Old 01-20-2014, 02:05 PM   #71
Zigidachs's Avatar
2011 30' Classic
Ridgefield , Washington
HI
Four "shoes" for our AS replaced this morning via warranty recall. Spare was out of recall time frame.
"The Catch"…Michelin only paid the store $20.00 / tire to complete all the paperwork, and mount the tires!!!!! I'll bet it didn't even cover their costs of keeping the store open. I was happy for the new tires, but frustrated for the dealer. Zigi
Zigidachs is offline   Reply With Quote
Old 01-20-2014, 05:48 PM   #72
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Doesn't make sense that they would cheap out on that. My shop had the paperwork and it stated free replacement without any other catches that I am aware. Got new high pressure valve stems, etc. I was dead set on road force balancing and was prepared to pay the difference, but they said it was all good.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 02-04-2014, 10:19 PM   #73
1972 31' Excella 500
Mount Vernon , Is For Lovers
Consumer Report 3/14
LTX M/S LT 225 75R16 recall Safety Recall : MICHELIN LTX M/S | Michelin Tires Nothing new for this informed group. Happy trails
Sylver Slypr is offline   Reply With Quote
Old 02-16-2014, 03:19 PM   #74
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
I don't know if anyone has tried to get tires replaced lately under this recall but I'll tell what I experienced with it. Due to being winter here and the EB stored I didn't start to deal with this until about 3 weeks ago. It turned out all 5 tires on our Eddie Bauer were affected by the recall. First there are only 4 Michelin dealers in town and the first 3 said they couldn't get tires and couldn't (wouldn't in my opinion) help.
The last option was the Ford dealer and these guys could not have been nicer. Only problem was after several calls they made to their normal wholesaler and then to Michelin, they found that indeed there were no Michelin tires available. Michelin told the Ford dealer they were not keeping up and then authorized any BFG or Uniroyal tire. Since we are leaving shortly for a long trip we went with BFG tires in the same spec, i.e. size, load range etc.
So if you need to get tires replaced under this recall you might want to plan ahead a little.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 02-19-2014, 02:04 PM   #75
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Have not seen any mention of this yet but if you happen to be going to Jackson Center you can get the replacement done there. Just made appointment to have mine done in mid-May when I'll be in the area for the Dayton Hamvention.
Al - K4GLU is offline   Reply With Quote
Old 02-20-2014, 09:09 PM   #76
2014 27' Flying Cloud
Seattle , Washington
Michelin tire recall LTX M/S LT 225/75R16 E
Hi,
In case this has not yet been posted (I have not checked that it has), I thought I would pass it along. This is the safety recall link for the LTX M/S LT 225/75R16 load range E tires. You will see that the date range is: January 2010 - June 2012, and there is also a picture of the DOT information to look for on the sidewall of the tire.
Hope this helps.. apologies if this is a redundant post!
streaminlife is offline   Reply With Quote
Old 02-21-2014, 05:37 PM   #77
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Glad you could get tires and I'm not surprised Michelin is out of tires. Goodrich is Michelin's cheaper brand. They came on our Tundra years ago and didn't last and rode badly, though our new FJ Cruiser came with Goodrich also and we'll see how they last. Did Michelin say they would replace the Goodrich's with Michelin's when they were available.
Gene
Gene
Old 02-21-2014, 05:47 PM   #78
crisen's Avatar
Fairbanks , Alaska
Gene
It is a one shot deal, the BFG are it. Goodrich has been around for donkey's years, as you say probably not the top brand available but since we're leaving next week on a 10000 mile trip, new BFG instead of Michelins with a known problem seemed like about the only smart decision.
Rick
Old 02-21-2014, 05:53 PM   #79
Master of Universe
Gene's Avatar
Rick, I understand and because of our experience with Goodrich, we would have probably taken the Uniroyals. Michelin has owned Goodrich for quite a while now, and the ones we had in 2007 may be very inferior to the ones they make now. Hope so.
Enjoy your trip.
Gene
Gene
Old 02-22-2014, 12:52 AM   #80
2005 19' Safari
GLENDALE , AZ
These might be a good alternative for those with 16-inch wheels:
http://www.tirerack.com/tires/tires....m=275R6COMMTAE
Old 03-05-2014, 04:55 PM   #81
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Went down today to my inside storage to check the tires for the recall. Date wise we fell right into the timeframe of the manufacturing of the recalled tires. I was pleasantly surprised to find that the DOT sequence on my tires differed. So I'm off the hook and have a good set of tires. The first two characters of the DOT sequence identify the plant that manufactured the tires, so apparently not all of these tires in our style and size, manufactured within the timeframe of concern are bad. What's interesting is the dates of manufacture of the bad tires. From the recall letter, the production period was from the 2nd week of 2010 through the 25th week of 2012. I'm assuming that such a long period of time probably means something wrong with some equipment mold for this sized tire that produced randomly bad tires.
After more research of the coding on the tires, based on the Plant Code "B3", the bad tires were produced at the Nova Scotia, Canada plant. My tires have the code "B7" which means they were produced in Dothan Alabama.
Here's a link to the Michelin plant codes. MANUFACTURERS' INFORMATION DATABASE (MID) | National Highway Traffic Safety Administration (NHTSA) Just enter in the name of the tire brand and search. On the page which comes up, scroll down and you will get a listing of the code and plant associated.
While brand new tires would have been nice, but I'm not disappointed since mine were manufactured 2412 and I put them on about 6 weeks later so they are relatively new.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-05-2014, 07:04 PM   #82
jasperkins's Avatar
2012 27' FB Eddie Bauer
colorado springs , Colorado
All 5 of our EB tires are under recall. As noted, there are no Michelin replacements available to put on yet (back ordered). The tires "look" good, and have not been loosing air. I am holding off until Michelin has replacements, despite leaving on a cross country RV trip in 2 weeks.
jasperkins is offline   Reply With Quote
Old 03-05-2014, 07:17 PM   #83
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
Michelin LTX M/S LT 225/75R16 tires are available. I bought a set along with Sendel wheels from Discount Tire, Melbourne, FL about two weeks ago. It took them one day to get them from their distribution center. The manufacture date was 0114 (1st week of January, 2014). Must be they aren't available where you live or recall replacements are being handled separately.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 03-06-2014, 07:59 AM   #84
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
As soon as I read about this recall on this forum in December, I pulled the trigger on my order at CostCo for the five new 16" Michelins as I knew there would be a "shortage" generated by this huge demand.
They are now installed on the new trailer.
