Old 02-17-2016, 10:37 AM   #71
Ravenna , Ohio
Originally Posted by avionstream View Post
Possibly the rubber compound gets harder as it gets colder?
I know for a fact that most high performance "summer" passenger tires will have tread compounds that do get harder in the cold. I have even seed tread rubber on ultra-high performance tires crack and shatter due to extreme cold.
Now the XPS rib is not in the same category as these HP tires but if Michelin says they are "summer" tires then I would not consider them suitable for operation in snow conditions.
Tireman9 is offline   Reply With Quote
Old 02-17-2016, 11:56 AM   #72
Long Island , New York
At the risk of being a bit OT, are you familiar with Nokian snow tires, and the compounds they use for good adhesion to the pavement in cold weather? I have read on other forums that they really work, but must be taken off as soon as winter is over, as they wear down quickly on pavement.
Peter
OTRA15 is online now   Reply With Quote
Old 02-24-2016, 12:21 PM   #73
Mixter's Avatar
1976 27' Overlander
Originally Posted by Ted S. View Post
After tons of research, my Michelin XPS RIB vs. LTX M/S2 debate is over.
I'm going with the LTX M/S2.
What led you to this decision?
Also, has anyone had any issues with a tire dealer putting the Michelin LT tires on a trailer? I have heard of tire places saying they wont put anything but a trailer tire on a trailer....
Mixter is offline   Reply With Quote
Old 02-24-2016, 01:32 PM   #74
Echelon73's Avatar
2010 30' Flying Cloud
Mocksville , North Carolina
I ended up choosing the LTX M/S2 over the RIB. As much as I wanted the RIB, I just decided it was probably not worth the extra money (which was significant). I based this on the success everyone is having with the LTX M/S2. I also decided the LTX may have slightly better grip which could help with braking and hydroplaning resistance. I still would love to try the RIBs though. Maybe someday when I have more money laying around or they offer a great deal on them.
Echelon73 is offline   Reply With Quote
Old 02-24-2016, 01:43 PM   #75
Mixter's Avatar
1976 27' Overlander
Who's mounting & balancing these for everyone?? Everywhere I read that tire shops will only mount tires spec'd for the vehicle. I dont see where the LTX M/S2 is spec'd for Trailers.
Old 02-24-2016, 02:10 PM   #76
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Discount Tire in Mesa, AZ installed the 15" Michelin LTX (P) 235/75R15 XL tires onto the SenDel T03-56545T 15" wheels along with the senders for the Dill 1506-453 TPMS system. I purchased all three items from them for our 23D. They were aware of the intended use ands still gave me a warranty. I installed them when I got to the dealership on the East coast.
CostCo in Mesa, AZ mounted the 16" LT225/75R16/E LTX M/S2 tires onto my SenDel T03-66655T wheels along with the senders for the Dill 1506-453 TPMS system for our 2014 31' Classic. In 2015 this tire and wheel combination became standard on the 31' Classics. They were available on all the Eddie Bauer models and for sale at the Airstream Service Center in Ohio as you entered by the Customer entrance.
I personally installed the 16" tires and wheels in the storage area as soon as I got the Classic off of the dealer's lot.
Old 02-24-2016, 02:13 PM   #77
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Most tire shops do not have data for trailers. And I am sure if you brought down a set of rims to have tires mounted and told them it was for a trailer you would leave with tires mounted on rims. There isn't much liability on the part of a tire shop to mount anything on a vehicle not designed to carry humans.
>>>>>>>>>>Action
Action is online now   Reply With Quote
Old 02-24-2016, 04:41 PM   #78
2015 30' FB FC Bunk
Ayer , Massachusetts
The biggest factor was that the Rib is a summer tire and I tow in the winter.
Ted S. is offline   Reply With Quote
Old 02-24-2016, 05:05 PM   #79
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I called a local (New England) Town Fair Tire and explained what I wanted (15" P rated Michelins on my 27FB). Brought the trailer to their shop and had them installed directly on the trailer with internal TST TPMS sending units.
SteveSueMac is online now   Reply With Quote
Old 02-24-2016, 07:28 PM   #80
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Unless your trailer is self propelled this is not a issue.A trailer just follows your tow vehicle and traction is not a issue.
It is a issue for your tow vehicle as it needs traction for pulling and turning.
Old 02-24-2016, 08:21 PM   #81
2015 30' FB FC Bunk
You are probably absolutely correct.
Old 02-24-2016, 09:35 PM   #82
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Ahh....unless you're towing at around 9,000' and the rain turns to sleet and then snow in less than a mile and your trailer decides it wants to go faster than the tow vehicle...and all of a sudden it doesn't want to just follow.
That was the tightest U-turn I've ever made with a 28' trailer on a two lane highway!
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 02-24-2016, 09:54 PM   #83
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
When we purchased the XL P tires and Sendel wheels for the 23, America's tire rep called me back to make sure that I understood the tire was rated for about 1800 lbs. For a 6000 lb gross weight, that is a lot of headroom. They had no problem mounting the tires to be used on an Airstream. As it turned out, I installed them at home, because I needed to wait for the Centramatics to arrive.
Do not plan on traveling on snow covered roads, but conceptually I really like the better traction of an all weather tire. Pat
Old 02-25-2016, 05:22 AM   #84
Ditto to mojo and PKI. When the conditions call for it, a more aggressive tread is needed -- snow, turning, downhill braking, etc.. Pinching pennies can get expensive, looking in the mirror with hindsight.
Better safe than sorry . . .
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Michelin LTX LT 235/75-15 JakeSpoon Tires 63 07-03-2015 04:18 PM
Michelin XPS Ribs (225/75x16) on our 19-foot Bambi Phoenix Tires 16 01-29-2011 11:32 AM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 05:21 PM
Michelin 235/75R15 LTX M/S vs Marathon ST225/75r15 EXCEL88 Tires 3 06-16-2008 07:41 PM
