Old 01-15-2007, 10:34 AM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Mounting tire to 65 Caravel
Getting ready to mount my spare tire to my 65 Caravel, was thinking about mounting on rear bumper and have seen many done this way. My question is, would the extra bouncing weight on the back bumper cause possible frame separation?
toastie is offline   Reply With Quote
Old 01-15-2007, 10:54 AM   #2
S C Streamer's Avatar
1964 17' Bambi II
Santa Cruz , California
Images: 13
Hi toastie,
Here is a different option...
IMHO,I really like the clean unclutterd look of the rear of the Caravels...
and no problems with the frame by using the tounge.
Mark
1964 17' Bambi II
2005 Dodge 2500 PowerWagon -5.7 Hemi
WBCCI #4207
AIR #11485
"you don't need a weatherman to know which way the wind blows" ~bob dylan
S C Streamer is offline   Reply With Quote
Old 01-15-2007, 11:01 AM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Yes, there are a couple of years that it was done in the '62/63 range, but it's not recommended. The extra weight bouncing around back there is not good. There are several threads with options for "spare tire carrier (or mount)" options that you can find with the search tool.
Ours has the tongue mount (like Mark's) and I actually detailed it in CADD for someone some time ago, here's a link: http://www.airforums.com/forum...tml#post150186
Shari
Old 01-15-2007, 11:10 AM   #4
toastie's Avatar
1955 22' Safari
Originally Posted by S C Streamer
Hi toastie,
Attachment 30840
Attachment 30841
What a great looking Bambi II, do you having any side photos showing how the tire was mounted........thanks
Old 01-15-2007, 11:14 AM   #5
1964 17' Bambi II
Images: 13
Just for the record, the trailer pictured is not mine. But I wish it was.
Eventually I will mount my tire on the tounge, but lots of things are ahead of that on the long restoration list.
Mark
1964 17' Bambi II
WBCCI #4207
AIR #11485
Old 01-15-2007, 11:22 AM   #6
toastie's Avatar
1955 22' Safari
Eventually I will mount MY tire on the tounge, but lots of things are ahead of that on the long restoration list.
I was looking at this design for the rear, would like to see more pictures mounting the spare to the front........
ID:	30843   Click image for larger version
Old 01-15-2007, 11:30 AM   #7
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
I vote no on the rear bumper mount. I included a few pics of my solution.
It works well and I can still remove the propane tanks to get them filled. I usually only take one tank off at a time to fill. Even if I took both tanks off the tire would only move as far as the eye in the bolt will let it.
You don't really want to attach anything to the rear bumper. There is too much risk of damage of some kind to the frame to floor to shell attachment points.
There are larger pics in the "my photos section"
I like the idea in post #6, but I see a lot of $$ wrapped up in mounting a spare tire. Plus 90% of the weight is still on the very end of the trailer.
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 01-15-2007, 12:27 PM   #8
toastie's Avatar
1955 22' Safari
Chris
Your running an eye bolt thru the tire to the vertical rod that is used to hold the propane tanks, is that what I'm seeing............thanks
Old 01-15-2007, 01:42 PM   #9
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Originally Posted by toastie
Chris
Yes, that is correct. I have a regular nut and fender washer on one side and a fender washer and a wing nut on the other. It pretty much stays right where it sits. The tire just sits on the frame/tounge. My vertical rod is about one to two sizes bigger than what is offered at the RV store. So I figure it can handle what little stress there is on it. I still have to get a cover for the tire. When my trailer is parked it faces south.
Project 2k5
Old 01-15-2007, 01:53 PM   #10
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Spare Tire Mount
My 1964 Bambi II has the spare tire mounted as in post # 2. (but my trailer is nowhere near that shiney)
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 01-15-2007, 02:04 PM   #11
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Spare Tire
We just installed a spare tire rack under the front of our 1969 27' Overlander behind the trailer hitch. Seems that there was a good space for it there and eliminates carrying it in the truck or mounting on rear which we think a previous owner did. We did not want the weight of that tire bouncing on the back of our trailer and besides mounting it there would interfere with the access to the battery, etc.
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 01-15-2007, 03:49 PM   #12
toastie's Avatar
1955 22' Safari
What a clean design, very parts and does the job, what is the dia. of the vertical rod, my is 1/2 inch........thanks
Old 01-15-2007, 05:30 PM   #13
InsideOut's Avatar
1956 22' Safari
Images: 108
Musta been a '64 thing...that's how ours is too.
(before polishing tanks & trailer)
Shari
Old 01-15-2007, 07:31 PM   #14
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Mine is half inch too. You must have the original rod. The newer ones are a bit smaller in Dia. Something like 3/8 or 7/16
Project 2k5
caravel
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
spare tire? Chas Tires 14 07-04-2005 07:09 PM
Tire opinion Dbraw Tires 12 11-25-2002 07:39 AM
Restoration of our Airstreamer Caravel Hagen 1965 Caravel 2 11-10-2002 02:15 AM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 04:40 PM
