Old 07-18-2014, 06:17 PM   #57
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Originally Posted by DKB_SATX View Post
This is only acceptable in its liquid state... the solid form of the compound detracts from enjoyment of the full flavor of the spirit.
Are you implying that "on the rocks" is an incorrect way to enjoy Bourbon!
Them's fighting words. I challenge you to a tasting competition. I already got the campfire going. Now, I do try not to allow my libation to get too watered down but I do like it chilled. Excuse me the cooler by my chair just knocked.
Oh yeah, check your tire pressure regularly, see owners manual etc.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-18-2014, 06:37 PM   #58
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
...snip...
Ok - I can see it now. A "hitch equivalent" thread on bourbon, whiskey and scotch - how to drink them, how not to drink them, what's the "best brand" (mine projects the "pivot point" toward my rear axle, yours doesn't carry enough weight), rocks, no rocks, metal cubes, granite cubes, distilled water splash, chilled, warmed, crystal rocks glass, red solo cup, Glenlivet 18, Pappy van Winkle 21, Woodford Reserve, Sazerac 18 Rye, Johnny (red, black, blue)...
On second thought - let's just toast each other and get on with it :-)
Old 07-18-2014, 07:03 PM   #59
GCinSC2's Avatar
How about adding 1792, Bulleit or my campfire special, Rebel Yell. Any in a Mason jar on the rocks thank you.
Check your tires every time you stop, give em a glance.
S/OS #001
Old 07-18-2014, 07:11 PM   #60
GCinSC2's Avatar
Na zdrovyeh.
An attempt at Nastrovia! The Polish version of Cheers! In honor of my Polish better half. But it might not be Polish, we might find out.
S/OS #001
Old 07-21-2014, 03:31 AM   #61
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
PV = nRT This thread is subject to massive thread wander. Amusing, but not scientific. Race car logic is the same. Lots of unproven theories and urban legends. Since tires are usually just filled with nitrogen, rather that 100% purged of all oxygen (a physical impossibility), the possibility of having a tire filled with only nitrogen is extremely remote. The potential benefit is also infinitesimally small. Interesting waste of time and money.
Old 07-22-2014, 02:57 AM   #62
Berkel-Enschot , Noord-Brabant
Me , who call myself tire-pressure-specialist now, also now concentrating on Nitrogen filling.
Planning to make an article in wich I first sum up all the comercial arguments, then de-mith them or relativate them .
One thing i can already de-mith and that is Nitrogen ( further N2 ) absorbing more heat then Oxigen( O2) , so your temperature and by that pressure stays more constant, for instance when braking .
It is true if you use per mass so per lbs , but as is used in tires in volume , even O2 absorbes ( 1% ) more energy . So this mith can even be deforced because its simply not true.
Busy now on the argument of rubber having little holes in it troug wich the smaller O2 molecule disapears quicker then larger N2 molecule.
But what then at higher pressure ,do the holes get larger so N2 goes yust as fast trough them ?
To my conclusion difusion trough the rubber is a much more complicated matter , somewhere between Phisical and Chemical, so the more reactive the molecule the quicker diffusion.
Then it could be that Helium ( He) althoug its a smaller molecule but totaly inert gas , could even diffuse slower then N2 troug the rubber.
Also Argon is an Inert gas and saw someone mention it here already.
Could be that Argon even dont diffuse at all , and its a side-product of Amonia production , wich is used for artificial vertiliser production, so probably in the same price as Nitrogen.
The rate of diffusion is sayd to 2 or 3 times more for O2 then N2. Even 5 times is mentioned, and I use that in spreadsheet I made. Then this results in less then 2 times more pressure loss for a 80/20 filled tire then a 100/0 N2/O2 division. Then in about a year I think the 80/20 tire looses 10% of its pressure and the 100/0 filled tire "only" 5,8%. Before that you have already checked it tree times if you are wise and filled that small difference of 1/3 th of 6,5 psi on a 65 psi filled tire . The N2 then only looses 3,5 psi in that year .
Filled in my spreadsheet with Argon 98% rest O2 and N2 and asuming argon diffuses 0.1 times as fast as N2 , and then even pressure rises about les then 1 psi , because O2 and N2 diffuse into the tire so more gas is coming into tire in time.
To determine the diffusion factor in compare to N2 ( =1, O2 = probably 5) I thougt out a test with 4 old the same tires with same rimms ( from old car or winter tires when summer) . give them a basic filling empty tire so Zero pressure = 1013 milibar real pressure , with same gas compound as outside
Then fill up with 100% each tire , one N2 two O2 , 3 Helium, 4 ARgon,
then the pressure loss is totally because of the diffusion of that filled gas , because the ground filling is Partial pressure of N2, O2, AR the same as outside , so yust as much of those gasses diffuse in as out.
The diffusion factor then can be calculated yust by deviding the pressure losses.
This would make the diffusion factors for shure and no gambling about it.
My expectation is that it will prove Ar and He to have a diffusion factor of 0,1 or less.
Then last about Water in the tire, my idea is that a little liquid water can help cool down and transport the energy better then dry air.
This because of the energy that is needed to go from liquid to gas ,
The pressure in tire will rise a little wich then gives lesser deflection so lesser heat production by the bending of the rubber.
but first I have to know how to calculate with that, so placed a topic on Dutch science forum about it, but had also to do with partial pressure of water as gas for a sertain temperature before it condenses.
jadatis is offline   Reply With Quote
Old 07-22-2014, 06:51 AM   #63
1982 31' Excella
City , Florida
If air has a greater coefficient of expansion than N then from an economic aspect maybe air really would be better than N? Think hot air balloons. If air in tires gets hotter than N then it would try to rise and so take weight off the trailer which would equal less fuel consumption and less wear on the tires.
The possibilities are boundless. Instead of conventional insulation between the inner and outer skins, how about using balloons filled with helium? And all that wasted space in the chassis box girders. If one got too much lift could traction problems arise? Once when I was working a job I didn't like, the air and everything else seemed heavier on Mondays. So should Mondays be a stationary day?
There's a multimillion dollar government research grant somewhere in here guys.
AFUser is offline   Reply With Quote
Old 07-22-2014, 07:11 AM   #64
K9CarCrate's Avatar
2014 Interstate Ext. Coach
Vienna , Virginia
This is really a chemistry question. The molecular size of nitrogen remains relatively the same under increased pressure and heat vs. Oxygen. Nitrogen is a smaller molecule. It can make a slight difference if you generally drive 200+ miles per hour. I have never seen a service station that has a system that effectively evacuates all water and oxygen prior to filling a tire with nitrogen. For regular everyday driving, it is a gimmick. Steve
K9CarCrate is offline   Reply With Quote
Old 07-22-2014, 12:59 PM   #65
1982 31' Excella
City , Florida
Now look here Dwight. You should know that Airstream owners consider any discussion of Airstreams a serious matter and it could be that some may consider calling their discussion of N "amusing" somewhat of an affront.
Old 07-22-2014, 02:54 PM   #66
richw46's Avatar
Lexington , Kentucky
Na zdrovyeh.
Na Zdorovie is a Russian toast. We always say Sto Lat! It's a Polish toast / song for all happy occasions. May you live 100 years; bottoms up! . I'm half Polish, not sure which half, left / right / top / bottom. So far it hasn't mattered much
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 07-23-2014, 06:47 AM   #67
GCinSC2's Avatar
I toast corrected, only married a Pole. Her nickname is "Ski"
S/OS #001
Old 07-28-2014, 01:23 AM   #68
If she is a she would her nickname rather be "Ska"
But In my last ( and first) post in this topic, I mentioned that the difusion rate in my test, could simply be determined by deviding the pressure losses , but that is not true.
Have found a way to calculate it thoug, so my test can be done still.
Tried it out that calculation and if for instance 100% N2 filling to empty tire looses 10% and 100 O2 filling 50% in that same time, it calculates not 5 times, but 6 to 7 times that O2 diffuses quicker then N2.
If in a few years Nitrogen is replaced by Argon, then remember it was my idea.
Argon though is a "heavy gas", also used in Air-bags, light bulbs.
So it would make the vehicle a bit heavyer wich we cant use ( about max 1lbs) so this would give Helium an advantage wich makes the vehicle about 2 lbs lighter.
Old 07-28-2014, 11:39 AM   #69
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Argon is used in low-e window glass and if the windows are shipped over high mountain passes too fast, the seals don't have time to adjust to the lesser air pressure and weaken and eventually fail. Those of us who live in Colorado check to see where the product is shipped from so they don't come over high passes more than 8,000'. If they do, follow the truck and make him stop every once in a while to allow the seals to adjust—lots of luck with that.
With argon in the tires, you'll have to stop at 8,000', wait a while, go up another one or two thousand, stop again, and so on. Enjoy the beautiful sights, have lunch or take a nap.
Gene
Gene
Old 07-28-2014, 11:47 AM   #70
Tires are not that rigid as window glass , so the tire yust has higher pressure then wich it can stand easyly.
Would the same problemm be if the low-E window was filled with any kind of gas?
Nitrogen filled tires mysecondjoy Tires 69 04-19-2013 08:48 AM
Filling tires/nitrogen Gas Phil Gobie Tires 44 04-26-2009 02:31 PM
Changed air in tires for nitrogen? Blevi Tires 37 11-29-2008 09:55 PM
Nitrogen in Tires? dpandorf Tires 24 04-29-2007 08:20 PM
Poll : PURE NITROGEN ( Z ) in tires brunoffrance Tires 37 11-18-2003 08:10 PM
