Old 06-18-2015, 04:55 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
New 16" wheels and Michelins
At Mothership upgrading my 2015 FC 28. Sidewall says PSI rating is 80. Is this the pressure I should be using? TV is 2015 Chevy 2500HD Duramax, ProPride 1400 lb bars.
DeltaRon is offline   Reply With Quote
Old 06-18-2015, 05:00 PM   #2
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I've experimented on two 30' with the 16" Michelins and have found that everything seems to ride better at just about 65 pounds. Good move in my opinion.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 06-18-2015, 05:35 PM   #3
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We installed the SenDel T03-66655T 16" wheels and the Michelin LT225/75R16/E LTX M/S2 tires with the Centramatic 300-356 (all "A" plates) wheel balancers and Dill 1503-356 TPMS.
We use 75 psi when "cold" on a 31' Classic that weighs 9,200 camping ready. The axles are supporting around 8,000 pounds when not connected and perhaps 8,400 with the ProPride in operational mode.
We see 81 to 84 psi and temps between 120 and 125 being reported by the Dill TPMS when underway.
Old 06-18-2015, 05:55 PM   #4
z , North Carolina
Yup
I run my Michelin's @ 70 PSI, and I do keep a good eye on the pressure & tread wear. IMHO, my 28 isn't heavy enough to warrant the full 80 PSI. I should probably bump mine up to 75, but they look & ride just fine @ 70 PSI. I am getting consistently even tread wear across the tire @ this inflation.
I always like to see the smile on the MM's face tho. He's a good man!
FishinHatteras is offline   Reply With Quote
Old 06-18-2015, 06:42 PM   #5
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Per the load tables, I run 72psi and saw a steady 75psi towing from VA to NY after underway for a few hours.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 06-19-2015, 10:47 AM   #6
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Which wheels did you get?
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 06-19-2015, 10:49 AM   #7
gecko's Avatar
2009 28' International
Pacific Palisades , California
We did same upgrade and have been traveling for two weeks. We have kept inflation around 78psi cold. At this high pressure, we have had cabinets bounce open, drawers dislodged (and dishes broken) while not exceeding 55 mph. We have gone over some sections of rough road as marked, but we've gone over much rougher roads with other tires at the recommended 65psi (and up to 70 psi) without this problem.
This has been a subject of debate on other forums. Search for Phoenix who has done much research on the subject. We have spoken directly with AS whose official position is that 16's and Michelins are not necessary, but EddieBauer insisted for their models. When pushed, they recommended using tire manufacturer's specs. My personal attempts to contact Michelin were unsuccessful.
We are debating between 80 psi for max tire integrity, particularly from scuffing during parking maneuvers, and punishing our coach with a rougher ride. I think we'll next try dropping 5 psi to 73 for our 28' 2009 International--6980 fully loaded/tongue weight approx 1200 lbs (about to lower that with lithiums)/Equalizr 4 pt/Sprinter 3500.
gecko is offline   Reply With Quote
Old 06-19-2015, 11:21 AM   #8
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
There are a bezillion threads on this and after reading ALL of them, I concluded that it makes the most sense to run at the rated pressure of 80. I do not remember why, but that is what some members with professional tire background indicated.
Larry
lsbrodsky is offline   Reply With Quote
Old 06-19-2015, 11:53 AM   #9
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I run 75 because that provides the same load carrying capacity as the original 15" wheels and tires at their 65 psi. It is way overkill for my load (6300# - 800# on the tongue) but since Airstream put 15" tires at 65 psi on as original equipment I thought it best to stick with the same load capacity.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-19-2015, 03:21 PM   #10
2015 25' FB Flying Cloud
Sandy , Utah
Hello,
I am new to travel trailers but have towed 26' and longer boats for years. I have seen the 16" Michelins mentioned many times. What are the advantages? I have even read some threads where they are buying them in order to not have to carry a spare tire. Are they run flats or puncture proof? Just wondering. Thanks
rocco52 is offline   Reply With Quote
Old 06-19-2015, 08:58 PM   #11
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
When we first switched to our 16” Michelins we set the pressure at 80 psi. We noticed a lot of the cushions were all over the place after driving at that pressure. I reduced the pressure fro 80 psi to 75 psi and it made a big difference. All of the cushions stay where they are suppose to be. I was surprised that a 5 psi difference could affect the ride in the trailer.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 06-19-2015, 11:45 PM   #12
Ernie & Madaline #3570
2010 30' Classic
Westford , Massachusetts
Send a message via AIM to bauere
We had our trailer refitted at JC Servie Center then drove 1600 miles to Farmington, Nm. We decided to try out the 80 #s they used there to start with out 30 Classic (10k) pretty loaded as we are on the road a lot. Nothing moving around in side at all. Very stable on the road, wants to roll right up to 70 but we kept the speed right at 60 or a couple down.
Well satisfied so far. Our next move is to weigh the trailer when we get a chance and then check out the Michelin tables.
bauere is offline   Reply With Quote
Old 06-20-2015, 08:24 AM   #13
switz's Avatar
2014 31' Classic
Images: 8
We are running our 16" Michelins at 75 psi. The trailer weighs about 9,200 pounds loaded with the axles supporting roughly 8,100 pounds per my scales. I see the pressures rise to 81-83 underway with the temps rising to 122- 125. I will try 72 psi starting out Tuesday and see what happens (will be close to 110 here).
My scales showed:
------ 1197
2048 ------- 2060
1910 ------- 2050
The left rear weight is down because we have an instant on water heater and lost the 50 pounds associated with the 6 gallon water heater which was just behind that tire.
The Michelin LT225/75R16/E LTX M/S2 tire pressure table:
80psi 2,680 (E)
75psi 2,560
70psi 2,440
65psi 2,335 (D)
60psi 2,190
55psi 2,060
50psi 1,940 (C)
45psi 1,790
Many of the paved roads out here (both interstate and secondary highways) are filled with abrupt undulations that are rough on both vehicles.
Old 06-20-2015, 08:47 AM   #14
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We travel far from home regularly and have the 16" Michelins for their exceptional reliability, especially compared to the original GYM.
Reading the gazillion opinions on tire pressure for these tires I have settled on 65-70 psi range. When backing the trailer I try to avoid sharp turns and prefer gravel or soft ground rather than concrete/asphalt so as not to put undue stress on the tire belts skidding them sideways.
Doug and Cheryl
Fair price on new Michelins ??? Air morgan Tires 7 10-23-2014 04:31 PM
Michelins on vintage Airstream Safari64 Tires 23 05-23-2014 07:54 AM
16" sendel wheel and Michelins campin hound Tires 7 12-15-2013 09:02 AM
OK To Use E Rated Michelins LTX/MS fr8tshaker Tires 11 01-29-2011 11:49 AM
