-2009 11:00 AM
Towing 5200# TT w/1978 F150 Supercab with 6.6L engine & 2.75 rear end and 235/75/15's Scottbral Tow Vehicles 2 04-04-2009 09:10 AM
Michelin 235/75R15 LTX M/S vs Marathon ST225/75r15 EXCEL88 Tires 3 06-16-2008 07:41 PM
