Old 05-08-2014, 01:38 PM   #15
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
OK well then how about these?
Continental Vanco 2 or GoodYear Cargo G26
I installed a pair of the Contis on the last Caravel I worked on. It was a new axle installation as well, so I changed the hubs to 6x5.5 pattern.
The new rims were from etrailer. Dexstar brand.
https://picasaweb.google.com/lh/phot...eat=directlink
Lance
Top is offline   Reply With Quote
Old 05-09-2014, 03:42 PM   #16
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
Lance,
Very nice work! I looked through your pictures and it looks like there is plenty of room there. I'll take a look at these 195's. They look like they aren't much smaller than the 205 size, so this might be an option for me. I don't know why they don't make 205 size in truck tires, but maybe these will be a good replacement size. Thanks!
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 05-18-2014, 10:36 PM   #17
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
Well, today I finally installed new Michelin LTX M/S 2 P235/75 R 15 tires on new wheels from Andy (Part# 11147, 2600 pound rated, 15 x 6 steel, 6 lug on 5 1/2" bolt circle) on my '64 Safari. Seem to fit nice. Installed Centramatic balancers as well. Haven't hit the road yet.
The Michelin side wall says max inflation 50#. The old Marathons ran at 65#.
What should Michelin LTX tire pressure be for trailer use?
Road trip!
Safari64
Safari64 is offline   Reply With Quote
Old 05-19-2014, 03:12 AM   #18
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
If you weigh it sometime you can set your pressure to the weight you are carrying. In the mean time run them at 50 PSI to be on the safe side. You should notice a considerably better ride on the single axle.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 05-19-2014, 04:03 AM   #19
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Road trip!
Safari64
Hi there. Where did you get the figure of 2600 pound rating on these tires? That sounds like a lot of capacity but I don't think these tires have that much.
Mine are stamped with 2183 on the sidewalls and that has to be derated 10% as they are a passenger tire being used on a trailer. So they actually have 1984 pounds of capacity per tire.
How much does your trailer weigh loaded for camping?
http://m.tirerack.com/tires/specification.jsp
Old 05-19-2014, 04:06 AM   #20
W , New England
Oh and on the pressure, I asked the same question and got a full 50 psi answer from some of the tire experts on the forum.
Old 05-19-2014, 06:13 AM   #21
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
SteveSueMac,
The 2,600lbs Safari 64 is referring to is for the new wheels.
Lance
Old 05-19-2014, 10:51 AM   #22
W , New England
Originally Posted by Top View Post
SteveSueMac,
Thank you. Second time this morning my ignorance was fully on display. :-)
Old 05-20-2014, 09:13 PM   #23
Safari64's Avatar
1964 22' Safari
Thanks for the help.
Tires set at 50 PSI....will test them out soon.....awaiting good Alcan road conditions....happens on a Tuesday this year.
Old 05-23-2014, 07:54 AM   #24
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
Yoko/mich/GM
I did go with the Yokohama RY 215 replacing the Goodyear Marathons after going over the time limit a bit too far.
I stretched the life as we did not travel so much last year and they did not look so good on closer inspection after they were removed. One Chinese & one Canadian. The China GM had a strange dip in the sidewall.
The Yokohamas are expensive, made in Japan, radial steel belted D rated. They do look "Vintage" being tall and narrow like the old Goodyear Workhorse trailer tires. I like this look but it does increase work when removing them.
I will also have to adjust the setting on my Equilizer hitch as the trailer sits higher at the axle. Oh joy.
My guess is the new tires with ride firmer then the former GM's. I always felt they were soft and noticed extra bounce when slowly crossing rough areas inflated to 55 psi. The Yoko's being radials I hope there should be more give to go easier on the trailer itself.
Gary
wbcci #3363
VAC - Region 1 vintage Club rep
New England unit
safari62 is offline   Reply With Quote
