Old 06-18-2009, 06:28 AM   #1
slk
Elk River , Minnesota
New tires needed for 25' Excella 1996
I need to get some new tires as the ones on my trailer are the original I think.
It has Goodyear TS225-75R15 Load range C on it now. Is it advisable to go to a Load range D or should I just stick with what was on the trailer original.
Also is there a need to have the tires on a trailer balanced
Steve
slk is offline   Reply With Quote
Old 06-18-2009, 06:56 AM   #2
Steve
You cannot increase the load range, unless you have mag wheels.
All steel whell manufacturers have warned that when a steel wheel has been in service for a long period, such as yours, that if you increased the load rating with new tires, the wheel will likely split around the circumference.
Of course, you can replace the wheels and be safe.
The size tire you have is still good, ST 225/75R15
Advice Needed: Solar For our 93 25' Excella myboyburt Generators & Solar Power 12 01-01-2010 07:17 PM
1996 Airstream Excella eBay Watch Airstreams on eBay 0 05-23-2009 01:20 PM
Purchase of 1996 Excella 1651 Easyriser 1994 - 1996 Excella 3 01-29-2007 04:21 PM
Size of Hitch Ball on 25' 1996 Excella? Streamer1 Hitches, Couplers & Balls 5 09-07-2006 04:50 PM
