Old 12-15-2011, 11:38 PM   #1
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
new Tahoe hauling 25FB Flying cloud.
We just bought a new Tahoe to haul our 25fb Flying cloud. We were told to increase the tire pressure from a recommended 32 psi. to the max rating of 50 psi. Is this ok?
danlehosky is offline   Reply With Quote
Old 12-15-2011, 11:48 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, yes, but you might not want to go all the way. My Lincoln tires had a max air pressure of 44 lbs and the factory setting was 26 lbs in front and 33 lbs in the rear; I set mine at 35 lbs in the front and 40 lbs in the rear when towing.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-16-2011, 07:53 AM   #3
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
If you go to a truck scale, you can get the loaded weights for all axles including trailer, which will help you determine if you have proper weight distribution. But it will also help you determine the best air pressure for tires at each axle based on the tire manufacturers recommended psi based on load.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 12-16-2011, 03:22 PM   #4
dznf0g's Avatar
Oswego , Illinois
Yes, what MOJO said.
-Rich-
Old 12-16-2011, 05:05 PM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Get the certified scale weights. In the meantime, use the owners manual to determine maximum cold tire pressure, and to preserver the FF/RR pressure differential.
25fb flying cloud, 50 psi, tahoe
25FB Flying Cloud danlehosky Dollars & Cents 5 10-27-2011 10:10 PM
Used '10 Flying Cloud 25FB Value bike_addict Trailer Values 0 09-04-2011 12:02 PM
2011 Airstream Flying Cloud 25FB - NO RESERVE !! eBay Watch Airstreams on eBay 0 08-30-2011 08:50 AM
Centramatics for 2012 Flying Cloud 25FB wlanford Wheels, Hubs & Bearings 14 08-25-2011 09:06 PM
2011 Airstream Flying Cloud 25FB - LIKE NEW !!! eBay Watch Airstreams on eBay 0 08-16-2011 02:20 PM
