08-25-2018, 09:18 PM
2016 30' Flying Cloud
Port Saint Lucie
Mixing endurance and marathon
Had a blowout today using 2016 marathon 225 75 15
Hit some debris on i81 just north of Roanoke. Virginia road ranger via Virginia HP WAS MAGIC. THANK YOU GUYS.
Anyways am homeward bound to Florida. So my plan is to replace the blown tire with endurance and use it as a spare for the remainder of the trip running with four marathon and then replace the other marathons when back home.
Is there any major down side to this plan?
08-25-2018, 10:02 PM
2007 22' International CCD
Corona
Many on the forum would seriously consider changing out ALL the GYMs instantly. Drive carefully
08-25-2018, 10:38 PM
2017 30' International
Broomfield
You’re fine. Definitely inspect the others.... if they look good head on home.
Good plan to replace all with endurance tires - much better tire.
08-26-2018, 02:22 AM
Sag Harbor
, New York
Yes, the loss of life for you and your family, unless you don't consider this to be "major." Oh, and the loss of your AS.
Sounds like you dodged a bullet. Personally I would follow this advice:
What are the dates of manufacture on your tires, including the blown tire?
https://www.tirerack.com/tires/tiret...jsp?techid=172
Any tire older than 5 years is suspect IMO, especially GYM's.
Good luck,
Peter
08-26-2018, 02:43 AM
Sag Harbor
, New York
Would you recommend inspecting the DOT date of mfg. for each tire?
08-26-2018, 04:14 AM
Chelsea
, Maine
You have a ‘16 FC, so the tires are likely 3-4 years old.
I would inspect for damage, and finding none, run them home and look for a good deal at that point.
I would not hesitate to run an Endurance with 3 Marathons. The tires simply support weight and spin, it’s not like there’s a differential that might get smoked due to mismatched tires.
Check pressure and keep your speed below 65 per the tire rating. You’ll be fine.
2023 Entegra Odyssey 26M
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
08-26-2018, 06:15 AM
2017 25' Flying Cloud
Fayetteville
, Arkansas
I thought this was a workout and physical training thread...[emoji17]
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn”
2023 F150 XLT
08-26-2018, 06:44 AM
CapriRacer
I'm in the
, US
I find it interesting that the OP states he hit some debris and many folks are ignoring that information in their recommendations.
People, tires are not immune to road hazards. You can argue that a Marathon has some issues, but this wasn't the result of that.
CapriRacer
Want to learn about tires? Please visit my website: Barry's Tire Tech New content every month!
08-26-2018, 06:50 AM
Sag Harbor
, New York
Good points but without knowing the DOT dates, everyone is flying blind IMO.
There are plenty of posts about older tires being in the mix, for whatever reason.
Why not take 5 minutes to check? An utterly simple owner awareness task . . .
Reward >>>>>> risk.
Peter
08-26-2018, 09:20 AM
2013 28' Flying Cloud
Penn Yan
, New York
Tires
I would not hesitate continuing back home with the Marathons. I hope u have tire monitors.
I would definitely check the remaining tires to insure they were not damaged.
Good luck.
08-26-2018, 09:49 AM
Lin
, Ne
I'm still wondering why ST tires pick up nails and hit potholes that cause it to fail far far more often than LT tires.
08-26-2018, 10:16 AM
2014 25' Flying Cloud
Temple
They usually blow out because of tire failure - this does not seem to be your issue, to take it home but replace the GYM asap, this spring we had a GYM failure on out 2014 FC and by the time we got home on our spare a second tire was separating - you are on the verge of problems with the GYM.s BTW we did get four new marathons - also our FC was in the body shop for a month forcing us to miss prime spring travel.
2014 Flying Cloud 25FB
2018 Ram 2500; Cummins
Blue Ox WDH
08-26-2018, 03:26 PM
Argyle
Forget the brand. We had specific "trailer"tires that our tire person for 25 years deemed suitable. That blowout in a 25 foot cost over $3,000. In a 28 foot we had the same situation that cost us us $1,600. Not worth it. Put new tires on - new "trailer" tires. There is a difference. Good luck - as I am pretty sure you took the advice to drive through to home with what you had.
08-26-2018, 03:31 PM
Port Saint Lucie
I found a good shop only a small detour away and after consideration and talking to the other happy airstream campers where I’m parked up, I’m going for the full replacement program since the shop can get stock and fitted midday Tuesday
People here also mentioned metal valves and inflation at a much higher pressure than the marathons
2016 Flying Cloud 30 Rear Bedroom with 2 a/c + window awnings.
2014 GMC Sierra 3500HD SLT Crew Cab Duramax 2WD
08-26-2018, 05:33 PM
1965 24' Tradewind
almena
, Wisconsin
Mixing tires on single tire axles!!!
The answer to your question is no! Run ‘em ‘til they’re worn out or too old!
Motor On!!!
08-26-2018, 05:42 PM
Sag Harbor
, New York
Excellent news, and a wise decision!
Peter
08-26-2018, 06:46 PM
Broomfield
Yup. Lost a one-year-old Goodyear marathon today to a road hazard. Stuff happens…
08-27-2018, 01:44 AM
Port Saint Lucie
Psi on endurance tire 225 75 15
This tire is rated to 80 psi. E ratind
The marathons are 65 psi are D rated
I have alloy wheels. - can they take the higher inflation pressure of the endurance and is that wise given the sticker on the trailer stating 65 psi - I presume because the marathons came as standard and they max out at 65
08-27-2018, 06:25 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
80 PSI is the maximum which is only needed if you have a load of 2,380 lbs per tire (ST225/75R15)! Why not weight your trailer axles, then check the load/inflation tables and inflate to an appropriate pressure that won't contribute to damage to your trailer because of too stiff a ride and still carry the load?
Ray B.
