Old 05-22-2015, 11:23 AM   #1
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
NITROGEN versus "AIR" in your Trailer Tires
Costco has uses Nitrogen to fill any tire you purchased from their stores. You get a green screw cap on your air valve as a bonus.
What I did I discover?
I monitor my tire pressure before we leave on a trip... no problem. Nitrogen does not "escape" like the mix of gases in the "air". I was convinced that Nitrogen served me well.
I sold the 2006 Safari with Nitrogen filled tires from Costco.
I now have a 2014 International. Jackson Center, Ohio... "air"? Before I leave home I have to hook up the air compressor and get the tires to where I want them. My bicycle tires always need to be inflated due to the higher air pressure and they leak... leak and leak. My ATV tires... leak over time. My Riding Lawn Mower tire... leak.
I would expect in humid climates that you will be getting a large amount of water vapor into your tires and it really expands when the tires get hot from distance traveling. Compounding the problem of highly variable tire pressures.
Our Toyota Dealer who said Nitrogen was a sales gimmick some years ago... now uses Nitrogen.
Nitrogen is inert. It does not expand and contract like "air". It obviously does not escape through the rubber, air valve or however the local air mixture seems to... leak.
I am not in the tire business. Is there something to Nitrogen, other than nobody wants to pay the cost of using it to inflate tires? Even bicycle riders want Nitrogen. What do Car Racers inflate their tires? What do bicycle racers use? Commercial truck drivers?
Human Bean
Ray Eklund is offline   Reply With Quote
Old 05-22-2015, 11:42 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
We use nothing but nitrogen in our aircraft tires for the following reasons. Nitrogen has no moisture in it which can cause corrosion on the wheel halves, no moisture means no freezing of water inside the tire, and more stable inflation values at different altitudes and temperatures
Old 05-22-2015, 11:43 AM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I would like to use Nitrogen but when the tire does get get low I have to use my air compressor to pump in air (which has 78% nitrogen).
Kelvin
Old 05-22-2015, 11:51 AM   #4
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Waste of money for automobiles and trailers. We had nitrogen in our Accord's tires when we bought it, now it's just air, no difference I can discern, and I drive that car at speeds above 80 mph sometimes. And as KJRitchie pointed out, most people don't have a supply of nitrogen at home. And even checking pressure - which you still have to do - will let some out of the tire.
I always hear a lot of theoretical improvements, but no one seems to have any actual, real-world results of improvements.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 05-22-2015, 11:55 AM   #5
1976 31' Sovereign
Oswego , Illinois
Once nitrogen is in tires then add air, nitrogen is worhtless as air has moisture contaminates nitrogen. If can find nitrogen to top up tires okay but many plces do not have, or do as I did when racing, purchase bottle and regulator at welding gas store, but it is costly. As Aerowood posted about nitrogen in tires.I used nitrogen in my airplane tires and struts, my ap had set up to do fills when needed. Nitrogen is stable about heat build up, why we used racing. There is a previous thread dated 7-13-2014 of 6 pages about nitrogen in tires. Quote from dzn0fog this thread, it is a gimmick for cars and trailers. As he stated 160 mph, a 1/4 pd. of pressure gain is a lot.
Old 05-22-2015, 12:31 PM   #6
1981 31' Excella II
New Market , Alabama
Nitrogen and air have identical properties. The only difference is the lack of water. I would say that it is snake oil for the most part other for extreme uses like in airplane tires. The lack of oxygen is a plus.
Perry
Old 05-22-2015, 02:43 PM   #7
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
FYI,, I have a few old American tube and tubeless tires that have to be pushing 20 years old that have held air all this time.. But it seems all my newer,, (China made ) tubes and tires leak like a sieve.
As for anything other than plain old air for tires in our rural area would be a waste of effort with all the nails,, hardware that lines our rural roads with constant punctures and repairs.. Its worked ok for over 100 years and will end up finishing me off in my life time..
Airplanes and such I can see some of the positive reasons for it.. But even then with a good compressor with a water trap system it would be 99.9% dry air..
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 05-22-2015, 03:22 PM   #8
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
What's the old saying? A sucker is born every minute.
MICHAEL
Old 05-22-2015, 03:25 PM   #9
Aerowood's Avatar
Arvada , Colorado
Just for the record here, I just use compressed air in my vehicle and trailer tires, it's just not worth the effort to use N2
Old 05-22-2015, 04:32 PM   #10
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I love this compromise (that I think I read on another thread here): Air is 78% Nitrogen. So just fill my tires to 122%, then let out the extra 22%. 100% Nitrogen.
2012 Dodge Durango Hemi/AWD
Old 05-22-2015, 04:37 PM   #11
Tincampers's Avatar
Sneedville , Tennessee
Say what? Help me get the wrinkles out of my forehead. Doesn't everyone used compressed air in their tires? Or am I missing something?
Tincampers is offline   Reply With Quote
Old 05-22-2015, 04:47 PM   #12
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
How do you purge the air from the tire to fill with 100% nitrogen? The tire is filled with air from the atmosphere as it is mounted, then filled the test of the way with nitrogen.
I'm thinking helium just to make them run lighter. Helium fills come with a blue cap which better matches my awnings! Just saying!
Old 05-22-2015, 04:48 PM   #13
1981 31' Excella II
I have some Argon at work and Helium as well. The helium would leak out fast. I could be the only Airstream with Argon filled tires. Is that cool or what. The helium has the advantage that you can breathe it and talk like donald duck.
Perry
Old 05-22-2015, 04:52 PM   #14
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Yes but.....
Filling tires/nitrogen Gas Phil Gobie Tires 44 04-26-2009 02:31 PM
Changed air in tires for nitrogen? Blevi Tires 37 11-29-2008 09:55 PM
Nitrogen in Tires? dpandorf Tires 24 04-29-2007 08:20 PM
Poll : PURE NITROGEN ( Z ) in tires brunoffrance Tires 37 11-18-2003 08:10 PM
