Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 08-20-2009, 07:04 PM   #1
Profile:  1997 25' Safari
Celina , Ohio
Mixed bag of tires
Currently on my 25ft Safari I have 2 Tow Masters on 1 side and a mix on the other of a Super Trail (?) and a Carlisle. The Carlisle is toast. A recent exam after a short trip shows steel on the inside edge. The trailer is in park until I replace the ST and the Carlisle. The Tow Masters still have excellent tread and show little signs of wear. I would like to keep the two Tow Masters but mount them on the rear axle. And, buy 2 Maxxis or Goodyear Marathons for the front. Am I wrong to consider this approach, or should I suck it up and get 4 new ones. Another question is what caused the Carlisle to wear so worn that the steel belt is visible and only on the extreme inside edge.
FYI. the 2 TMs are Canadian about 4yrs old. The Carlisle about 6 and Made In China. the other, who knows.
tinhut is online now   Reply With Quote
Old 08-20-2009, 07:57 PM   #2
lynn's Avatar
Profile:
Airstream Service Center in JC carries TowMaster 15" "E" rated tires. They also come with a road side assistance as part of warranty.
lynn is offline   Reply With Quote
Old 08-20-2009, 08:14 PM   #3
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
wear on one side might indicate an alignment issue.
Axle alignment in Oregon
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 08-21-2009, 04:40 PM   #4
Celina , Ohio
It will make sense to have Airstream install 2 Tow Masters and check out the alignment. Fortunate for us, we live 30 miles from Jackson Center. We have been there a few times and had work done, stayed at their Teleport campsite for free
while the AS was in the shop. Only question I have now is that the 2 TMs I have now are LR ""C....I would not want LR "E" on the other axle. I assume that JC has "C" s also.
Old 08-21-2009, 06:08 PM   #5
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Just my personal opinion TinHut get 4 new ones .If one of those comes apart the damage may be sevier and then you will really have to go to JC.Tires at 4 yrs old are about at the end of their useful life no matter what the tread looks like. Just my opinion, I think Four new tires are in order all the same brand so the rolling radius is all the same and make sure you have all the same ratings. Save two of the best for spares.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336
My your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 08-27-2009, 09:20 AM   #6
Celina , Ohio
An update on the Carlisle tire with exposed steel: Bearing failure, the inside bearing was toast. Installed all new yesterday with parts purchased at AS in Jackson Center. They changed the race gratis. WOW what a crew. Also made an appointment to install four Goodyear Marathons moving up to D load range. FYI, they will install Tow Master LR E only if you upgrade the rims. Also will add new shocks to this visit as the ones on now are most likely the same age as the tinhut..(1997) any more suggestions
I may get them to check alignment but, I do think the tire failure was due to a failed bearing.
Old 09-02-2009, 08:17 PM   #7
Celina , Ohio
Another question before I take off for Jackson Center. After removing wheels and repacking the bearings I found the date code on the inside of the Tow Masters to be 4206. That makes them about 3 years old. Once again, they do look like new. Issue is that AS now sells LR "D" for the 25 ft trailer. I moved both TM's to the rear axle anticipating putting 2 new Marathons LR D on the front axle. What problem (if any) is there with C's on the rear and D's on the front. Is this tomfoolery or does it make a whole lot of difference.....tinhut
Old 09-04-2009, 10:43 AM   #8
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
You know I wouldn't recommend it and I have done this.
Isn't there a load capacity weight rating in actual pounds? I believe a "C" rating is somthing like 1880. With all "C" rated tires that would give you a capacity of 7500+ pounds at max tire pressure. If your fully loaded rig is 6000#'s or less, I would stick with "C" all the way around.
If the above fits, "D" rated tires will be more expensive, provide a rougher ride and not offer any more benefits. If over 6000 #'s fully loaded then my suggestion is it is OK to go to "D" rated tire.
Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 11:11 AM
Which Tow vehicle?? Mixed answers...help! tmarquis Towing, Tow Vehicles & Hitches 54 06-15-2009 08:14 AM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 05:11 PM
Air Bag alfalsetto Mechanics Corner - Engines, Transmission & More... 5 09-27-2003 10:16 AM
What's this? Radiator bag? TinCanSue Our Community 4 07-30-2003 08:01 PM
