Old 04-01-2013, 11:33 AM   #1
MontyV's Avatar
1994 34' Limited
Salem , Oregon
New Tires
I have read many of these threads. I am posting anyway, I see the tidal wave coming, to get opinion and experience.
We have a 34' classic Limited. The dealer recommends Les Schwab, they recommend a 10 ply TOMAX STR E rated tire 225/75R15. We have 3 axles.
I see some like a softer tire, some like 16" tires, some C and others D rated.
Short of changing all the rims out to 16" I want the best tire money can buy.
We would appreciate all comments, experiences and advice.
Monty & Maureen
MontyV is offline   Reply With Quote
Old 04-01-2013, 11:37 AM   #2
1986 31' Sovereign
Miami , Florida
Michelin LTX 235/75R15
Mike
Old 04-01-2013, 12:26 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I run the above mentioned Michelin on my 25'. They are a XL tire and inflate to 50 psi. I would be very leary of running them on a 34 foot because the overall load is too high and because the load may not be distributed evenly making one tire on a side overloaded. I think Goodyear makes a load range D wrangler, 15" tire that inflates to 65 psi. Wish Michelin made one. I would buy almost any brand truck or SUV tire over the ST tire. If I did buy ST tires I would just stick to GYM. I can not see why there would be a "magic brand" of ST tires that is better than all the rest.
Your wheels are probably 65 psi Aluminum? I would think putting 10 ply tires on and underinflating them to 65 psi would not be a good thing to do.
Bill M. is online now   Reply With Quote
Old 04-01-2013, 12:27 PM   #4
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Look at the Continental Vanco 2.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 04-01-2013, 01:42 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I have had the Power King Tow Max tires on my Safari for two years with no problems.
Before that I ran US made GYMs, for more than 20 years, without any problems.
All of my trailers had two axels. Prior trailers were 30'.
Alan
Old 05-14-2013, 07:33 AM   #6
dalemonroe's Avatar
2008 16' Safari
Portland , Oregon
I bought some Kumho tires rated at 2270 lbs capacity at 65 psi. They'll only be carrying 1550 lbs each. How much pressure should I carry in them. My old Marathons were 50 psi.
dalemonroe is offline   Reply With Quote
Old 05-14-2013, 07:46 AM   #7
1981 31' Excella II
New Market , Alabama
I second that. That would get you 12,000lb total capacity. Whatever tires your run it would be a good idea to rotate them often. 3 axel trailers tend to scrub tires pretty bad when turning. Since these are speed rated tires they are good for speeds way above what most sane people tow at.
Perry
Mike
Old 05-14-2013, 08:06 AM   #8
Roadtrain O--O~(--ooo--)
ebair's Avatar
2000 34' Limited
1979 31' Excella 500
Miamisburg , Ohio
We havent tried the tires you asked about but I can relate our experiance with another brand that we bought due to reccomendations from folks on this board.
In 2008 we bought a set of Maxxis E rated tires as replacements for the factory supplied goodyears on our tri-axle ltd. They have served well under some harsh use, we run a little over 10,000 lbs loaded up and I'm not known for driving under 65 much. Traveled quite a bit in the west with air temps above 105, (tires at 80 lbs hot) and 70 + with no issues so far, this year they will probably be replaced due to age but they arn't showing any side wall checking and just normal wear, rotated every year. Color me satisfied and likely to re-purchase the same.
'00 34' Classic Limited (LOVSHAC)
'12 3500HD, 4x4 LBZ D/A CC LB
AIR #12881
TAC OH-10
ebair is offline   Reply With Quote
Old 05-14-2013, 08:24 AM   #9
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We changed the five OEM GYM ST tires as soon as I got the trailer home for five Michelin LTX (P) 235/75R15 XL tires running at 50psi. We are contemplating moving to a 31' International Serenity or Classic and will order it with the Michelin LT225/75R16E tires and 16" wheels. The Michelins take the tire worries off the table for me. If I had a 34' tri-axle Classic, if at all possible, I would use the 16" Michelins.
Old 05-14-2013, 12:20 PM   #10
dalemonroe's Avatar
2008 16' Safari
Portland , Oregon
We put some 205C 14 Kumho 857 tires on the trailer. They have a load rating of 2270 lbs each at 65 psi. They will only be carrying 1550 lbs each. What pressure should I carry in the tires? The original Marathons were inflated to 50 psi.
