Old 06-21-2015, 12:09 AM   #15
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Ours stay at 75 psi cold.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 06-21-2015, 07:14 AM   #16
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Cold is relative.... The air temp yesterday was 41 Celsius or 115 here in the Phoenix area. So the tires are pre-warmed for the road?
Old 06-21-2015, 07:44 AM   #17
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Hi Rocco. Flat's are still gonna happen. I carry a spare and have never used it. The only flat I had was a screw in a tire and I was able to plug it and move on. The 16" wheels with a LT tire seem to give better service with fewer tire failures due to tread separation which seem to plague the ST rated tires. You can read yourself to sleep during a tornado with what's available on the forum so go to it. In the end the decision is yours. There are many ST tires out there that have performed well however I changed over to 16" LT's for my trailer.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-21-2015, 09:57 AM   #18
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Maybe the new specification should be "Ambient".
2010 Classic 30
ProPride P3-1400
Old 06-21-2015, 01:55 PM   #19
Ravenna , Ohio
I suggest you read and follow the information of inflation pressure on THIS post.
Retired tire engineer (40 years). Write a blog on RV tires.
Tireman9 is offline   Reply With Quote
Old 06-22-2015, 08:39 AM   #20
Ravenna , Ohio
Please don't forget a plug only is a temporary repair and you may have internal damage from the object or internal damage from running low. Only type repair approved by DOT or the tire companies is a combination plug & patch.
With only a short screw you may not have damage from the scrwew but still might have damage from running low on air as seen in this tire with many cracks.
Old 06-22-2015, 08:41 AM   #21
Ravenna , Ohio
Spec has always been "Ambient" but some don't know the meaning of the word. I believe "cold" was selected as a reference to warmed by the Sun or warmed by driving on it.
Old 06-22-2015, 10:37 AM   #22
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Yes, I know. I was just establishing a more "relative" term for Mr. Switz.
2010 Classic 30
ProPride P3-1400
Old 06-23-2015, 09:01 AM   #23
2015 25' FB Flying Cloud
Sandy , Utah
Hello Tireman9, thanks for the info. I have read a lot about this now and one of the things that I found was from Michelin stating that the ST tires have larger steel wire and nylon chords with stronger sidewalls to handle the forces put on trailer tires when turning. I am not a tire expert so this whole thing is confusing as hell to me! I have been towing 6000 to 9000# boats with ST tires since 1983. In all of those years driving to and from Lake Powell in Utah about 10 times a year I had one flat and one loose lug nut disaster. The flat tire was shredded beyond recognition. "Dad, do you smell something burning?". The lug nut issue required a new wheel and wheel studs and was, fortunately, noticed at a rest stop. Lesson learned.
rocco52 is offline   Reply With Quote
Old 06-24-2015, 10:00 AM   #24
Ravenna , Ohio
Ed
Its the air pressure that supports the load not the tire. Increased "strength" of the materials in the tire are there to retain the inflation pressure.
Your experience is a good example of why you should run TPM. Though not sure if any of the external screw on units can handle boat trailer application with being under water. For a boat trailer I would go with internal sensors.
Old 06-24-2015, 10:50 AM   #25
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Agree 100%. I use my kits only to take it and get it inspected. But most folks are happy to sit on the road and wait for help.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Fair price on new Michelins ??? Air morgan Tires 7 10-23-2014 04:31 PM
Michelins on vintage Airstream Safari64 Tires 23 05-23-2014 07:54 AM
16" sendel wheel and Michelins campin hound Tires 7 12-15-2013 09:02 AM
OK To Use E Rated Michelins LTX/MS fr8tshaker Tires 11 01-29-2011 11:49 AM
