Old 11-10-2013, 08:21 AM   #15
2009 27' FB International
Silsbee , Texas
Thanks for the info everyone! With the build date of the original Chinese built GYM's approaching five years, its time to replace and/or upgrade.
Craig Schrader is offline   Reply With Quote
Old 11-10-2013, 08:45 AM   #16
Snaken49's Avatar
2010 28' Flying Cloud
Fort Worth , Texas
Originally Posted by Ramble On View Post
I bought my wheels (Sendel T03-66655T) directly from Tredit in Arlington, Texas. Paid $85.00 plus tax each. Not sure how I got them so cheap, but I think they quoted the wrong size.
At the time NTB had the best prices on Michelins. Shop around. As far as clearance, no problem. I think putting these tires on the trailer is a no brainer. I have more confidence, especially in the hot summer time.
I also recommend adding the Centramatic balancers. You can pick them up from Centramatic in Alvarado, TX for $199, eliminating shipping.Centramatic
Old Cobra AH-1G Pilot
WoundedWarriorsFamilySupport.Org
http://www.highfivetour.com/
Snaken49 is offline   Reply With Quote
Old 11-10-2013, 09:03 AM   #17
Silsbee , Texas
Thanks. I like that price!
Old 11-10-2013, 09:55 AM   #18
daymonjones's Avatar
Hot Springs Village , Arkansas
This may be a stupid question, I'm known for those. Do the 16' tires cause any change in handling? i.e. sway, porpoising?
I found this site, also, with rims that can handle higher load.
Specialty Trailer Wheels - HiSpec Wheel & Tire, Inc. - The Safety Wheel
Daymon, Maggie May and Mini Me (@ the Rainbow Bridge )
"A good man takes care of his animals, but wicked men are cruel to theirs." Proverbs 12:10
daymonjones is offline   Reply With Quote
Old 11-10-2013, 11:24 AM   #19
dznf0g's Avatar
Oswego , Illinois
None that I have noticed.
-Rich-
Old 11-10-2013, 03:57 PM   #20
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I have the T03's which at the time were the same wheels as the Eddie Bauer units were being with. Here's my receipt for wheels, center caps, lug nuts, and valve stems. I also think it lists the new 16" spare wheel which matched the style and finish of the Airsteam supplied spare for my trailer.
I've noticed no change with the handling or ride of my trailer since replacing the tires in July of 2011.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-10-2013, 05:54 PM   #21
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We changed to 16" Michelin and Sendel T02 (looks like original Flying Cloud wheels), no noticeable difference in handling after 10,000 miles.
Doug and Cheryl
Old 11-11-2013, 06:38 AM   #22
Snaken49's Avatar
Fort Worth , Texas
Sorry! I failed to mention that $199 is for a set of 4 Centramatics.
Old 11-11-2013, 06:45 AM   #23
Snaken49's Avatar
Fort Worth , Texas
You may want to check this forum. The HighSpec wheel generally comes stock on the late model AS. There are quite a few reports of filform corrosion with this wheel over time.
I had no corrosion issues with my stock High Spec 15" wheels but upgraded to 16" Sendel T03 in the silver and black style.
Old 11-11-2013, 06:48 AM   #24
2012 27' Flying Cloud
blaine , Washington
Noticed your 2014 Ram. Just ordered the identical model 2500. How is it?
I'm weighing ProPride vs Air Hitch and my existing Equal-I-zer on 2012 27fb. The cushioned ride is appealing and not addressed by the PP. Lots of scare threads about popped rivets on here.
hanktheyank is offline   Reply With Quote
Old 11-20-2013, 08:46 PM   #25
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
I found the change to 16" LT Michelins to have much less sway, much less wind shift and almost no effect when passed by semi's. After 7,000 miles on my 30' Classic/with slide, it was the best move I ever made. After 3 blowouts on my GYM ST's, I should have done it years ago.
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 11-29-2013, 10:02 AM   #26
SilverEagle6's Avatar
2013 25' Flying Cloud
2008 30' Classic
On The Road To Wherever We End Up , Traveling the USA
I am ordering a 2014 FC 25. My understanding is that AS will put 16' tires and wheels on, but give no credit for the 15's. If I make the conversion to 16's I'll probably wait til I need new tires.
Based on you guys who converted, what are you gaining?
SilverEagle6 is offline   Reply With Quote
Old 11-29-2013, 10:07 AM   #27
rperrym's Avatar
2017 28' Tommy Bahama
For me, peace of mine mostly. Plus they match the tow vehicle tires which I have, different size of course. I use an Airsafe with an Equalizer hitch and have had no problems pulling two different Airstreams.
Rick
rperrym is offline   Reply With Quote
Old 11-30-2013, 02:49 AM   #28
blaine , Washington
Also tpms
Just did TO3 and Michelin 16" conversion on 27FCFB. I run Michelins wherever I can, and as a result haven't had a roadside tire changing picnic in 50 years, which works out to half a century.
Also put in a Hawkshead Talon tpms. They offer an all-metal "T" valve stem which let's you mount the sensor and still have the air fitting in its normal position. I hadn't seen that before. Offered for $10 each, or $10 for a set with a system. Mounted easily on the wheels.
