Old 07-11-2015, 12:30 PM   #57
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Originally Posted by JamuJoe View Post
BTW, getting the spare in and out of the spare carrier is a lying on the ground, knuckle scraping PIA. I surely could wish for the rear bumper carrier on my last trailer, or at least a cable suspend system common on many cars.
Jamu Joe
After JC adjusted my spare carrier, unloading or loading it from under the front of the AS is the same as it was beforehand, when I had the OEM 15" tires/wheels. Maybe you just need to have the rack adjusted.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 07-12-2015, 10:25 AM   #58
2011 23' Flying Cloud
Durango , Colorado
The spare tire access holder is just the same as originally with the 14" tire. It is simply an awkward design with several inherent safety hazards. Airstream could do much better for little added cost.
Safe Travels,
Jamu Joe
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 02-13-2016, 07:12 AM   #59
2015 30' FB FC Bunk
Ayer , Massachusetts
As mentioned earlier, Michelin states the XPS Rib tire is a "Summer" tire. What was not mentioned is that there appears to be a comparable tire which is "All Season". It's called the XPS Traction and is slightly more expensive.
I'm curious what makes the tire suitable for its environment. If it is just the tread, the the Rib would be my choice for a trailer because I don't need as much traction. But if it is tire composition, then I'd go with the Traction.
What is interesting is that they state 'not intended for cold temperatures first' then talk about snow and ice. It's as if they are saying stay out of the cold...period.
Crack. Pop. Bang.
Ted S. is offline   Reply With Quote
Old 02-13-2016, 07:54 AM   #60
Gainesville , Florida
Possibly the rubber compound gets harder as it gets colder?
Old 02-13-2016, 08:26 AM   #61
r carl's Avatar
Lin , Ne
Its got a rib tread not an all season tread.
Old 02-13-2016, 10:00 AM   #62
2015 30' FB FC Bunk
I see that, but is that the only difference?
Old 02-13-2016, 05:17 PM   #63
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Michelin XPS RIB vs. LTX M/S2
The tire is completely different with a thicker sidewall and a higher quality build.Fedex and UPS use the Ribs on delivery trucks due to durability and long wear.I have been using Ribs in a 16 inch for over 30,000 miles on our 28ft International.They show no wear and have even wear.I run 65-70 psi.
Old 02-13-2016, 08:46 PM   #64
2015 30' FB FC Bunk
I'm going to be a total geek and run out and examine the tires on the next FedEx or UPS truck that comes to my house. Meanwhile, the Michelin web site states the following:
Summer tires are primarily designed for high-performance vehicles and provide optimal dry and wet performance levels in a temperate environment. Summer tires are not designed to be used during the winter season where temperatures are colder and approach freezing consistently as their performance would be less than optimal.
Is it really just tread design that makes it summer only.....
Old 02-14-2016, 04:57 AM   #65
Long Island , New York
Originally Posted by Ted S. View Post
[snip]
I will venture a guess that the rubber compound is different to maximize the tires' grip on the pavement in warm weather, similar to Nokian snow tires which offer a softer compound for cold weather use. I have never used these, but folks from the northern climes swear by the traction afforded when the Nokian tire rubber meets cold road pavement.
Perhaps the tire experts here could comment?
Peter
Old 02-14-2016, 06:57 AM   #66
CapriRacer
CapriRacer's Avatar
I'm in the , US
The Michelin XPS Rib is not only a commercial summer rib tire, it is also a steel ply tire - compared to the Michelin LTX M/S2 which is an all season as well as a polyester/steel construction.
This means that the XPS Rib is designed for retreading and heavy service, like on UPS and FedEx trucks, where the emphasis is on longevity, as opposed to LTX M/S2 would be more designed for consumer usage on a pickup or van, where the emphasis would be on fuel economy, traction, and soft ride.
CapriRacer is offline   Reply With Quote
Old 02-14-2016, 07:35 AM   #67
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Crack. Pop. Bang.
I may be wrong, but I think Ted is asking about the difference between the XPS Rib and the XPS Traction.
Lance
Top is offline   Reply With Quote
Old 02-15-2016, 08:15 PM   #68
2015 30' FB FC Bunk
So anyway, I found some interesting info. on the Michelin website from a link someone on Airforms posted on another Thread. Bottom line, it appears the summer tire has a different composition, which hardens and looses traction in colder temperatures regardless of snow and ice:
Do I need winter tires?
Yes, if you live in an area where the ambient temperature regularly approaches freezing point below 44░F or gets heavy snow or ice then you will likely need winter tires. At that temperature, the rubber on standard tires starts to harden and can lose its grip.
More here:
http://www.tirerack.com/tires/tirete...jsp?techid=273
Old 02-15-2016, 08:58 PM   #69
Adiredneck's Avatar
2014 27' FB Classic
Vicksburg , Mississippi
However the FedEx and UPS trucks use rib tires on a 19.5 tire - a true "truck tire". Do not confuse the construction and load rating of a LT tire (16", 17", 18", 20") with a true commercial truck tire (16.5", 19.5" etc.). Different beasts altogether. A few years back, when I had a 11.5' slide in camper in my pickup with SRWs, I looked into upgrading from the LT wheels/tires to commercial grade 19.5" rims/tires and came across these guys who made the rims for GM, Ford and Ram trucks:
http://www.ricksontruckwheels.com/
I may still get a set for my current TV, even though I don't have all the weight of a slide-in. Nothing to slow me down but money...
Tim
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
Adiredneck is offline   Reply With Quote
Old 02-15-2016, 09:11 PM   #70
2015 30' FB FC Bunk
After tons of research, my Michelin XPS RIB vs. LTX M/S2 debate is over.
I'm going with the LTX M/S2.
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
Michelin LTX LT 235/75-15 JakeSpoon Tires 63 07-03-2015 04:18 PM
Michelin XPS Ribs (225/75x16) on our 19-foot Bambi Phoenix Tires 16 01-29-2011 11:32 AM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 05:21 PM
Michelin 235/75R15 LTX M/S vs Marathon ST225/75r15 EXCEL88 Tires 3 06-16-2008 07:41 PM
