Old 07-15-2014, 11:06 AM   #43
jcl
Vancouver , British Columbia
Originally Posted by featherbedder View Post
As I stated before n2 in shocks, airplane struts. Racing tires for build up of heat and stability as we raced motorcycles up to 160 mph, n2 did not give us any failures. N2 is not needed for highway tires, and n2 put in then air put in n2 was contaminated then useless.
There is a logic to this, but it isn't because of the nitrogen, as has been noted above. It is because the bottled nitrogen is dry. Moisture is the problem for pressure stability with varying temperature, as water vapour expands much more than air/nitrogen. You can put a dryer on your compressor to remove the moisture, or you can use nitrogen which is already dry.
jcl is offline   Reply With Quote
Old 07-16-2014, 06:28 AM   #44
CapriRacer
CapriRacer's Avatar
I'm in the , US
I'm not completely buying the water in racing tires theory. I concede that liquid water would affect pressure buildup and you would get more with liquid water in the air chamber.
But I strongly suspect the reason nitrogen is used in racing tires has more to do with the fact that a nitrogen bottle is easier to transport than an air compressor.
In the 1970's I used to crew for an IMSA race team. They used nitrogen bottles to power the impact guns for tire changes. Those did not take up a lot of space, it was easy to transport into the hot pits and one bottle could last the whole weekend. We used that bottle to fill the tires. Easy-Peasy!
CapriRacer is offline   Reply With Quote
Old 07-16-2014, 06:54 AM   #45
1982 31' Excella
City , Florida
Originally Posted by markdoane View Post
The only performance difference between nitrogen and air is due to the level of dihydrogen monoxide contamination.
Some people have been known to dilute their whiskey with dihydrogen monoxide.
AFUser is offline   Reply With Quote
Old 07-16-2014, 07:06 AM   #46
1976 31' Sovereign
Oswego , Illinois
nitrogen
We did not start using n2 until the 80s & we found the tire pressure did not go up and very few failures of which we had none versus air filled. When you are racing on 2 wheels at 160mph w/out roll cage seat harness ore other safety devices that cars have, we don't take chances with tires etc. You will get or killed or hurt if falling at these speeds this is not IMSA with a open or closed cage around you & technology has changed since 70s enuf said on this matter as I stated before n2 is not needed for highway use &waste of money unless free. PS I owned the bikes we raced & did all work both on & off track. We raced grand national races all over US & had top pros ride for me & my 2 sons so I did not take chances with there lives
Old 07-16-2014, 10:16 AM   #47
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Is that a tongue twisting way to say water?
I use the solid form to start the dilution process in my Kentucky cough medicine.
It's good to see tech discussion interspersed with a bit of levity.
Appreciate the professionals perspectives.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-16-2014, 01:22 PM   #48
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I fill my tires with rainbows and the blood of unicorns. Works really well. True story folks.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 07-16-2014, 01:59 PM   #49
Images: 59
Never tried it. Prefer hydrohydroxic acid in my whiskey.
markdoane is online now   Reply With Quote
Old 07-16-2014, 03:06 PM   #50
1977 Argosy 24
Milltown , Wisconsin
I filled my AS tires with helium. I now get better mileage as the trailer weighs less. I had to put a spoiler over the rear of the AS to keep it on the ground at high speeds though.
ventport is offline   Reply With Quote
Old 07-16-2014, 03:22 PM   #51
r carl's Avatar
Lin , Ne
If you fill your tires with air and let the smaller oxygen molecules migrate out of the tire you will end up with a tire full of fatter nitrogen molecules.
Old 07-16-2014, 04:11 PM   #52
Nomadic , USA
I might try that. Unicorns are getting harder to come by.
Old 07-16-2014, 05:03 PM   #53
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Like all great ideas, this seems so obvious once someone has that stroke of genius.
Much better than unicorn blood. I do use unicorn oil in the truck engine.
Gene
Gene
Old 07-16-2014, 05:19 PM   #54
GCinSC2's Avatar
Gene,
What type ? O AB A NEG other?
Yes Nurse , I did take my meds.
Gary
S/OS #001
Old 07-17-2014, 11:21 PM   #55
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
Here in sunny California we are having big-time drought concerns. Does anyone know how I can drain the H2O from my tires so I can use it to water my lawn? Then I can go racing.
The other choice may be to use triple helium: HeHeHe...
Seriously, (not) this is a great thread, lots of creativity and fun.
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 07-18-2014, 09:26 AM   #56
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
This is only acceptable in its liquid state... the solid form of the compound detracts from enjoyment of the full flavor of the spirit.
David
DKB_SATX is online now   Reply With Quote
Nitrogen filled tires mysecondjoy Tires 69 04-19-2013 08:48 AM
Filling tires/nitrogen Gas Phil Gobie Tires 44 04-26-2009 02:31 PM
Changed air in tires for nitrogen? Blevi Tires 37 11-29-2008 09:55 PM
Nitrogen in Tires? dpandorf Tires 24 04-29-2007 08:20 PM
Poll : PURE NITROGEN ( Z ) in tires brunoffrance Tires 37 11-18-2003 08:10 PM
