Old 07-20-2011, 04:23 PM   #1
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
New tires+PSI?
In April 2010 I replaced tires on my airstream and put on Gladiator ST225/75R-/15 10 ply tires....35, 000 towing miles later, today replaced the set with new ones.... this is every day, day in day out use. Old tires were worn evenly and most likely had another 4 or 5 thousand miles available, but it was convienient today at a lew schwab dealer in sutherlin, oregon to replace them. they recommend 75psi....i ran much less in the old set....
any thoughts
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 07-21-2011, 10:51 AM   #2
Vintage Kin
Fort Worth , Texas
As a rule of thumb -- and assuming wheels are rated the same as the tires -- one can take a recommended size tire for that wheel (where tire tread width and wheel rim are a good match) and run it at full sidewall pressure.
Certainly, you don't have to. Ideally one wants tire pressure and load (scaled weight per wheel) to match according to tire manufacturer Load & Pressure Table.
The trailer manufacturer also would have recommendations.
Since you've made no changes in TV or TT you've your choice. 35k on a set sounds very good.
In other words, acquire these relevant numbers and compare them to your own. There is likely a range that will suit you (and weigh the rig to get axle-by-axle numbers sometime).
For peace of mind I also add CENTRAMATICS to mine. And axle alignment should be done.
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
Bumps on sidewall of tires? bertheep Tires 16 08-06-2011 11:10 AM
Tires and Alignment Airstream12557 Land Yacht/Legacy Motorhomes 0 06-08-2011 05:04 AM
Towmaster Tires mshamilton Tires 0 05-08-2011 09:38 AM
White letter tires on Airstream Road Ruler Tires 2 03-09-2011 07:14 PM
