Old 06-04-2013, 09:54 PM   #1
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
Michelins on vintage Airstream
Has anyone verified that Michelin LTX M/S 2 P235/75 R 15 tires will fit in wheel well and run smooth on a 1960's single axle Airstream?
I've read threads for days, all I find reference use of Michelin LT tires on newer Airstreams.
Currently running P225 Marathons.
Would like to install Michelins LTX P235s on 1964 Safari with new 15" wheels.
Specifically on wheels from Andy (Part# 11147, 2600 pound rated, 15 x 6 steel, 6 lug on 5 1/2" bolt circle).
I like the Michelins LTs on my SUV and have had more than my share of "issues" with GY Marathons and Carlilses.
Sorry for another tire thread.
Safari64 is offline   Reply With Quote
Old 06-05-2013, 01:48 AM   #2
2005 19' Safari
GLENDALE , AZ
See short summary of tire posts on this forum, at link below:
http://www.airforums.com/forums/f438...ml#post1292576
Also, enter "235/75x15" in SEARCH window to locate individual posts on this subject.
Old 06-05-2013, 06:49 AM   #3
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
confirmed. we installed these on our 62 globetrotter.
from my receipt: P235/75R-15 Michelin LTX M/S2 XL
on edit: we felt it was a good choice. we've been up to philly and back to NC on them. they are still relatively new, but there is plenty of clearance. we have new wheels and axle.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 06-05-2013, 07:58 AM   #4
Melody Ranch's Avatar
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
will and won't
I tried the 235 x 75 x 15 on my 66 Caravel and they would not fit. I run those same wheels and tires on the Bubbles and the Cloud and they are fine.
Old 06-05-2013, 12:54 PM   #5
Safari64's Avatar
1964 22' Safari
Thank you,
That's what I was looking for, specific experience with Michelin LTX 15" fitted on 1962-66 Airstream single axle trailers.
thanks
Old 05-07-2014, 09:25 AM   #6
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
This thread is the only one I have found addressing my question. I would be interested in running a LTX tire on my 65 Caravel. I have to get new wheels and tires. I was looking at VTS narrow 15" wheel that is 5" rim width, but can't find LTX tires to fit that size rim. If I went with a 6" rim is there an LTX tire that would fit my Caravel? any experience with mid 60's Caravels here? The wheel well is tight!
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 05-07-2014, 09:41 AM   #7
DFlores's Avatar
1968 22' Safari
I have been looking to run the LTX tire as well, my research has come up with an alternative......Maxxis TL 15713000, 225/75r15 with a weight rating of 2,830....but I sure would appreciate any input from someone with actual experience with this product.
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 05-07-2014, 10:18 AM   #8
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
I was looking at the Maxxis too. I think it is the most respected brand of trailer tire by many. The 205/75r15 will fit the 5" wide rim and Maxxis makes that size. However, I am thinking now I might get the 6" rim, so I can have the option of using a 225 tire if I decide to go with LTX tires. I am just not sure the combo will fit in my Caravel wheel well. If there is anybody out there that has confirmed the 6" wide wheel and 225/75r15 combo will work let me know.
Old 05-07-2014, 10:30 AM   #9
r carl's Avatar
Lin , Ne
Please don't even consider a china tire. Do the right thing and get these.
http://www.tirerack.com/tires/tires....rtnum=700R5215
Old 05-07-2014, 11:49 AM   #10
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
That's one I haven't considered. I'll take a look at it. Made in Japan is probably better. I don't trust most Chinese tires either, but it has to do with the quality control from the manufacture. If the manufacture is strict enough there are some good Chinese tires. I think Maxxis has this down, unlike Goodyear.
Old 05-07-2014, 12:18 PM   #11
safari62's Avatar
1962 22' Safari
1957 22' Custom
Vacationland , Maine
Images: 43
It is time for me to renew my tires and am also looking to try another brand. Michelin LTX or Yokohama???
This would be for the 62' Safari. Load range D OK?
Gary
wbcci #3363
VAC - Region 1 vintage Club rep
New England unit
safari62 is offline   Reply With Quote
Old 05-08-2014, 10:06 AM   #12
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
Ok. I have been digging further and have come to the conclusion after reading as much here as I can that 225 tires won't fit the Caravel. I will be ordering 5" wide wheels and put on 205 tires. Last night I checked the old ones on my trailer and they are 205/75 R15. I was not sure the old tires and wheels were correct, but it looks like they are, so I now know what to order. I can't find Michelin LTX in this size, so I guess I will be either going with a trailer tire or another brand truck tire. I'll get the wheels first, then choose a tire. More thinking to do...
Old 05-08-2014, 10:29 AM   #13
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
You might consider these-
GoodYear Wrangler HT LT 215/7515 LRD
Lance
Top is offline   Reply With Quote
Old 05-08-2014, 12:24 PM   #14
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
Thanks for the suggestion but those are still too wide. 215 minimum rim size is 5.5" width. I will need 205.
