Old 07-14-2014, 09:55 AM   #15
dznf0g's Avatar
Oswego , Illinois
Originally Posted by kscherzi View Post
I use a custom blend of roughly 78% nitrogen, 20.95% oxygen, 0.93% argon, 0.038% carbon dioxide, trace amounts of other gases, and a variable amount (average around 1%) of water vapor in my tires.
Good Call!!! that's exactly what I use. I have found the availability to be rather good and the cost reasonable.
-Rich-
Old 07-14-2014, 11:25 AM   #16
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I get my supply of it online and they deliver it with a drone to my shop.
Is it time for my meds? They just took my crayons and coloring book.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-14-2014, 11:49 AM   #17
Ottawa , ON
CR tested this claim
And here are their results:
We conducted a year-long test of the effects of nitrogen in tires and the results show nitrogen does reduce pressure loss over time, but the reduction is only a 1.3 psi difference from air-filled tires. The average loss of air-filled tires was just 3.5 psi from the initial 30 pressure setting. Nitrogen-filled tires lost an average of 2.2 psi from the initial 30 psi setting.
They bought a consumer-type system that generates nitrogen in order to do this.
So you still need to check your tires frequently...
Old 07-14-2014, 11:52 AM   #18
Ottawa , ON
Since that is the makeup of standard air, I find a lot of people up here doing that, too. ;D
Old 07-14-2014, 11:53 AM   #19
dznf0g's Avatar
Oswego , Illinois
The infrastructure is in place for global distribution, however sometimes it comes in a very cold dense state and sometimes in a hot less dense state. Care to share your meds?
-Rich-
Old 07-14-2014, 12:15 PM   #20
golopogos's Avatar
1971 25' Caravanner
Beatrice , Nebraska
I use it since it was offered on new tires. If I need a fill up I can stop at any t.o. haas and have them topped off for free. If at some point I need to add air to them while traveling and there is not a t.o. haas around I will use the other free stuff. I would not go out of my way too far to keep nitrogen in them.
golopogos is offline   Reply With Quote
Old 07-14-2014, 12:31 PM   #21
txdxrider's Avatar
1976 31' Excella 500
Providence Village , Texas
Basically- once purged there is circa 2-3% of oxygen in the tire. Nitrogen has a larger molecule so the "seepage" is less than nitrogen.
The main benefit for any tire is the oxygen expands more than nitrogen once heated up- hence the reason your TPM light comes on in the morning after a cool evening after driving in warmer climates. If you top back off with oxygen you are repeating the cycle- however if you top back off with nitrogen then you reduce the possibility of driving on an under-inflated tire thus reducing your tire wear.
Let's party with Pirates and Ninja's.....
txdxrider is offline   Reply With Quote
Old 07-14-2014, 12:47 PM   #22
1976 31' Sovereign
Oswego , Illinois
Smile nitrogen
Originally Posted by TG Twinkie View Post
How do you evacuate the air in a new tire before you fill it with nitrogen? When a tire is mounted there is a certain amount of air inside. Even at zero pressure.
When they mount new tire miniscule of air is in tire will not be enough to effect n2 unless air was put in to seat tire that should have been done with n2 if air was used n2 is useless as it is contaminated, never seat with air when using n2.....
Old 07-14-2014, 01:23 PM   #23
txdxrider's Avatar
There are also Machines that evacuate the tire and refill with nitro..,
Old 07-14-2014, 01:27 PM   #24
1981 31' Excella II
New Market , Alabama
You would have to mount the tire with nitrogen as well as to get all the N2 out. The only other way would be to purge it but that would waste N2. If you pull a vacuum on it the tire will collapse and pop off the bead. I don't know how you would purge it unless you purge it before the bead is set.
Perry
Old 07-14-2014, 01:45 PM   #25
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Next time my dermatologist uses liquid nitrogen to burn off some lesion on my skin, I'll ask him to fill my tires and check the oil. I wonder if Medicare will pay for that?
Gene
Old 07-14-2014, 02:21 PM   #26
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
I think, as most have said, that if there is an opportunity to fill your tires at no cost or effort then do it! Costco probably won't want to deal with a trailer but you never know....
GREENovaters is offline   Reply With Quote
Old 07-14-2014, 06:20 PM   #27
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I just over inflate my tires by 20%, then let out that 20% and end up with 100% Nitrogen.
I love that. I think I read it on an earlier thread here.
2012 Dodge Durango Hemi/AWD
Old 07-14-2014, 06:54 PM   #28
Gene's Avatar
Yes, there's a wealth of information all over the Forum. Some of it is even right.
Another thought: what if we fill them with CO2? That could solve global warming. We can just breathe into the tires.
Gene
Nitrogen filled tires mysecondjoy Tires 69 04-19-2013 09:48 AM
Filling tires/nitrogen Gas Phil Gobie Tires 44 04-26-2009 03:31 PM
Changed air in tires for nitrogen? Blevi Tires 37 11-29-2008 10:55 PM
Nitrogen in Tires? dpandorf Tires 24 04-29-2007 09:20 PM
Poll : PURE NITROGEN ( Z ) in tires brunoffrance Tires 37 11-18-2003 09:10 PM
