Old 07-25-2010, 08:00 PM   #1
1973 31' Sovereign
Del Rio , Texas
Smile need new tires
any suggestions on brand type of new tire to put on our 1973 31ft sovereign thanks b2b
back2basics is offline   Reply With Quote
Old 07-25-2010, 09:30 PM   #2
r carl's Avatar
Lin , Ne
You can read a lot of bad stories about ST225/75R15 D tires. I think my next set will be load range E ones inflated to 60psi.
Old 07-25-2010, 10:31 PM   #3
SteveH's Avatar
Common Sense , Texas
Four 225/75R15 D rated tires are rated for over 10,000 pounds weight when inflated to their rated 65 psi. E rated tires at 60 psi will most likely ride much harsher.
Regards,
Steve
Old 07-25-2010, 10:59 PM   #4
TahoeStream'n
subfan1's Avatar
2019 23' International
La Habra , California
We just put a set of USA Goodyear tires on our Bambi last April. doing well so far. longest trip was to Mammoth and June Lake loop, otherwies weekend beach runs and 3 trips to Desert Hot Springs.
subfan1 is offline   Reply With Quote
Old 07-26-2010, 06:33 AM   #5
Kristi Foster's Avatar
Jonesboro , Georgia
Images: 33
Two Tire Blowouts in less than a Month
We have had two major tire blowouts in less than a month. The blowout this past Thursday did some body damage behind the wheel well. We do not know if all four tires are defective or if the 99 degree temperature was a factor.We are replacing all of the tires, even though they are basically new. AAA RV Emergency Roadside Assistance came to our aid, in both instances, because we were on major high speed four laneClick image for larger version
Name:	tire blow out on 6-27-2010.JPG
ID:	107505 interstates.
Kristi Foster is offline   Reply With Quote
Old 07-26-2010, 06:39 AM   #6
r carl's Avatar
Lin , Ne
How else is a person going to get a stronger tire?
From what i experienced, in a bias ply yes, in a radial no because of their weenie sidewalls. I had 6PR Michelins on my tahoe and tried 10PR Goodyear Silent Armor Pro Grade tires, (because they had a 30day trial) and was shocked that the 10PR tires didnt make my tahoe ride like a lumber wagon. The improved cornering made up for the slight difference the ride. I run with 50psi in them now and may try 45psi when not towing and see what happends. I also run nitrogen.
Old 07-26-2010, 09:23 AM   #7
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Just lost the cap off a Marathon,tore up the fender well molding,and a 3" rip in skin.Tire was a D rated,65# pressure w/nitrogen,and 2.6 years old.I`m going to change them out to Maxis E rated.
Damn shame they can`t make a decent tire. Dave
easyride is offline   Reply With Quote
Old 07-27-2010, 07:36 PM   #8
Ottawa , ON
I can see the 10 plys on your TV, but putting them on the TT will make for a harder ride, so if you do it, watch for popped rivets after your trip. Can't be doing the body much good.
Airstream to this day still recommend ST225/75R15 load range D for all the trailers they make...
Old 07-27-2010, 08:01 PM   #9
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
GYM - forget them!
I had a near distaster with GYM's and will not buy any more. I switched to load range E at 65 lbs. No problems. I should add that I also replaced the 45 year old axle and the ride is like a could (much credit to the new axle). Airstream Life is doing research as we speak on using load range E tires instead of D. They said to look for the article in the Oct. or Nov. issue....Tim
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 07-27-2010, 09:00 PM   #10
r carl's Avatar
Lin , Ne
Radials have a stiff tread and thin sidewalls about like an innertube. Thats why when people put on radials after having bias ply tires they say their trailer rides so nice. It may be a C bias ply tire rides like a E radial tire, wouldnt surprise me. I would bet that a D bias ply that came on on my 30ft rides harder than a new E radial.
Aage, if i put in 80psi in E tires of course it will ride harder, but if i put in 60psi as i do now with D tires it should ride about the same im sure.
Old 07-28-2010, 08:54 PM   #11
SteveH's Avatar
Personally, I don't believe the bulk of the tire failures we are seeing with the ST tires is because of carcass failure, or another way to put it would be the lack of strength in the "D" rated tires. I believe most of the failures, especially the Marathon filures, originate from tread seperation, and then without the tread and tread belt, the body fails.
The Maxxis, Towmaster, and other tires that seem to be staying together have an additional fiberglass belt which helps prevent tread seperation, and therefore tire failure. The Marathon lacks this additional fiberglass belt.
Just got back from a 14.75K mile trip on Maxxis "D" rated tires with no failures. They did, however, wear out, but that is another problem and no fault, I believe, of the tires.
Regards,
Steve
Old 07-29-2010, 09:26 PM   #12
r carl's Avatar
Lin , Ne
Carlisle Radial ST Utility Tire Reviews. Buying Guides & Consumer Product Reviews - Epinions.com
Looks like Carlisle tires blow like marathons.
Old 07-29-2010, 09:34 PM   #13
SteveH's Avatar
Interesting, and it may also interest you that the Carlisle's do not have the extra fiberglass belt under the tread that helps reduce tread seperation.
Regards,
Steve
Old 07-29-2010, 09:55 PM   #14
_
sorry steve but this is nonsense.
tread separation is not the same thing as BELT separation.
one may lead to the other but either can happen independently.
__________
and the notion of fiberglass REALLY dates this tire discussion...
like it's the 60s all over again dude...
http://www.basiccarrepair.com/tire_cord_materials.html
__________
polyester, nylon, steel, kevlar/aramid (other POLY fibers) are hip now.
the maxxis does have a NYLON cap.
the use of a NYLON cap is common on ultra high speed/low profile passenger car tires...
with speed ratings above r (106) a few tires have this cap and above H (~130mph) almost all do...
the theory being at ULTRA high rotational speeds belts may shift/squirm or separate from the centrifugal forces...
and the cap reduces that belt shifting in WIDE/low profile tires traveling at 100-150 mph or faster...
IF this helps on high profile balloon shaped tires used at NORMAL driving speeds is NOT clear.
trailer tires are rotating at MUCH slower speeds
and are NOT cornering or providing traction in the manner a car/truck tire does...
_________
the GYM doesn't have a FULL NYLON CAP (meaning bead2bead) but it DOES have a NYLON BELT...
the belt is REINFORCED at the perimeter
and IS intended to provide the same function as a full NYLON cap,
without losing the 'supple' side wall feature.
cheers
2air'
Old 07-29-2010, 10:01 PM   #15
r carl's Avatar
Lin , Ne
I have 1yr old HI RUN 225 75 15 LRD tires on my 30ft and wondering if i should keep or get rid of them. Im worried about tearing up my wheel wells if one blows.
Old 07-29-2010, 10:04 PM   #16
SteveH's Avatar
Not going to argue, but it does seem the tires that have the extra belt do not have the seperation problems that the Marathons have.
Regards,
Steve
Old 07-29-2010, 10:13 PM   #17
_
unless you have access to a % of problematic tires from ANY vendor...
((and none of us have that info))
the NUMBER of reported problems with any of these tires can be simply a result of TOTAL PRODUCTION...
gyms=10-100s of millions made.
maxxis=a few 100 thousand
greenball/carlisle and other common brands LUMPED2gether, are somewhere in between...
but still just a fraction compared to gyms.
_________
it's baffling that this issue gets REPEATED every few month here with the same old nonsense echoed...
lets blame it on the internet...
the chinese imported walmart sold internet invented by a guy name al...
cheers
2air'
Old 07-29-2010, 11:05 PM   #18
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
I have been running Carlisle "E"s on my 31 for 4 seasons (4K-5K miles/season). I have had zero issues with them! I inflate them (or deflate them) to exactly 80 psi cold every time I leave home.
2 other AS buddies have the same tire, one is a wide body 30 limited and the other is a 70's 31 like mine, both travel about the same as I do with zero problems.
The majority (not all) of the tire problems that I have heard about and witnessed have been due to either old (cracked) or UNDER INFLATED tires.
I have never owned GYM's so I can't speak about them.
A quick note: when truckers have tires heating up, they always add more psi to them which will cause them to run cooler.
I am totally baffled as to why anybody would under inflate thier tires!
To 2air's point this issue keeps coming up and people keep spreading the myth about a harsher ride. I have even heard from some here that AS utilized the softer tire rating in thier suspension engineering. That is BUNK! I have never seen any data from AS about this and I doubt that it exists. For many many years AS installed bias ply tires without a word of a harsh ride from owners. If your trailer is properly set up and the axles and shocks are in full working order, there is no harsh ride, and moving up one letter in side wall rating will have no ill effects IF everything else is right.
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
drag'nwagon is offline   Reply With Quote
7 14.5 Tires Over59 Tires 28 08-17-2010 03:20 PM
tires radials or bias ply tires larry b Tires 22 06-27-2010 06:36 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 11:11 AM
Tires 101 Jim & Susan Tires 18 11-22-2007 10:36 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 05:11 PM
